Question about GE ZV950SDSS Kitchen Hood
Hood Lights not all working...
We have a GE Monogram ZV950SDSS range hood. Unfortunetley one of the lights were replaced with the wrong MR16 bulb a 50 Watt bulb was installed and should have been a 20Watt. It worked fine for the first few days than both left side lights went out. 2 bulbs on the right side still work fine and the fan still works.. We replaced both bulbs with the proper MR16 20Watt bulbs and neither are working.. However the other 2 on the right side still are working. Please help...
  • Anonymous Jan 25, 2009
    I have same problem the fuses were blown. They are above the hood inside a black box. 2 in each box
4 Suggested Answers
  • 4 Answers
SOURCE: I have a viking Professional range hood. While
FLASH covers a multitude of possibilities. What is the voltage of the blower motor. What you are describing often happens when 220 is wired to a 110 lighting circuit. I would not be running the blower motor although I hope it has inherent built in motor protection. If the voltage is applied higher to light bulbs they become flash bulbs. Florescents can become fire fixtures fast. If you are not an electrician back away from this and disconnect power at your breakers. Do not open up and trouble shoot if you are not qualified so you do not get embarrassed and have a dirt nap. It only takes about 40 vo;ts and a few milliamps cross chess to kill you. Also when ever you turn something on start and keep the habit of using one hand to turn it on and one hand to grab your pants behind you. OK OK or skirt. This prevents a cross chest shock . Old Navy (USN) death defeating rule that sved me many times and still. Remember call a pro when you do not know .
Posted on Dec 04, 2009
SOURCE: Where can I find the internal fuse on the GE
There are (2) inline 5A - 125V fuses under the top fan/duct cover. They are located on the left side (as facing the unit) in a plastic junction box. Four Phillips head screws hold the cover on.
Posted on Jan 14, 2011
espressonist
  • 1711 Answers
SOURCE: My fan and lights stopped
You should check the lamps if they are ok and if you have a new one try to be 100%.
If not you should the fuse internal. We have here a parts diagram and fuse is part no 170 and is a 5A fuse.
Finaly since the board is new and consider that the connections have been set correctly then you should check the light transformer part no 208 in same diagram. Check whith a multimeter in and out voltage if it is ok.
Posted on Aug 19, 2011
Ge monogram fan dying slow death...first hi-spd. only, now only humming, lights work...is it fuse, transformer or worse, blower assembly
My best guess is the blower motor is going out -- probably the bearings. You might be able to replace just the motor excluding the propeller or the squirrel cage as the case maybe.
Oct 08, 2012 | General Electric GE Monogram 36""...
My hood keeps blowing the fuses for the rear lights.
There is a short in the wiring to the lights... probabbly a wire rubbed through...
Use an "OHM" meter to find the problem...
heatman101
Jan 12, 2011 | GE Monogram ZV1050SFSS 42" Island Chimney...
Where can I find the internal fuse on the GE Monogram Hood model ZV950SDSS?
Dec 30, 2009 | GE ZV950SDSS Kitchen Hood
ZV30SSF GE Monogram Hood Lighting
I found them at http://lightbulbsdirect.com look for
MR1650E26120
JDR Type Medium Base (E-26) / MR-16 2 Diameter Flood / Line Voltage / 50 Watt, they were only $5.99 each. apparently GE charges you $19.50 if you order through them.
Feb 17, 2008 | GE Monogram ZV30SSF Stainless Steel...
Halogen Lights Failing
I had the same experiences with my lights. I placed a 50v bulb and it blew the fuses. The fusees located on the right side of the bottom duct cover. use 5a 125 v fuse GE part # wb27x10542 but you can find a cheaper fuse at Radio Shack. Good luck
Mar 28, 2007 | GE Monogram ZV1050SFSS 42" Island Chimney...
Ge monogram hood has power but not working
Diana, the tech sheet I have states that if the unit has a power interruption, reset the house circuit breaker to the hood, if made before 2001. If after 2001, serial number beginning with DA press the start button to reset the hood. Let me know if it worked, Catriver..post back.
Mar 10, 2007 | GE ZV750SY Kitchen Hood
GE ZV950SDSS Kitchen Hood Logo
105 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
