Question about Panasonic PT-47WX49 47" Rear Projection Television
My Panansonic TV shuts down every few minutes and the LED blinks three times
This 6 year old TV that is 47 or 52" Panasonic started shutting down down every day several times. Once it shuts down the LED blinks three times and with a pause in between and keeps repeating blinking three times.
Once I unplug the cable and plug it back in, the TV can be switched on. However it sometimes stays stable for 2 min or 2 hrs unpredictably. Sometimes, i tried 3-4-5 times within minutes and is frustrating to keep doing it.
What needs to be changed? and what costs are normally incurred for this kind of problem?
  • wilkinson4 Nov 10, 2008
    tv WILL COME FOR ABOUT 10 SECONDS AND WILL CUT OFF. HAVE TO UNPLUG IT AND WAIT A FEW MINUTES AND PLUG IT BACK UP AND DOES SAME THING AGAin.
I still have that problem. I calle Mfr and also spoke to repair shops recommended by them and they said they estimate a cost of 300-400$ or so approx. I am waiting to buy a new LCD which could be few 100 more but at least dont have to live with the old one and keep spending money...
regards
Posted on Nov 05, 2008
Model th42px50u plasma. What happened to picture?
Evidently power supply failure. The blinking LED may indicate the TV is trying to restart, but can't.
Mar 05, 2016 | Panasonic Televison & Video
Power indicator light blinks-7 times. will a new power supply fix it
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
blink 7
There is a sequence that you have to check to figure out which board is bad,
Feb 16, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
I have a Panasonic PT-50DL54 50" rear projection tv. My tv screen won't come on but the fans will. The power led light flashes green like normal but than starts to flash fast for about a minute than the...
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
Jun 14, 2010 | Panasonic PT-50DL54 50" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic pt-47wx53g
How many times is it blinking? That is probably blinking a code because its shutting down. Let me know how many blinks its blinking and I will be able to tell you whats wrong with your TV
Apr 12, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic Th37PE30 Viera plasma stopped working
here is a complete list of all codes for panasonic tv's rgeardless of model if its panasonic it is these codes
1 Blink SOS: This shutdown operation is usually caused by a lack of communication between the A and the D boards.
1 Blink SOS: This shutdown operation may be caused by the improper connection of a SS board connector to the panel.
2 Blinks SOS: Pin 87 of the MPU IC9003 monitors the 15V line. During normal operation, the transistors Q9053 and Q9054 output a high to pin 87. If the 15V line is missing or shorted, a low is provided to pin 87. As a result, the unit shuts down and the power LED blinks 2 times.
3 Blinks SOS: IC9807 is a 3.3V regulator located on the D board. Its output is monitored by IC9003. If the 3.3V is not present at pin 86, the MPU shuts down the unit. The power LED blinks 3 times.
5 Blinks SOS: Pin 85 of the MPU IC9003 monitors the 5V line. During normal operation, the transistors Q9051 and Q9052 output a high to pin 85. If the 5V line is missing or shorted, a low is provided to pin 85. As a result, the unit shuts down and the power LED blinks 5 times.
6 Blinks SOS: Pin 90 of the MPU IC9003 monitors the status of the SC board. During normal operation, the transistor Q6581 and IC6581 output a low to pin 90. If the SC board becomes defective, a high is provided to pin 90. As a result, the unit shuts down and the power LED blinks 6
6 Blinks SOS: 6 blinks of the power LED may also be obtained from pin 3 of IC9003, the DRV_RESET input. The D board provides the 5V source needed to power the C boards. On the C2 board, the 5V is routed back to the D board via connector C20/C10, C11/D31 causing pin 3 of IC9003 to be high. If 5V is not routed back to the D board, pin 3 of IC9003 goes low. The set goes into shutdown mode and the power LED emits 6 blinks.
7 Blinks SOS: Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
8 Blinks SOS: Pin 91 of the MPU IC9003 monitors the status of the SS board. During normal operation, pin 8 of connector SS23 outputs a low to pin 91. If the SS board becomes defective, a high is provided to pin 91. As a result, the unit shuts down and the power LED blinks 8 times.
10 Blinks SOS: The SUB5V and DT9V sources created on the A board are monitored by IC1100. If they are not present at pin 30 and 34, the MPU shuts down the unit. The power LED blinks 10 times.
10 Blinks SOS: The F_STB_15V of the P board, as well as the derived SUB5V and DT9V sources are monitored on the A board for excessive current. If a short circuit is developed in one of the supplied lines, pin 114 of IC1100 receives a high. The SUB5V and DT9V lines are also monitored for excessive voltage. When an over-voltage condition is detected, a high is also output to pin 114 of IC1100. The DT9V is provided to a DC/DC converter to create the BT30V for the tuner. If the BT30V becomes excessive, a high is output to pin 114 of IC1100. A high at pin 114 of IC1100 causes the unit to shutdown and the power LED to blink 10 times.
Feb 26, 2008 | Televison & Video
Panasonic Plasma TH-42PZ77U Power Light Flashing 7x
Dec 31, 2007 | Televison & Video
Panasonic PT-47WX49 47" Rear Projection Television Logo
224 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
