Question about Frigidare GLEB30M9EC STAINLESS STEEL Electric Double Oven
Frigidare microwave Timer is counting but oven doesn't come on.
  • thunderangel Oct 07, 2008
    Frigidare Microwave
    model GLMV168KS2
    The timer is counting down but the oven and light won't come on and cook.
  • thunderangel Nov 12, 2008
    I tried slamming the door when it first died on me, no result.
    I tried again after shopping for a new one and this time a good hard SLAM did the trick. Thanks
  • 2,071 Answers
    Scholar:
  • 121 Answers
You have a defective control panel which is common with this model a can be obtained at an appliance parts store for $100 to $150
Posted on Oct 07, 2008
  • 1,800 Answers
Most likely the problem with your microwave is a shorted rectifier or a shorted magnetron tube.
- The part number for the new rectifier is AP3772273.
- The part number for the new magnetron tube is AP3769081
good luck
    Scholar:
  • 116 Answers
Yes. This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a misaligned door hinge.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
    Sergeant:
    Champion:
  • 334 Answers
Try hard reset unplug it plug back in once
  • 2 more comments
  • nick helpap
    nick helpap Oct 07, 2008
    bad relay fireing wint fire up
  • nick helpap
    also is clock set on this ? if it aint that will do weird dumb stuff ok
  • nick helpap
    try slaming the door shut once then does it start then
  • nick helpap
    maby lift on it wiggle up down see if starts then it would be bad alinment
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
The microwave timer is counting down but it is not turning on to warm up my food?
you have a bad magnitron tube,it would be cheaper to change out the unit.you can buy a g.e. jvm1540 for around 240 dollars.
Jun 05, 2011 | Ovens
I need fr my microwave Lg model 2341br user manual plus recipe
I have uploaded a copy of the complete manual with recipes to Rapidshare for you to download:
http://rapidshare.com/files/447032725/LG_MG-2341BR.PDF
To download the file:
1. Click on the link above - the download page will open in a new window
2. Scroll to bottom right-hand corner of the download page and click "Slow Download".
3. Wait for timer to count down to ZERO. (usually, about 30 seconds)
4. When timer reaches zero, click "Download now!".
5. Save the file (LG_MG-2341BR.PDF) to your PC
Please let me know if you have any difficulty downloading the manual or need further assistance.
Regards,
BElectric
Feb 09, 2011 | Ovens
Unit stopped working. no microwave or turn table movement, but timer counts down. Any thoughts?
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 23, 2010 | Frigidaire Ovens
Model # 318279502C Serial # 7G80904510 Display on microwave work, you can set cook time and power but when you enter start, the timer counts down like it is suppose to but microwave never comes on
I had the same problem and it was a relay switch on the inside panel behind the keyboard. There are 3 relays on the plastic panel and one had a slightly melted plastic portion. The technician tested each relay with a meter and they all had voltage but when he took the panel off and looked at them, one was bad. The relay costs about $4 but the service charge was the expense.
Dec 03, 2010 | Kenmore Ovens
There is no heat coming from the microwave part of the oven, although the grill, convection oven, motor, light and fan all work. The 8 amp fuse on the board where the mains cable enters the oven has blown....
Hello, If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.the magnetron i guess is kind of faulty and this is the most expensive part in a microwave oven.
If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
wish yo good luck,
take care.
Jul 19, 2010 | Ovens
Microwave oven stopped working
This is most common in over the range microwaves. Cooking grease migrates into the door switches, resulting in the symptoms you list. Replace the door primary and secondary interlock switches and you should be cooking again. NOTE: be careful not to touch other wires! Even with the unit disconnected from power, if you happen to have a bad bleeder resister in the high voltage capacitor you can still get a nasty zap !
Aug 27, 2008 | Ovens
Whirlpool super capacity 465 timer won't beep
clock timer and motot for a black electric oven 220Volt. oven number on plate at bottom of door is these two RGE 1600 P 5.8 and MK 93877451 4.4
rge
Jan 12, 2008 | Whirlpool GBS307PR Electric Single Oven
No heat or rotate
did you check the door switches?
Aug 18, 2007 | GE JKP85 Electric Double Oven
Frigidare GLEB30M9EC STAINLESS STEEL Electric Double Oven Logo
91 people viewed this question
Top Frigidare Ovens Experts
Dan Webster
Dan Webster
Are you a Frigidare Oven Expert? Answer questions, earn points and help others
