Television speakers speakers is off and can't turn the on
  • Anonymous Oct 07, 2008
    No one knows the solution? What the ****?
No one has a solution? What the ****?
Posted on Oct 07, 2008
I was watchin Tv and the sound just went out. If I turn the tv up all the way I can here a humming noise...
Sounds like the speakers are blown.
Your only choice now is to connect external speakers to the TV or to purchase a new television. The speakers built into TVs are generally low quality 10 Watt speakers, it is always recommended to connect external speakers to a flat panel television.
Mar 11, 2011 | Televison & Video
No audio,tried menu items and selections,nothing.The sound just went out,what do you think it might be?
There is no sound or low volume coming from the television speakers.
Solution Follow this procedure to troubleshoot when there is no sound or low volume coming from the television.
NOTE: Because each of these steps represents a possible solution to this issue, check the television status after completing each step.
Increase the volume of the television. Ensure the television audio has not been muted. Ensure no headphones are not connected to the television. If using a set-top box with a volume control, increase the volume of the set-top box.
NOTE: If the set-top box is connected using an Audio/Video (A/V) connection, ensure that the A/V cables are connected securely to the appropriate video input on the television.
Verify that the MTS settings of the television are set to MAIN or STEREO .
NOTE: If the source device is not set to stereo or is not capable of transmitting a stereo signal, sound may come from one speaker on the TV only, and the volume will sound low. In this case, adjust or replace the source device.
If the TV has a Simulated effect in the audio menu, turn it off . Ensure the televisions speakers are not set as the center speaker.
NOTE: Some televisions allow the televisions speakers to act as the center channel speaker when using a multi-channel receiver.
Verify that the speakers are set to ON in the television menu.
IMPORTANT: If the television has audio output jacks and they are connected to a stereo system, then the speakers on the television may be turned off. Some televisions require the internal speakers or the center speaker setting to be off before audio can be sent out to a stereo receiver via the audio out jacks.
Ensure all audio and video cable connections are properly connected to the television.
Test the television using another source like a VCR, DVD player or Blu-ray Discâ„¢ (BD) player.
Reset the television to the original factory settings. To reset your TV to factory settings, turn the TV ON. Then, while pressing the UP ARROW button on the Remote Control, press the POWER button on the TV. The TV will turn itself OFF then back ON.
NOTE: If your remote control does not have a RESET button or the procedure did not reset the TV to the factory default settings, perform a power reset.
If the issue is still unresolved after completing all the troubleshooting steps suggested, service may be required.
Jan 30, 2011 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Can not get my surround sound system to work with Sharp LC-40F22E using usual audio cable, sound still comes through the tv speakers and can not find how to turn tv speakers of or tell the tv to use...
The way to turn off the tv speakers is to press the menu button scroll to the option category navigate to output select and choose variable. However just turning off the tv speakers will not cause the surround sound system to work with this television. Connecting the red and white composite audio cables to the television's OUTPUT will get you stereo sound. Some people opt to keep the tv's speakers turned on when doing this. In order to get the digital optical out to work between the television and the surround sound system you will have to be using input tv. You will have to be using the television's tuner with digital cable no cable box or with an over the air antenna. Did you make sure you connected the red and white cable to the surround sound aux or any composite input and choose the right function on it?
Dec 03, 2010 | Sharp Televison & Video
Hitachi projection 51F59. When I turn the TV on there is no sound from the speakers, but I have sound from the remote headphones.
make sure that the interal speakers are turned on in the menu of the TV, some also have a switch on the back for internal speakers on/off
Aug 30, 2010 | Hitachi 51F59 51" HDTV Projection...
Want to install exterior speakers
Go to menu, use ch. keys and click audio, use vol. keys to go to sub-menu, when sub-menu appears, use ch. key and click down to the tv speakers under heading "speakers", turn them "off". On left side in the back are the audio plugins, the top two under the s-video plugin, red on top, white next down are the two audio speakers rca jacks. Plug your external speakers, like the ones that you'd buy for a computer, in those two. The manual does not say if you plug speakers in these jacks the tv's builtin speakers will be cut off, but this tv I got was being used for a computer monitor and the tv's speakers were turned off from the menu, so I guess plugging in external speakers does not turn off the tv's speakers and would interfer with the external speakers. I suppose you could try it both ways and see, leave the tv's speakers "on" and plug in externals and see if they are turned off automatically.
Jun 04, 2010 | Westinghouse LTV-19w6 Television
Turn the speakers to ON
No I am not using a hdmi input. This problem exists within the unit itself. I am unable to manually turn on the Televisions internal speakers. they are currently set to off and are not highlighted within the menu to be able to turn them back on. I hope this helps. thank you!
Nov 17, 2008 | Mitsubishi WS-65909 65" Rear Projection...
Need to turn external speakers on (ilo tv)
What is the model of the DVD player and the Television.
Nov 12, 2008 | iLO Televison & Video
Turning on Internal TV Speakers
either your model tv ,doesnt have that option,,or its on the back,,check the rear of the tv,,good luck
Oct 01, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Vizio Speaker Making a Buzzing Noise
My 32" vizio I bought a week ago does the same things.
Buy an external sound system for the tv. Turn the speakers off in the TV menu. Hook the sound system up to the out speaker hookups on the tv.
You will not only have better found, you will fix the speaker buzz problem.
Feb 19, 2008 | Vizio L32 32 in. LCD HDTV
I have picture but no sound
go into the audio menue to turn speakers back on
Dec 27, 2007 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
371 people viewed this question
Top Televison & Video Experts
Electro Med Services...
