I recently bought a s2 pro, and it was working fine for a couple of days, but then all of sudden every time i took a photo a few seconds later the LCd screen would say "write error", i emailed the shop i bought it from and they said to format the card, done that and still doesn't work. Any suggestions?
It could be a faulty memory card. Or maybe dirty contacts on the card itself. Try swapping cards with a friend or your local camera shop and see if it works then. Maked sure the card is correctly inserted too.
If the card formatted in the camera it should be OK. If it was corrupt it would show up during format. I hope you didn't buy the card off Ebay through an Asian or Chinese dealer. They are conning people with half a gbyte card marked as one gbyte. Some of them are reworked so they show the full Gbyte but when you go to format them they crash when you try to use them.
Anyway it should be under warranty so ask for an exchange or even a different brand.
the white focus light has stopped working on my fuji finepix s2 pro? do i need to replace a bulb? if...
(More)
the white focus light has stopped working on my fuji finepix s2 pro? do i need to replace a bulb? if so how?
Fuji finepix S2 will not power up at all I now have 2 S2's and an S1 with the same problem. I have...
(More)
Fuji finepix S2 will not power up at all I now have 2 S2's and an S1 with the same problem. I have changed the batteries and done the usual things but nothing at all
I have a Fuji S2 camera that will not record media to CF card. the numbers do NOT advance on the...
(More)
I have a Fuji S2 camera that will not record media to CF card. the numbers do NOT advance on the camera at all.
The hinge where the lithium cr123A batteries go is broken on my Fuji S2. It won't lock shut. I need...
(More)
The hinge where the lithium cr123A batteries go is broken on my Fuji S2. It won't lock shut. I need new parts. Where can I order a new hinge, or do I have to send this in somewhere?
My camera apperas to be working correctly but will not display pre or postview images on the LCD...
(More)
My camera apperas to be working correctly but will not display pre or postview images on the LCD screen and when I play any images taken they are totally black (as if the picture was taken with the lens cover on!)
