Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer SD P50A5 red light stays on, green lights up but does not stay on
You mentioned a fuse replaced on the power board, is this on the outside or the inside of the unit?
Where can I locate it?
Thanks,'
Louis Blanaru
louisblanaru@shaw.ca
  • louisblanaru Oct 07, 2008
    i will give it a try
    thanks,
    Louis
  • psft99x Jan 04, 2009
    The same problem occurs after I used the TV 1-2 days. I replaced the fuse (4A with 125V) 4 times in the last 10 days. What is the best way to solve this problem? Right now, I keep on replacing the fuse. Should I change to other types of fuses (I bought a package of 4 fuses with 4Amp 125-Volt Fuses from Radio Shack)?
    Thanks in advance.
The fuze replacement worked.  I was just about ready to trash my 50" Pioneer.  THANKS
Posted on Feb 09, 2009
It take me sometime to find out the fuse. It is behind the transformer in the middle of the board.
Yes, my TV is working now.
Thanks
Francis Fu
California.
Posted on Dec 23, 2008
You were 100 % on the money for this solution. It was the 4 amp fuse exactly.
Unit works perfectly now - even better than the reply from the service company who said they had no idea what the problem was, and also they didn't believe it could be a fuse.
It was the fuse. You are the BEST!
Louis
Posted on Oct 08, 2008
    Problem Solver:
  • 6 Answers
It's internal, located close to many other fuses, the one in question is a 4a 125v fast-blow.
Get a flashlight, (after opening up the bottom cover on the back) and look at ALL the fuses
on the power supply board. Search intently on finding a 4a glass mini-AGC board-mounted fuse.
MAKE SURE the TV is unplugged when you do this!
Posted on Oct 07, 2008
  • el seven Oct 07, 2008
    It's labeled "4a" directly on the board, very close to where the actual fuse is located, if not directly under the fuse itself, i forget now...
    Look for 4a on the PS board / the PS board is the only board with the power cord running to it.
Pioneer pdp-505cmx both red and green lights stay on - no picture - any ideas?
After replacing the power supply board, it is necessary and a must to adjust its Va & Vs voltages. These details will be there on its panel label. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts. Without adjusting these voltages properly, might make the Plasma Display defective.
Jan 01, 2014 | Pioneer PDP-505CMX 50 in. Plasma...
SD P50A3 Q red Standby is on....will not power up.
ok sir you have defective power supply at hot side section! and the power oscillstion circuit! your unit need to diagnos to know the exact defective parts!
Oct 21, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
I HAVE A SD-532HD5 RED LIGHT STAY ON....IT USE TO TURN OFF BY ITSELF ONE DAY IT WENT OFF AND NEVER CAME BACK ON ......THERE IS A RED LIGHT ON THE POWER BOARD
This model and others close to it have all sorts of soldering problems on the power board----fixed a lot of them by removal of power board and aside from fuses solder the ENTIRE board--every connection---bad connections develop with age and heat.
Oct 14, 2012 | Pioneer SD-532HD5 53" Rear Projection...
Pioneer 65" TV Model # SD-643HD5 won't power up.
I would suggest replacing the board itself, chances are what caused those fuses to blow is still faulty. did you check those fuses again after you powered it back up?
Jun 12, 2011 | Pioneer Televison & Video
THE TV STAYS OFF
If the sound keeps working your probably just need a new lamp, if the sound does not stay on, you probably to get someone to fix the power supply.
Sep 02, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Main power light turns on but i have no picture or sound
Take a closer look at the power board fuses. There is a fuse numbered 106 a little ways away from the rest of them. I have this same model and got it working long enough to diagnose a bad flyback transformer by replacing this fuse with one from Radio Shack. At some times, I could put in a new fuse and have the set work for a few weeks. The flyback transformer is available from parts.pioneerelectronics.com for around $60.
Jan 29, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer sd-t50w1
My SD P 50A3-K We unplugged it and now wont come back on to stay...we turn it on then the red lite comes on green flashes on then right back off.....Some times tv will come back on then it shuts it self off....please help thank you
Jun 30, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
50" Projection TV
your set was going into protective shutdown. Probaly a leaky diode that was raising voltage that triggered the shutdown circuitry.Toshiba has good service info available to trubleshoot the power supply and shutdown circuitry. let me know if you would like me to post a link on where you can get this troubleshooter manual .
Feb 24, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
163 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
