Question about Philips 55PP9401 55" Rear Projection Television
Lost remote / convergance problem
Hello, I will be repairing the convergance circuit on my philips 55PP9401 TV. The problem is that the remote has been lost, damaged. Is there a way to do the auto alignment (intelisense) without it? Thanks, Mike
  • wireitupman Oct 13, 2008
    thanks, ill do that
  • 38 Answers
U can not set the convergence without the remote control just look on the web they are between 30 and 60.00 dollars
Posted on Oct 13, 2008
We no longer have the remote for model 55pp9401 and we have a convergence problem what can we do
Here's the Philips support URL for your TV:
PDF download of your Owners' manual:
Here's what Philips FAQ says about your convergence procedure:
Question How do I adjust convergence (align colors)? Answer Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
Press the INTELLISENSE button on the remote (under the flap). During the convergence process DO NOT press the INTELLISENSE button again and DO NOT move the Projection TV.
So, I think you're going to need to order a replacement remote.
search "replacement remote" at
May 13, 2011 | Philips 55PP9401 55" Rear Projection...
Intellisense button
If the model number on the set is 55PP9401/55 you have an interesting set----this model says Philips but was made by Hitachi---they made them for Philips for one year while Philips was gearing up to produce their own sets---very good set and is better than the Philips sets that came after it.
It uses (if it is this model) two STK-392-110 CONVERGENCE IC's----both need to be replaced and the set adjusted---no need for an original remote---with the set engaged in the convergence adjustment mode( there is a micro switch on the front of the main circuit board) A HITACHI REMOTE CAN THEN BE USED TO ADJUST THE CONVERGENCE. Hope this was helpful.
Aug 11, 2009 | Philips 55PP9401 55" Rear Projection...
Philips TV model 60PP9202/17F veins circuit board destroyed
Email the team at - they may have a photo or service manual for that model.
Jun 14, 2009 | Philips 55PP9401 55" Rear Projection...
Where can i buy remote control for phillips 55pp9401?
get a full universal at your local walmart for less then 20 with full menu and program functions, get a phillips brand and no programming required.
Mar 16, 2008 | Philips 55PP9401 55" Rear Projection...
55pp9401 convergence problem
try aligning them using the yoke control rings.
sometimes the alignment is so far out that you have to adjust the magnet rings instead.
Feb 25, 2008 | Philips 55PP9401 55" Rear Projection...
You probably have a problem with your convergence board. Try resetting the convergence manually on your TV - go to Philips website for instructions on doing this if you have lost the Quick Start Guide. If the manual convergence fails, then your convergence board needs to repaired or replaced.
Dec 24, 2007 | Philips 55PP9401 55" Rear Projection...
Phillips 55pp9401 red and green not converging even after using itellesense
Replace convergence IC's STK392-110 mounted on large heatsinks....I use upgrade STK394-160E = CZ 01341 Hitachi #.
Let me know if you have ??'s.......................T.
Oct 27, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ, look for discolored resistor
near IC's.....replace with exact value......last = activate
Sep 25, 2007 | Philips 55PP9401 55" Rear Projection...
Philips 55PP9401 55" Rear Projection Television Logo
102 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
