Cant adjust red convergences - Televison & Video
  • deenaworkman Mar 31, 2009
    how do you replace the converge ic
  • 185 Answers
Replace the red converge ic, typically all chips get replaced when 1 goes
Posted on Oct 08, 2008
It appears to be convergence issues. Red, green,
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
May 15, 2010 | Mitsubishi WS-65511 65" Rear Projection...
55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Oct 01, 2009 | RCA HD52W59 HDTV Projection Television
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
Cant get icns lined up can adjust side to side but
if this is a rear projection crt type set go into the customer menu and select CONVERGENCE--if either blue or red will not move up and down--you have a bad convergence IC---most sets use two of them.
Aug 07, 2009 | Philips Magnavox 51MP392H Rear Projection...
Convergence
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Oct 09, 2008 | Mitsubishi VS-50803 50" Rear Projection...
Kp-43t70 red out of adjustment
It seems, from your description, that the convergence circuit is failing. The usual components that fail are the convergence integrated circuits.
Dec 20, 2007 | Sony KP-43T70 43" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Red convergence will only move up or down
Stk392-110 red convergence IC is bad...normal procedure===
1) pull chassis   2) replace both Stk's for reliable repair
3)re-assemble  4) re-align convergence
If you hire a technician, 400.00 is ave. price.
Oct 16, 2007 | Toshiba 50H72 50" Rear Projection...
Televison & Video Logo
776 people viewed this question
Top Televison & Video Experts
