Question about Mitsubishi WS-55813 55" Rear Projection HDTV
DM module removal
How to remove the DM module, can you give me any directions I have a WS-55813 and the green light is blinking. My friends said that I need to replace the DM module. How can I remove the DM module so that I can replace it. Please advice.
  • kierannataj Oct 17, 2008
    Please let me know how to replace the DM module for the Mitsubishi WS-55813. Also let me know where to get this module.
  • Anonymous Apr 03, 2009
    i went to the link welcomejee posted but the dm module removal is different on the tv they have than it is on the ws55813. does the dm module just unplug off of the board after removing the 4 screws in the casing or is there more to it? i got the 4 screws out & tried pulling the dm module out but it seems very tight & resistant to pulling out.
  • 10,594 Answers
Check this link for guidance with pictures about DM board removal.
Thank you.
Posted on Oct 07, 2008
Constant blinking green light on Mitsubishi WS-65909 TV. Replaced the 7 Capacitors on the DM module and re-installed into the tv, plugged in and the same blinking green light problem is happening. Is
This is a V19 chassis, circa 2002
If all capacitors were replaced correctly & all caps with bulging tops were replaced, It sounds like you may have other issues on the DM pcb. Possibly defective ICs. That would be the E2P module (a small pcb which plugs directly onto the DM pcb), which is specific to your particular model & serial#
Several years ago the only way to get the E2P, was thru the manufacturer, they also, used to make a kit that you could replace those ICs yourself. Those pcbs & kits were limited. So all I can do is wish you much luck if that is the problem.
At this point I would double & triple check the replacement of your capacitors.
Dec 11, 2014 | Mitsubishi Televison & Video
Trying to replace capacitors in dm module
it is tight, and some what glued in place just pull firmly and straight up. it will come out ok.
Apr 03, 2009 | Mitsubishi WS-55813 55" Rear Projection...
Green light flikering
Replace all 7 capacitors in the DM Module on the DM Power Supply Board. If it is similar to the WS-65869 and WS-65513 it will have a metal enclosed DM Module at far left of chassis, looking from rear. About 4 or 5 connectors, screws, and Module slides out. Take top shield off. Take good notes or use digital camera or video recorder to make re-assembly easy. These capacitors are 1000uf@16 volts. They always check good, just replace them! After re-assembly plug AC in and wait 90 seconds or more (green Timer LED will stop blinking), then press Power button. If Timer LED doesn't stop, look for small pinhole (System Reset) and press switch with pen or small screwdriver, then wait for green LED to stop blinking. Then Power On TV.
Feb 08, 2009 | Mitsubishi WS-65809 65" Rear Projection...
2004 Mitsubishi WS-55813
You need the V23 Chassis DM repair kit which has the replacemnt capacitors and the instructions on how to do the repair. Heres the link to the kit. You also get the full service manual on the instructional CD as a bonus.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 16, 2009 | Mitsubishi WS-55805 55" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light
The DM module in the TV is bad. Some can be fixed easily some cannot. What is the model #?
Sep 11, 2008 | Mitsubishi WS-65713 65" Rear Projection...
Blinking timer light on mitsuWS-55815
My mitsubishi little green timer light will not quite flashing and the tv will not come on.
Apr 01, 2008 | Mitsubishi WS-55813 55" Rear Projection...
Green blinking light on Mitsubishi WS-55813 HDTV
generally this means a bad digital module.. as a techinican the first thing that we would check are what is know as standby voltages. if they were there we would replace digital module.! question. Does it blink for more than 70 seconds. This unit comes with a lockout feature. to unlock press and hold menu down for 10 seconds on front panel.
Jan 08, 2008 | Mitsubishi WS-55813 55" Rear Projection...
BLINKING GREEN LIGHTS IN FRONT
Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030..if they are ok then the DM pcb itself is bad part # 934C067002
Nov 27, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Timer Light Blinking
Replace four caps in DM module 1000mf/25v 105 degree...
common repair for qualified Mits tech............T.
Oct 13, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Mitsubishi WS-55813 55" Rear Projection HDTV Logo
966 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
