Question about Mitsubishi Televison & Video
I have a mitsubishi dlp tv model 52525 and I just changed the lamp and the lamp light still comes on and stays red. lamp comes on for about 5 seconds and quits. is there a code on the remote to hard reset the tv
  • Anonymous Mar 24, 2014
    mitsubishi TV model WD65732: Replaced DLP lamp twice..TV comes on then switches off with Lamp red light flashing. If I unplug TV for 5 minutes and plug it back in, then on lamp flashes goes off. Then if I switch on the TV via remote comes on OK. Real pain to keep plug on and off before start up of TV to work normally. Please help
    Genius:
  • 1,030 Answers
These set have a known problem with some blown capacitors in the power supply from the syptoms you describe this could be the issue. i know of no reset command that would help
Posted on Oct 07, 2008
Where can i get a color wheel replacement for my DLP Mitsubishi WD-52525 210719 TV? I have changed the lamp and still the TV goes to black and the status light goes on.
This DLP tv model don't have a colors wheel.U hear alot of clickings sound,when power turn on?The Ballast board it dead.This board,job to help projection lamp to ignite.Tries websites like Partstore.com,Ebay.com to buy the Ballast board for the replacement.
Oct 21, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Video went blank
It may be. I have replaced the lamp in my sony 3 times. Look for dlp lamps online and enter in your tv model. There are instructions online on how to change it yourself. They also show you in your manual. The power light should blink red indicating bulb failure. Read your manual. Hope that helps
Apr 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Tv stays on for about 3 minutes the shuts off
If it is Mitsubishi WD-52525 DLP TV then it sounds weak lamp problem in TV and TV needs lamp replacement.
How old is this TV and did you replaced lamp recently?
Lamp replacement is written in user manual of TV and it is easy work.
Please buy Mitsubishi original lamp for TV safety.
Thanks.
Oct 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Wierd sounds coming from fan
If it is a grinding sound, or a sound you might consider painful to listen to for more than say, five seconds--it's your color wheel.
The color wheel in most MITS DLPs can be replaced on its own. However, in some cases, you need to replace the whole Light Engine.
Expect to pay $400+ for the Light Engine and $250+ in labor for someone to install it.
May 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 52525 dlp capacitor problem red light after lamp chang
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi DLP - model #WD62725
you have mention that after 10-15 seconds T.V starts up, will you give total description of the T.V within that 10-15 seconds?
Aug 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD52525 DLP TV
Yes, this can happen and there also are fuses that needs to be changed(F9A09) and caps C9A37,38
Mar 11, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi dlp does not get picture
the plug the connects underneath is not connecting right you have to get at the plug and seat it correctly
Dec 08, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
