Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
Audio Problem Hi Bought this Westinhouse digital TV picture is great but having problems with sound the voices are clipped any suggestion s ? JH
Westinghouse 42" tv no sound
Posted on Jul 18, 2008
    Champion:
  • 217 Answers
Probably on the main board, most people use an external source for sound, tv does have a problem
Posted on Feb 18, 2007
SOURCE:
Trying to connect pc with hdmi cable have great picture no sound on TV Used HDMI imput 7 tried imput 6 with hdmi and audio imput from PCF to TV still picture and no sound any suggestions
Hi Scott,
On your PC, you'll need to go into the Control Panel --> Hardware & Sound --> Sound (Windows 7) and click on "Playback". Here, you'll need to change the sound settings to reflect the audio to be handled by the video card / audio chipset / HDMI jack on the motherboard. You should also check for other settings such as Digital Output that are usually associated with and HDMI jack on the card and not an analog jack.
As it is now (or is likely to be the case anyway) the picture is being handled by the HDMI on the video card / motherboard; but the audio is still coming from the the speaker jack(s) on the motherboard or audio card. Making the changes above will redirect the audio from the speaker jack(s) to the HDMI jack instead.
Mar 27, 2015 | Sharp 52"" aquos lc-52sb55u 1080p...
Hello. I am J.H. Jansen, MD Radiologist from the Netherlands. Today i bought Canopus ADVC mini serial number EBC-109151. Bad product. During capturing (on Imac with Leopard but also on Macbook Pro...
Hello J.H. ,
This not a surprise . You just waisted your money .You need top quality material both sides to successfully capture analog/digital programs . A PCI or VGA internal card will do better but you also need a super powerfull pc to obtain satisfactory results , like a I7 intel model with great amount of DDR3 RAM .
I myself experienced that the best results are obtained with a stand alone DVD/Blu-Ray recorder , preferably with an internal HDD . This is really the best way , believe me .
Best regards,
fanaudi
Mar 16, 2011 | Canopus grassvalley ADVCmini...
Unable to listen to tv through the surround system
Your BEST TV-related audio would be brought in directly from each external source you watch, NOT the TV itself (if TV's were hi-fi we wouldn't need audip equipment), so, yes, digital audio is the ONLY way to go. Having plenty of connections on the TV is NOT going to give you HI-FI multichannel audio from all of them.
Jul 08, 2010 | Panasonic SCBT230 Theater System
I'm getting a great picture with my converter box, but no sound.
This may sound like a rediculous thing to ask you to do, but I've seen these types of things happen.
With the antenna to the box and the box to the antenna port on the TV setup, go into the TV menu - audio section and make sure that the speaker is set to 'ON'. Also, make sure that 'SAP' mode is not on.
Try plugging headphones in the headphone jack and see if you get audio there.
You should also check the instructions for your digital box to see if there is any audio modes that may need adjusting.
Sep 12, 2009 | Sony Televison & Video
I cant get my samsung home cinema system to play through my t.v
I bought the optical audio cable ($15 WalMart) and use the Digital In on the DVD player to play the sound through the surround system and turned the TV speakers off. Works great! The optial audio has square ends and looks transparent with just one round shaped cable that goes from the TV to the back of the DVD player.
Jan 01, 2009 | Samsung HT-X40 System
Audio device problem
hi.. sir
please follow the step's
1. start
2. control panel
3. sound and audio devices
4. voice
5 test hardware
6. follow the step next ..
itwork's is ur audio device is correct.
thank u
sir don't forget to rate it..
Sep 04, 2008 | IBM ThinkPad R52 Notebook
Optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650, everyone suggested adjusting the delay time on my AV amp but unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then turn the TV back on again. This will get you into the secret Service Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for the internal speakers of 100ms but for some reason this is not set for the external output so all you need do is dial in a 100ms delay there and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other standard menu settings are lost and the screen will be set to dynamic for some reason so you have to go through and change everything back after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
Feb 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Not getting sorround sound from my tv
only the hd channels get great surround sound. if your tv has an optical audio out and your surround has the optical in input. then i suggest buying a fiber optic wire for the audio you'll hear a big differance. just hope that the audio stays in sync unlike my cheap *** koss system
Dec 10, 2007 | Samsung HTP-1200 System
Thm505 no sound
IF YOU BOUGHT A REGULAR S-VIDEO CABLE THAT IS THE PROBLEM LOOK RIGHT BUT IS NOT NEED SPECIAL AUDIO CABLE
Nov 06, 2007 | JVC TH-M505 System
Sound card driver problem
If you are using xp
Go to control panel
Click on sounds and audio devices
click on voice
See voice playback?
click on volume make sure there is not a check mark in mute under microphone
Do the same for voice recording
and check the volume levels on both
Hope this helps
Oct 20, 2007 | Computers & Internet
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
304 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
