Question about Innovage 69420210126 Phone
Weird..Cound't dial out
The phone works perfect at all my friends' house but once connected to any of my home's telephone jack, it could only receive calls but cound't dial out. Right after I key in the first 3 digits of area codes (905) or (416) the call couldn't get thur but instead...PLEASE CHECK YOUR NUMBER AND DIAL AGAIN Blah Blah .... Appreciate if you could help me out....thanks very much....Stephen
  • Anonymous Nov 17, 2008
    garbage made in china
  • Anonymous Dec 13, 2008
    My problem is similar. When I try to dial-out, I receive an operator intercept after hitting the third key. "The message says that the number cannot be reached as dialed... call your operator." I have the Flash rate set at the default rate (600ms), but don't know if that is the issue.
    GHIZMO
  • 26 Answers
THERE IS A BLOCKING FEATURE IN THE MANUAL ON PHONES ON THE SAME LINE ,FIND IT READ IT MAYBE THIS WILL HELP
Posted on Mar 23, 2009
Why can I receive calls but barely hear dial tone or hear them?
click on the speaker icon on your computer and check playback and recording level.. also make sure that the sound device is magic jack and not your internal sound card
Tony
Apr 16, 2015 | Uniden Cordless Phone
Tip
How to connect your VOIP phone service (IE Vonage, MagicJack, Via Talk) to...
Are you tired of being tied down to your computer area to use your VOIP phone service (IE Vonage, MagicJack, Via Talk or ITP)? Here is a way to make your existing home phone jacks work with your VOIP.
***** DO NOT USE THIS TIP IF YOU HAVE DSL (FROM THE PHONE COMPANY) FOR YOUR INTERNET SERVICE PROVIDER OR IF YOU ARE IN AN APARTMENT BUILDING*****
Items you will need-
  1. An existing home telephone jack near your VOIP service modem.
  2. A screwdriver
  3. A telephone cord long enough to reach from the VOIP service jack to the existing phone jack.
COMPLETE THESE DIRECTIONS EXACTLY AND IN ORDER OTHERWISE DAMAGE COULD RESULT TO YOUR VOIP MODEM.
NOTE THAT EACH HOME IS SLIGHTLY DIFFERENT AND MAY HAVE NON-STANDARD WIRING SITUATIONS OR HAZARDS UNFORESEEABLE SO THIS TIP IS TO BE DONE AT YOUR OWN RISK AND YOU WILL BE RESPONSIBLE FOR ANY CONSEQUENCES THAT ARISE FROM WORKING ON YOUR OWN HOUSE SUCH AS IF YOU DAMAGE ANYTHING OR GET SHOCKED OR FRY YOUR VOIP MODEM AND BURN DOWN YOUR HOUSE IT'S ALL ON YOU....
So hopefully I haven't scared you off from trying this tip since it is fairly simple to do but complements of lawsuit happy America I had to cover the disclaimers....
Let's get started...
First thing you need to do is to locate the main telephone junction box to your home usually located outside near the power meter. Here are some pics of some standard used boxes.5124c69.jpg
There is a screw keeping the customer access door closed. Loosen this screw and open the access door to expose the home wiring. Note: this screw does not usually come completely out. To set you at ease, yes it is completely legal for you to access this portion of the box. The portion that you are not supposed to access is restricted by a security bolt and can not be opened with a normal screwdriver.
Once you have the access door open there are two types of commonly used connections.
  1. The most common is one similar to this picture. Disconnect the lines attached to the test jacks.
    If you have more than one line here then loosen the screw terminals one at a time and place the wires from the other lines to the same terminals on Line 1 so all jacks in the home should be available.
    Note: there may be a cover over where the screw terminals are for where LINE 1or 2 are, simply pull the cover toward you to expose the terminals.
2) The second style is very similar to the first but the area where the screw terminals are has a plastic rectangular bar about 2 inches long and 1 inch wide with telephone lines attached to it (often times Red and Green or Blue and White/Blue). If you have this style of connection push the side of the bar closest to the center of the box and then pull outwards and to the right this should expose the "Test Jack". Once the bar has been extended twist it 1/4 turn counterclockwise to remove it from its mounting bar. Use caution not to disconnect the phone wires attached to the bar.
Almost there and now the hardest part should be done.
Now return to where the VOIP modem is located and remove the telephone cable for the phone that was being used for your VOIP service.
Connect the new phone cord to the same outlet that the phone was connected to on the VOIP modem and then connect the other end to the home phone jack.
If you still want to connect a phone to the jack you are connecting to here then a simple telephone line splitter plugged into the jack will fix that.
Now try to connect a phone to any of the phone jacks in your home and you should have dial tone. Note that most phone service is made to comfortably handle 4 phones that connect to a phone jack.
on Jan 16, 2010 | Lands Phones
My in house telephones are not working,but the internet is working.WHAT CAN I DO TO MAKE THE TEELEPHONE WORK AGAIN.
Have you paid the phone bill? Are you supposed to have phone service?
Providing that you have a contract with the phone company and it's paid up, take a hardwire telephone out to the grey junction box on the outside of the house. Open the junction box and plug your phone into one of the two phone jacks inside, Try the phone. If you get no dial tone, try the other phone jack.
If you get no dial tone from either phone jack, borrow a hardwire telephone from a neighbor and try both jacks again with the borrowed telephone.
If no dial tone with your phone or your neighbor's phone, then the problem is on the phone company's side of that junction box.
If your neighbor's phone works but yours doesn't, the problem is your phones - lightening strike, maybe?
