Question about Kenmore Microwave Ovens
Error code f9 model 721.63764 300 sears elite microwave arching, smoke at left side of grille upon resetting of unit by way of unplugging unit
  • 1 more comment
  • corngirl Oct 20, 2008
    Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave.
  • William Miller
    William Miller May 11, 2010
    bump
  • William Miller
    Are you saying that when you unplugged it to reset it (a good idea, by the way) it started smoking before you tried to cook?
    Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
    If you could look at that, it may show the error code F9 and tell you what it is.
    We have critical safety & disassembly info (including a disassembly how-to video) at our site, linked here.
    Please let us know what you find out.
  • Kenmore Master
  • 9,086 Answers
Very useful information. Thank you.
You can find exploded views and order parts by entering your model number at the Sears parts site.
The part number for this model's inverter is 6871W1S019AR and Sears charges $92.49 for it.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
It often features a parts layout to help you find things.
Hope this helps! Good luck and be safe.
Posted on Oct 21, 2008
  • smjnp Aug 03, 2011
    Either that or it is the magnetron...
Microwave has an error code F9 after running for about 5 seconds
Some quotes from other forums, but note that you need to look up your model to verify part numbers:
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
"f9 model 721.63764300
Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
There should be a "mini-manual" hidden inside the unit behind the control panel or hidden behind the grille, which is very helpful when troubleshooting, & testing.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
BUT once you have the part number from the Sears site, you can often get the parts cheaper
here.
May 25, 2010 | Kenmore Microwave Ovens
I have a kenmore elite microwave and after about 8 seconds and f9 error apprears...please help
The F9 error code indicates a failed inverter. If resetting the unit does not help you will need to have the inverter & harness checked.
http://media.fotki.com/1_p,wbgdfgsrsttwqwbxgtqsskgwtqkq,vi/kgdfkfrkkxkfdtftrfb/1/1303472/5961857/image45625img-or.jpg
This can sometimes by caused by a power surge or glitch through the electrical lines.
You can sometimes clear this fault by completely unplugging the microwave for 1 minute.
Plug it back in and see if the fault code returns.
If it does, then you have an internal component failure that will need to be serviced by a technician.
Microwaves must be serviced by technicians due to the inherent dangers involved in repairing these appliances.
Internal capacitors can retain a lethal electrical charge even though the unit is completely unplugged.
A microwave radiation leakage test must be performed on the unit following any internal component repair.
It does not ALWAYS indicate a inverter control board problem however in other brands/models.
LG's service manual (for an example) suggests the f-9 code could be due to line voltage, magnetron, inverter module, "Relay2", or a loose connection between door/magnetron/control pcb.
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case.
For example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possibilities.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^%$
Mar 06, 2010 | Kenmore 63792 Microwave Oven
F-9 error on my LG lmvm1945t microwave
The F9 problem in this microwave is a bad magnetron or inverter.
From other users:
"F-9 on this microwave IS inverter related. My problem was the magnatron and checked out bad with the help of (the tech sheet). It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron."
"f9 Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen2.gif and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
The first thing I would suggest is a hard reset. Unplug the unit for several minutes or so. Then plug it back in, set the clock and try again.
If it fails again and you or someone you know decide to look into it further, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Sears parts site.
The magnetron probably has an extended warranty beyond the normal one year parts and labor warranty.
So I would consult your owner's manual or contact Sears for details on the warranty.
To get your owner's manual, just enter your full model number at the Sears parts site.
On the resulting page, look to the right for the blue "View Manuals" button.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Oct 06, 2009 | LG LMVM1945 Microwave Oven
F9 err cd on Mod 721-80869400 be caused by metal tray in micro?
Aug 24, 2009 | Kenmore 63792 Microwave Oven
F9 code on mod 721-80869400 kenmore elite
This is usually inverter trouble, but it may be the magnetron, controller, wiring, etc.
May 17, 2009 | Kenmore 63792 Microwave Oven
Sears Kenmore Elite Microwave F-9 Error
My guess is that it is the main transformer that has developed a fault. If the insulation has broken down - it will arc there instead of the magnatron. Or it could be the magnatron itself. Both are prime suspects - and expensive to replace.
Unless you are particularly attatched to this - I would buy a new unit - and sell the turntable plate to recoup your losses.
Feb 04, 2009 | Microwave Ovens
F-9 appears on microwave when I try to heat somethingIt
First of all, I would bet your model number is 721.64683300 not 731.64683300, right?
From other users:
"f9 Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave."
Sears parts site.
Sears parts site.
Dec 16, 2008 | Microwave Ovens
KENMORE ELITE MICROWAVE
F3H is a humidity sensor error.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again. If that doesn't work, leave it unplugged for maybe an hour.
If it still fails, you have a bad sensor.
You can usually find exploded views and order parts by entering your model number at the Sears parts site.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 01, 2008 | Kenmore 62702 Microwave Oven
Kenmore elite ultrawave microhood combination error code F9
F9 is normally a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
Aug 22, 2008 | Kenmore Microwave Ovens
Microwave Ovens Logo
291 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
