Question about RCA Universal Remote 3 Device Remote Control
Universal remote directions to program vcr
    President:
  • 1,734 Answers
If you need help with the codes ask here
They will find the right code for your specific VCR.
Posted on Jun 28, 2009
How do you program it to a GE universal remote
these are the codes
LG: 004 005 009 012 050 057 080 156 227 338
  • How to Program a GE Universal Remote ' Techwalla https://techwalla.com/content/program-ge-universal-remote Lost your Remote? Need help programming your GE Universal Remote? Most TV's, VCR's, DVD Player's, Cable and Satellite Boxes will work with a GE universal...
  • How to Program GE Universal Remote: Quick Steps www.brighthub.com > Electronics > Home Theater > Home Media 2011-04-18 · How to Program GE Universal Remote Using the Code Search Function. If you've tried the codes listed for your device brand and are unable to get your ...
  • GE Universal Remote Codes and Instructions ' direcTutor www.directutor.com/content/ge-universal-remote-instructions Goto GE remote Codes. Direct Code Entry for GE remotes with 4 digit codes. 1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
  • How to Program a GE TV Remote ' Techwalla https://techwalla.com/content/program-ge-tv-remote GE universal remote controls allow users to program multiple devices onto a single remote. The remote control uses codes to detect the device, and you can...
  • GE Universal Remote Quick Start Guide - YouTube Youtube
    • BY JASCOPRODUCTSCOMPANY
    • 3 MIN
    • 216K VIEWS
    2013-04-18 · Video embedded · http://www.jascoproducts.com Eliminate remote clutter with GE Universal Remotes
  • How to Program a GE Universal Remote Control ' eHow www.ehow.com > Tech > TVs > Remote Controls
    • BY EHOW ELECTRONICS EDITOR
    Programming a Jasco/GE Universal Remote Control takes about seven steps. As with programming other remotes, you need to know the code of the component you are ...
  • May 09, 2016 | LG "32"" inch New 2011 HD LCD TV With HD...
    Need the code to program my universal remote to my jvc tv the serial# to my remote is rc24922-c1122 model jc024
    Do a code search method as follows.
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
    Dec 26, 2014 | GE 24926 Glow Keys Universal Remote...
    I have a all for one remete urc#4063b06 need code for samusung tv/vcr modelcxa192680b
    There is no code for Samsung TV/VCR combo units. Try the Samsung VCR codes: 240, 045 and the Samsung TV code: 060, 427, 056, 030, 019, 178 . Program the VCR and the TV buttons separately.
    Most One for All universal remote manuals and code lists are available from: http://www.oneforall.com/support/manual . You may need to change the country listed at the top of the page. Then use the drop down menus to select Universal Remote and the model. The direct link to the manual for the URC4063 is http://www.oneforall.com/uploads/support/00b313f46269f3fc78988edae4518f03.pdf .
    Please note that the codes programmed into a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV/VCR is newer than your remote, you may need a new remote.
    I hope this helps.
    Oct 03, 2011 | One For All URC-3021 Remote Control
    Need a code for zenith/vcr combo.
    Program a GE Universal Remote Using Code Search Make sure the device for which you want to program the remote is turned on, and that the GE universal remote has good working batteries in it. Batteries that are weak may keep the universal remote from being programmed. Press and hold the Setup or Code Search button. Again, the name of the button will vary between GE universal remote models. Once the indicator light is lit, you can stop pressing the button. Press the button with the name of the device for which you want to program the GE universal remote (such as TV or DVD) and release it immediately. The indicator light should flash a time or two and then simply stay lit. Now all you have to do is point the GE universal remote at the device you selected, press the Power button and release it. The catch is that if the device does not turn off, you must wait at least two seconds and try again. The GE universal remote will attempt to program the right code for the device, cycling through all of its built-in codes. This can take up to 250 attempts. When the universal remote (finally) catches the right code and is programmed, the device will power off. Once this happens, press the Enter or Save button on the GE remote to complete the programming process. and for free
    Jun 02, 2011 | Televison & Video
    Can not program my rca remote model rcr311w.
    If you go to rca.com they have a full list of manuals. Just select your model and follow the directions. Have a great day..
    Aug 27, 2009 | Universal Remote Control DIRECTV Universal...
    Instructions on how to program RCA universal remote control
    This link is a .pdf of the manual with directions on how to program the remote as well as all of the codes for various electronic brands for all equipment (DVD, TV, VCR, etc.):
    http://www.lexrixa.com/vcr%20codes.pdf
    Jun 20, 2009 | RCA Universal Remote Control
    Cannot find remote code for panasonic TV/VCR combo for RCA remote
    Here is a list of codes for your remote. Please follow any of the links below to get your codes.
    Results 1 - 10 of about 324,000 for rca universal remote codes. (0.26 seconds)
    Search Results
    1. RCA Universal Remote Control-Programming Codes RCA Universal Remote Control-Programming Codes. ... The remote may already be set up to operate your brand of TV, VCR, or Cable Box. ...
      www.thompsontv.com/rcarc.html - 33k - Cached - Similar pages -
    2. How to Program an RCA Universal Remote Without a "Code Search ... wikiHow article about How to Program an RCA Universal Remote Without a.
      www.wikihow.com/Program-an-RCA-Universal-Remote-Without-a-%22Code-Search%22-Button - 42k - Cached - Similar pages -
    3. Universal Remote Control Codes Codes and links for a number of universal remote controls, including Sony, RCA, Memorex, Radio Shack, One For All and more.
      www.xdiv.com/remotes/ - 73k - Cached - Similar pages -
    May 05, 2009 | RCA Universal Remote 3 Device Remote...
    Lost remote programing directions
    Great News!! We can program most Philips Universal Remotes with Automatic Code Searh. Here's how it works on most of our remotes.
    Programming with Code Search
    2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
    3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
    4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
    The above assumes that you want to store the VCR you want under the VCR but, Cable codes under the CBL, etc
    Note: if the device does not have a chat channel at a button, you should Play (VCR only) or Power instead.
    Here is a Code List on PDF that shoud be universal for most remotes. It worked for me.
    http://www.remotecodelist.com/remot...ps-Magnavox_PM525S.pdf
    Hope this helps you out, good luck.
    Nov 27, 2008 | Philips Magnavox Learning Universal Remote
    Remote codes
    Contact Direct tv and they should have the codes to program the remote tothat tv. Or contact Universal remote @ 919-573-7854 919-573-7854
    Aug 17, 2008 | Philips Magnavox Learning Universal Remote
    RCA GuidePlus Gemstar Universal Remote Control 242524
    i need to program my remote for my tv with this gemstar universal remote control "crk76te1 . how do i do this ? its for a zenth televison . thanks
    Jun 08, 2008 | RCA Universal Remote Control
    Televison & Video Logo
    196 people viewed this question
    Top RCA Televison & Video Experts
    jason
    matt martin
    matt martin
    Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
