Question about Canon PowerShot S1 IS Digital Camera
Going through batteries abnormally quickly
This is a used Canon PowerShot S1 IS. A couple weeks ago it started going through batteries abnormally quickly. A set of rechargeable AA batteries that used to last 800-1000 shots now last 15-20 shots. When I put those same batteries in a different camera, they lasted for 750 more shots. There's obvisouly something wrong somewhere inside the camera, but I don't know how to fix it.
  • 3 more comments
  • jhaakri Nov 01, 2007
    same problem here
  • Anonymous Dec 04, 2007
    exactly the same problem
  • dogfather17 Sep 04, 2008
    I have the exact same problem with my S1 IS. I put brand new AA batteries which works fine for the first shots then i turn it off. The next day i turn it on only to see the red battery symbol flashing in the LCD screen. Frustrating. I thought it was my rechargable batteries but it does the same thing with non-rechargables.
    Is it worth changing the flash capacitor ? If so where is it located and where can i order/get a new one ?
    Thanks i'm desperate.
  • siempresenna Sep 14, 2008
    Same camera type, same problem.
  • MJBH Aug 15, 2013
    sigh.............same problem here...........wt???
    Problem Solver:
  • 13 Answers
Hi. I had the same problem with my Canon S1 IS. In my case the problem was caused by flash capacitor. To check if it is the case just follow the following procedure. 1. Turn on the camera. 2. Be sure that low battery warning is flashing on LCD. 3. Turn off the flash by pressing flash button (be sure that flash is OFF but not in AUTO regime). 4. Turn off the camera. 5. Open and close the battery door. 6. Turn on the camera. 7. Take several pictures.
If after these operations the low battery warning does not show up it means that flash capacitor causes the problem and it should be replaced. Or you still can make pictures with your camera without using a flash.
Posted on Jun 19, 2008
Hi. I bought a used A70 that had that problem. I disassembled the outer body panels and found that a base panel assembly screw was too long, and was touching the LCD's ground cable, at the cable's tip. I changed the screw for a shorter one and it was settled. It never happened again.
Posted on Nov 19, 2007
I'm using a Canon PowerShot A570IS, and am getting only 20 to 30 photos from fully charged Sanyo AA HR6 2000mAh batteries. I'm using the Sanyo Ni-MH quick charger that was sold along with the...
Unfortunately, this is not unusual with rechargeable batteries. The best thing you can do with a rechargeable battery is to fully and completely discharge it, and then recharge it fully. After that, there's nothing else you can do except buy a new battery. You can get brand new, unbranded ones on eBay for a fraction of branded ones, and they work great. Just buy from a seller with a good reputation, and you can't lose. I usually buy multiples and never run out of battery power this way.
Feb 18, 2011 | Canon PowerShot A570 IS Digital Camera
The only problem with the camera is that i have to change the batteries every 10 minutes is there a way to fix it?
Because of the power drain due to the functions you use and the resolution of your pictures, alkaline batteries in digital cameras will drain fairly quickly. The best bet is to get some high capacity rechargeable NiMH AA batteries (at least 2500MAH). This should give you the photo taking life your want.
I would get at least 6 rechargeables (the 15-minute rechargeables) so that you have a couple of changes available and you can quickly recharge them.
Let me know if you have any other questions.
Please rate this solution. Thanks.
Oct 18, 2010 | Canon PowerShot A530 Digital Camera
I have had two digital cameras (the first an Ixus - the present a Powershot). After a couple of years the Ixus wore out batteries in 5 minutes - and buying new ones did not help. Now the same thing is...
Rechargeable batteries lose performance when they get older. A three year lifespan is not unusual. Note that your camera does not use "normal" AA batteries. It should be using rechargeable NiMH or disposable lithium AA's only, although alkaline (e.g. regular Duracell) can be used but will run flat very quickly. Anything else will either run flat far too quickly or will provide a false battery charge level indication.
Oct 06, 2010 | Canon Cameras
Can I use rechargeable batteries?
If it requires AA or AAA,yes you can use rechargables,or I guess any type battery which is made rechargable.They seem to last a little longer too.I am so disappointed how fast my digital camera eats batteries that I am trying to sell it and repair my SLR.
Good luck! Greg
Aug 12, 2010 | Canon PowerShot S1 IS Digital Camera
Battery always going dead use 4 regular lithium batteries
in this camera and most of fuji AA batteries, the batteries keeps draining even with the machine off .
if the camera is not on use REMOVE the battries.
i will recommend regular recghargable batteries with at least 2700 Mah type NiMH.
you can recharge them several times and they will last almost as those lithium batteries on that model. plus they will be cheaper
Oct 08, 2009 | Canon PowerShot S1 IS Digital Camera
Powershot SX100is battery life
hey, i had same problem.. after i started using energizer ultimate lithium AA it started lasting weeks
Jun 16, 2009 | Canon PowerShot SX100 IS Digital Camera
Losing power rapidly...
The only thing I can suggest is that the metal connections on your camera have corroded due to the long life of your camera. I had a similar problem where any batteries I used would not work, regardless of what kind of battery it was. Turns out I had a nice greenish layer of corrosion on my connections which I sand-papered off. This might be a little tricky if your connectors are way inside of a battery holder, but it can be done nonetheless. Try taping some sandpaper to the flat end of a pencil and clean it out that way. Hope it works.
Jun 25, 2007 | Canon PowerShot S1 IS Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
296 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
