Question about Whirlpool Dryers
Clothes take a really long time to dry. seems like the machine gets the clothes warm buit "maybe" isn't blowing ?
  • 5,911 Answers
A great many heat related problems with dryers are attributed to poor ventilation. The following link explains:
http://www.fixya.com/support/r385301-thorough_dryer_advice
Pay particular attention to the paragraph that discusses your dryer ducting. Cleaning the lint trap often is not enough to keep accumulations of lint from building up inside your dryer air blower housing and/or associated exhause ventilation. Use the advice I've given on how to quickly determine if you have a blockage internal to your dryer or external. Vent lines that run through an attic or under a crawl space are the worst, because they create resistance for the blower motor to work against. With an attic line, you have gravity working against you, because the blower has to force the air upward and out. In a crawl space, you have sags in the line working against you that create choke points for lint to accumulate. Also, it is recommended that you leave the dryer about a foot away from the wall so that you do not crush the vent hose. Make sure you use the semi-rigid metal type of ducting because it resists crushing, rodent infestation and is heat resistant.
The reason I'm pinging on your ventilation is because you stated that the dryer is getting warm. This indicates to me that the heating circuits are trying to work. If the dryer is left in its current state, however, the heating circuits will actually overheat to the point of failure. Before assuming you have a failed component, I would recommend a little maintenance on the dryer interior and vent lines just to be sure. I hope this helps you. Let me know if you require additional assistance.
Posted on Oct 07, 2008
Kenmore Gas Dryer does not dry clothes.
If this is the electric version then after 15 years you probably need a new heating element, they are not difficult to install and are not terribly expensive as a DIY project.
Jan 12, 2013 | Dryers
Electric dryer heats up and blows air but doesnt dry my clothes
I would check to see that the lint/filter isn't completely clogged up. This could make the dryer warm without allowing it to do its job of drying the clothes.
Also, is the drum spinning? If not, it could be indicative of other problems.
Nov 13, 2012 | Dryers
The dryer works fine in TimeDry mode, but in Intellidry mode it dries very slowly. The "Moisture Moniture" indicator lights start and stay at "Less Dry". I have replaced the moisture...
you could have bad gas coils.if the timer doesn't advance in auto dry most likely you're having heat problems,when the dryer heats and then the heat shuts off then the timer will advance,when the heat comes back on the timer stops,it does this until the clothes are dry.gas coils when starting to fail will work normally until they get hot and then no heat until the coils cool down then they will work again,on time dry the timer just keeps counting down until the time runs out no matter what's happening to the dryer.i've seen the coils fail after the first 10 minutes and other times for 20 to 30 minutes but usually if the load is big and in time dry the clothes will feel warm and you'll need to dry them a second time to get them fully dry,also while you're in ther you should clean out the dryer at least once a year,clean out the duct that the lint filter slides into,vacuum out the cabinet where the motor is and blow out the vent line,if it's a long run i use a leaf blower to blow out the line,remove it from the back of the dryer,stick the leaf blower into the vent line and blow it out,i've blown out birds nest out of some lines, your clothes will dry on time,you won't go through so many parts and you won't have to worry about a dryer fire,the gas coils are on top of the gas valve,remove the two phillips screws,lift off the cover and change out the coils.next time you use the dryer keep an eye on it,after it runs for 20 minutws start checking it,you'll hear a click,then another click and the flame will lite,look into the gas tube and if the flame isn't liting then you have bad gas coils.
Sep 10, 2011 | Maytag MDG7600AW Gas Dryer
CLOTHES WONT DRY. IT GETS REALLY HOT INSIDE. THEY SEEM WETTER AFTER IT RUNS FOR AWHILE. TAKES PROLLY 3 HRS TO DRY.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
May 22, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
Not drying clothes still getting warm and turning but despite leaving it for hours the clothes never become dry just warm and damp
sounds like your clothes are not spun dry enough try spinning on maximum speed alternatively check your water pump is not partially blocked maybe you need to clean filter let me know how you went
Nov 12, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore dryer hot, but doesn't dry clothes...also spueaks
Sam,
A dryer function is really simple:
Gets hot, boils left over moisture from clothes and it needs to blow it out.
If it is getting hot and it is turning - Then your problem is in the exhaust system.
Check all pipes that carry moisture/steam/vapor out of your machine and make sure is free of any restrictions.
Good Luck
Aug 18, 2009 | Roper RES7646KQ Electric Dryer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
