Question about Toshiba 50H72 50" Rear Projection Television
Jumping picture for a few minutes
When I turn on tv, my picture jumping in all directions. After a few minutes picture is fine. With time it takes longer to get a clear picture. Thanks, Adam
    President:
  • 3,130 Answers
Theres a bad capacitor off the sweep power supply or possibly in the main power supply. Most likly though it would be where i mentioned first. There are no user serviceable parts inside this set Unless your a repair person so best thing for you to do is call in a pro to assist you in this repair. Good Luck
Posted on May 31, 2006
Picture is jumping lg55lb7500
10 Ways To Fix A TV Picture That Jumps Jerks or Skips ...
https://removeandreplace.com/.../10-ways-to-fix-a-tv-picture-that-jumps-jerks-or-skip...
Aug 5, 2016 - QUESTION: When I watch my TV, the picture sometimes jumps. How do I test it to see if it's the TV or another issue? If your TV picture is jumping while watching cable, satellite, or streaming, there are a few things you can check. See below for the best solutions to fix a TV where the picture seems to "jump" or ... Missing: lg55lb7500
Picture jumps every few seconds. - Forums - CNET
https://www.cnet.com/forums/discussions/picture-jumps-every-few-seconds-375282/ Dec 26, 2009 - 5 posts - ‎2 authors
I have a Samsung LN -T4061F model I bought two years ago. Over the past two days I have noticed that the TV picture jumps every few seconds. In the trouble sho... Picture Issue on my Samsung Television/Blu-Ray
23 Aug 2010
Samsung UN55C8000 Jumping images
7 Apr 2010
More results from www.cnet.com
Missing: lg55lb7500
How to Stop Jitter on a LCD TV ' Techwalla.com
https://www.techwalla.com/articles/how-to-stop-jitter-on-a-lcd-tv Mar 31, 2015 - When using an LCD television you may notice occasionally that the picture jitters, or jumps down the screen. This makes watching the set rather disorienting and may even cause headaches. Fortunately, there are a few troubleshooting steps you can take to correct the jittery picture issue before calling on a ... Missing: lg55lb7500
Picture jumping - The eBay Community
https://community.ebay.com/t5/Technical-Issues/Picture-jumping/td-p/26963824 In the last few days, when I have been viewing photos/pictures in a seller's listing, they have been flickering and jumping until I viewed the.Missing: lg55lb7500
Feb 21, 2018 | Televison & Video
Purple static lines and a jumpy picture
Your picture tube is about to go.
If it's still under warranty,take it back.
Hope this helps.
Nov 26, 2013 | Mitsubishi VS-45607 45" Rear Projection...
I have a Clarion NX-500 and we're having problems with the clock. First, it kept jumping to an entirely different time (1/2 hour ahead). The guy who installed it disabled the "synching" between the clock...
http://www.teamclarion.com/Sharedwebdbs/clarionsupport.nsf/ce17209d69d0c0b688256ea0005a1fbc/70a5e00878ca4cb0882577eb005afb17?OpenDocument . follow the directions on the english pdf and it should update to the right firmware. make sure you follow directions exactly or take it to a clarion dealer to do it.
Oct 09, 2010 | Clarion NX500 Car Video Player
My AKAI PDP4273M 42" Plasma has thin horizontal lines that flicker across the screen and then the picture jumps and flashes red and green distortions on the screen acts like interfearance of some sort if i...
This sounds like a loose solder joint, or overheated component. I know this may sound like a **** question, but have you tried tapping the TV to see if it goes away? If it does, you will need a tech to re solder the loose component. I have also seen this type of line and color bleed problem, believe it or not from poor cabling or loose connections.
Mar 09, 2010 | Akai PDP4273M Television
My Samsung 23 inch LCD tv works fine for 25 minutes then the screem starts jumping..
There is a Anynet Setting under the input tab. It has to be on the right setting or the picture Jumps after 20-25 minute. Once I adjusted it to the right setting it stopped jumping and it now works Perfect. Would nt have figured it out if I wouldnt have been messing around with it as a last chance deal.
Dec 27, 2009 | Samsung LN-R237W 23 in. LCD Television
My beko 20'' lcd tv picture keeps bouncing . when it is turned on. what could be the cause? The picture is fine for a few minutes then starts jumping
Is this tv getting free air signal?Have a better antena like a roof antena or digital antena.If it cable,satalite or telicom signals.Turn off the reciever box,than turn it on again for the signal to reboot and update the software to work better.
Nov 06, 2009 | Televison & Video
Flickering/jumping picture
I HAVE THE SAME PROBLEM. TV WAS FINE UNTIL A FEW MONTHS AGO. OF COURSE ITS OUT OF WARRANTY. FROM WHAT I HAVE READ, AND BEEN TOLD, IT IS THE POWER SUPPLY TO THE UNIT. IT IS DEFECTIVE, OR IT OVERHEATS AND TRIES TO SHUT DOWN. A LAW SUIT IS IN PROGRESS AGAINST WESTINGHOUSE TO RESOLVE THIS MATTER. KINDA REMINDS ME OF THE XBOX 360'S WHEN THEY CAME OUT. ALL YOU CAN DO IS TAKE IT IN FOR SERVICE. OR, YOU CAN KEEP TURNING IT ON AND OFF, LIKE I DO. I HAVE HAD THIS TV ON ALL NIGHT BEFORE WITH NO PROBLEMS. AS SOON AS I START CHANGING STATIONS, OUT IT GOES. GOOD LUCK. WESTINGHOUSE WILL NOT EVEN EMAIL ME. I HAVE TRIED SEVERAL TIMES TO CONTACT THEM. I HAVE HEARD FROM THE LAW FIRM IN CALIFORNIA THAT IS GOING AFTER THEM. GO ONLINE, AND JOIN THE CRUSADE.
Mar 25, 2009 | Westinghouse SK-32H240S Television
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Help please!
most likely a weak capacitor in the vertical deflection circuit or a solder joint.
Jul 14, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Toshiba 50H72 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