If your phone works in the junction box but not inside the house, then the wiring from the junction box to your house jacks has a bad connection somewhere. Someone - you or someone else - will have the arduous task of tracking down where that bad connection is.
Jul 29, 2014 | Panasonic Lands Phones
Why does my phone say no line?
That means that it is not connected to the wiring that has voice data on it. IT cannot detect the voltage that should be there. Check the wires to the plug in to the phone jack.
Apr 09, 2014 | Lands Phones
Phone less than a year old. no dial tone with inability to call out or receive calls. other phone functions seem to be working
First check if it is the phone or the line. Try replacing the cables. Use another phone (known working) to see if the jack has a dial tone with it. If you have dial tone on another phone and not on this phone with any set of RJ-11 cords, then send the phone to AT&T for repair. It had a 1 year warranty. Contact the customer service at www.telephones.att.com, or call 1 800 222-3111.
Try both phone on other jacks with that line, if available. If the phones work on other jacks but not on the first one, open up the faceplate and check for loose wires. Most either use screws to hold the wires or have keystones with punch downs. If you have the screw type, strip the wire strand if needed and resecure the wire. http://www.lanshack.com/wire_phone_jack.aspx has the diagram of the wiring. The keystone punchdown tool is available at stores like Lowes and Home Depot, among others - in the section for wiring a new home.
Try then on another line, if possible. If the phones work here, then it is a general wiring issue on the other line.
Find where your telephone service comes in and see if the box has RJ-11 connections. Try your phones there. If the phones do not work at other jacks and the service connection is not RJ-11, call your telephone provider. They can test the line and will repair the line free if it is an outside issue. If the issue is inside, check all exposed wiring for damage. Check the jacks as well. If it is a problem inside the wall, you may want a professional. Your telephone service provider will probably fix it for a fee.
I hope this helps.
Feb 04, 2011 | AT&T 1855 Phone
I have a Lucent model 103H. I no longer get a dial tone when I push the line buttons. I only get static. I replaced the two AAA batteries yet I can still not dial out or receive incoming calls. Do you have...
hmmm .. the lucent 103h is called a "partner 5 slot (carrier) chassis for partner internal phone systems .... used in business usually for multiple phones... unless you have a home phone by that same name .. if you do have a "partner" system then lucent repairs those for about $65 ... check the line before considering repair ... if you have a single standard phone that just happens to have the same name .. then you may have a damaged telephone line .. you can test that by unplugging this phone and temproarily plugging in another .. if it works then there is likely damage to your original phone .. usually its lightning surge protectors that fail (due to a nearby llightning hit) ...if a second phone doesnt work then there is usually a service jack near where the phone line comes into the house .. you can plug in there .. if the phone is bad there also then its an outside maintainence repair job .. thats free from the telephone company .. if the test phone works at that test jack then its often your responsibility to arrange inside line repair .. unless you have an inside line repair contract the telephone company may charge for inside repairs .... your phone company can talk you thru using the service jack .. you would first disconnect the rest of the house by removing a connector from the service jack then you would plug in a standard phone to that jack .. that makes sure the problem is either inside or outside .. if your phone happens to be chordless then there is more things to consider .. the handset and base have to develop a relationship in order to work properly ... that relationship can be lost in a power failure and must be reestablished .. usually thats done by removing power from the base for a minute then connecting it again .. so there are a lot of possibilities depending on what type phone you have ...
Aug 18, 2009 | Avaya Lands Phones
Service was connected on Saturday 10/11, telephone rings in your ear when phone number is dialed, telephone not ringing inside the home.
If the caller hears ringing after dialing the home but the not ring inside home. That means the number is active but the wiring inside home is faulty/ not properly connected. A phone rings /or works of a basic system. Two wires usually red/green as primary. If either one is broken or improperly connected the phone inside will not ring. That doesn't indicate a short. If it was a short the caller would not hear ringing at all. So the first thing you must do is the track the cause. Make sure home phone is plugged securely into phonejack. Still no dial tone check all other jacks inside home. If still no dial tone. Contact your service provider. They will need to send a technician to check the Demarcation point. Which simply means the connection point where the service provider wires , meets the customers house wires. They just need to verify this connection
Oct 13, 2008 | Lands Phones
Got a dialling tone but couldn't make a call
Cnavarro,
my existing phones work fine but the new phone is really weird. tested Ok at the supplier's store and perfect at my friends' houses. But once tested at any of the phone outlet in my house, after keying the first 3 numbers....PLEASE CHECK YOUR NUMBER AND DIAL AGAIN etc... the scenario telling me my phone service in my house is OK and the new phone tested OK at other locations.
See if you could give me some clues....thanks
Oct 07, 2008 | Innovage 69420210126 Phone
I have 3 phone jacks in my home and right now on one of them gets a dial tone. The other two are completely dead. What could be the problem?
There should be a termination point outside your house where the local phone company connects to the wiring inside your home. These are usually wired for at least two phone lines. Sounds like your house was at one time wired for two numbers and the jack that is working was on one number while the other two jacks were on a different number. Best thing to do is connect all three jacks to the working telephone line outside the house. Good Luck. ...Mike
Aug 11, 2008 | Lands Phones
Telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Feb 13, 2008 | Lands Phones
Innovage 69420210126 Phone Logo
Top Innovage Lands Phones Experts
spiritsoul
Level 1 Expert
Mike Neath
Mike Neath
Are you an Innovage Lands Phone Expert? Answer questions, earn points and help others
