Question about Mitsubishi Televison & Video
Images are surrounded in yellow and blue with text duplicated below text in blue. Model VS-45609 45" purchased in 6/2001.
Purchased new TV.
Posted on Oct 07, 2008
Our e-Studio 45 printer is printing duplicate text / images. Looking at the print out, it looks like a duplicate of what is being printed slightly below the original text or image. Looks like a ghost layer...
Some printers have a maintenance option to clean it. May need to manual clean the drum or rollers but follow the instructions or could damage components. Might need to check drivers are up to date. Are you using a different type of paper? Is the paper feeding correctly? Are the rollers catching/sticky? Is the toner/Ink old or almost out?
Jan 06, 2015 | Toshiba e-Studio 45 Black and White Copier
I can not get my surround sound to work with my sony bravia HBD-E570 blue ray, while watching dish
I use HDMI cables for my blue ray DVD player, not sure if you do. If so, make sure surround sound is connected to your TV in the right jack. My surround system is old, so only uses RCA's (red, white, yellow). I plug mine into the audio out jacks (red, white) just below the HDMI 1 jack. Only the red and white are required for sound but also can use video (yellow) for higher quality. That is the main audio out. Plug into that and you should have all sound that is on your TV also sent to your surround system.
Aug 02, 2013 | Sony Bravia Kdl 46Ex700 46 in. TV
Red filter on images
replace the color image units with OEM cartridges
Apr 29, 2012 | Konica Minolta magicolor 2300DL Laser...
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I have a VS-55609, after an hour of watching, there are blue and yellow shadows on the images
This may be loose solder if it occurs after a few hours. Otherwise if its permanent its the convergnce modules.
Apr 25, 2011 | Mitsubishi VS-55609 55" Rear Projection...
Green, yellow and blue images are not converging.
Try adjusting the convergence. If it won't move see below- (or hitting Magic Focus for some Hitachi’s)
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail between
charge http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 25, 2009 | Hitachi 50UX57B 50" Rear Projection...
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Blue and yellow shadows on tv
DID YOU CHANGE THE OIL? OBVIOUSLY MY RESPONSE IS A JOKE!!! DO YOU THINK THAT YOUR TROUBLE IS POSTED IN THE WRONG LOCATION.
Feb 28, 2009 | 1991 Ford Econoline
WS-55809 - Video pinched in center, distorted, yellow/blue/red glow
This doesn't sound like a programming issue. I had a very similar problem about 6 months ago and I fixed problem. I had cold solder joint on the video power board. It was the board in the middle. The power supply was to the right. The video board had a driver with a bunch of legs. About 7 solder joint where cold or loose. I solder the board and my mitsu wide screen was fixed. Hope this helps.
Andy
Aug 22, 2006 | Mitsubishi WS-55809 55" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
