Question about Sony SDM M51 15.1" LCD Monitor
Dell LCD screen goes white
Screen now goes white immediately it the beginning it would go white after it was in use for a while. Now it is almost immediately. I have removed the cover from the back of the LCD panel. However I do not see any obvious signs of a component being bad....can someone direct me to the part that usually is the issue? I have two fo these monitors currently with this problem. Unfortunately I have several of these in use and I am concerned they too will start having the same problem.
thanks in advance for any help I have the same problem. When my monitor comes on it is all white and stays that way. I have connected it to a different computor and the problem is still there.
    Champion:
  • 293 Answers
Hi...there,
It's seems you got unstable AD board that caused a white screen. Need to be replaced a new ones or updated the bios. What's the AD board? AD board is a piece of component that connecting the VGA or DVI cables. Order from Dell... I'm sure they got lots of refurbished parts laid around... Have a nice day!
Posted on Oct 07, 2008
Why a black screen on xps l701x w7 i7 1.73
Black screen - no flashing white cursor in the upper left corner - no picture at all, i.e. the initial Dell start-up screen doesn't show up either:
- LCD is dead or isn't getting a signal - not an easy fix; or
- the LCD isn't being sent a signal - holding down the function [Fn] key and press display Function key to toggle through its settings (LCD panel only, Rear VGA output only, both LCD and VGA output)
Black screen - flashing white cursor in the upper left corner - the screen goes black after the windows loading screens come up but before the windows login screen comes up - it is probably a windows video driver problem. Try starting in Windows Safe Mode with VGA. Press [F8] after the Dell startup screen disappears to access the windows startup menu
Oct 19, 2014 | Dell XPS Computers & Internet
For the last 3months,my dell vostro 1088 laptop has started giving a lot of trouble.While i'm doing working on it,the screen suddenly starts blinking and it all goes white within a second.This pro
  • Remove the battery and disconnect the power cord.
  • Press power button for a few second.
  • Connect the power cord. Press the power button to start and then dock the battery.
  • White screen on a laptop is a connection problem between the LCD screen and the video cable running from the motherboard. The issue can arise with the motherboard or the screen might contain a defect.
Aug 22, 2012 | Dell Vostro 1088
White screen
the beginning of ugly problems you will need a new video driver card and screen within about 3 to 6 months
May 28, 2012 | Dell Inspiron 1545 Black Intel Celeron 900...
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Screen goes white
Check the ribbon cable between the LCD panel T-CON board and the logic board. When you lose 5vdc feeding the LCD T-CON board the screen will glow white.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | Dell E176FP 17" LCD Monitor
Dell Dimension 4700 desktop. Turn computer on, go...
try to disconnect, stretch the master cable of Hard drive and then connect it.
May 20, 2010 | Dell Dimension 4700 PC Desktop
White thin line running across horizontal on my hp laptop
You got a bad LCD screen. no immediate resolution aside from getting the LCD replaced. if your system still has warranty call Dell for replacement.
Hope it helps!
Feb 18, 2010 | Dell Inspiron 9100 Notebook
My dell E196FPF 19'' lcd screen acting strange!
Are You using a extention cord or a ups that is not funtioning properly....?? if yes try connecting the power for the monitor seperately or directly to a plug base...
this mi8 solve ur problem
Apr 10, 2009 | Dell E177FP LCD Monitor
The problem with most LCD monitors that go white are one or more of the following in order:
1. Bad or loose VGA/DVI connection cable
2. Bad power inverter board. (Internal part: can be replaced)
3. Bad power supply.
Hope this helps you.
Dec 29, 2008 | Dell E151FP 15" Active Matrix TFT LCD...
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Sony SDM M51 15.1" LCD Monitor Logo
320 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
