Question about Dell AS500 Sound Bar Computer Speakers
Where do I plug the speaker in?
I see the wire of of the sound bar. Where do I plug it in? It is real short so do I need sometime of other cable to plug it in?
Thanks!
Jeff
  • 4 more comments
  • david250503 Oct 19, 2008
    I have the same problem Where do I plug that very short wire into?
  • fozzysoma Feb 09, 2009
    My speaker quit working. I see the short wire with a round plug but no place to plug it into the monitor. The other wire plugs into the CPU. The green light on the bar will not come on so I'm thinking this other wire supplies power to the speaker bar. But where do I plug it in?
    Thanks
    Donna
  • Anonymous Feb 20, 2009
    I have the same problem. The Sound Bar has a short wire coming out of it and I think its meant to power the Sound Bar. I dont know where to plug that short wire in order to get power to the Sound Bar.
  • macazani_87 Feb 20, 2009
    Both the answers dont help me! I still need to know if i have to buy another cable for the power outlet?! Or am I just suppose to plug the shorter cable into something (even though it doesn't reach anywhere do to being so short!!)
  • Anonymous Feb 21, 2009
    where do i plug this short wire to do i need to purchase a power cord to lug into this short plug coming out of the back of the moniter
  • acox Apr 13, 2009
    My speakers do not work. There is a short cord that I am assuming is the power cord but I don't see any place in monitor to plug it in.
    This speaker is also sold with a PA - do I need to purchase one of those or am I missing the spot onthe monitor where it plugs in.
    It is a 20" Dell monitor.
    Genius:
  • 1,124 Answers
Please be more specific - Usually on the back of any computer you have 3 outlets at your sound card:
one is for "mic" (pink)
one is for "speaker" (green)
one is for "line in" (blue)
Posted on Oct 07, 2008
    Problem Solver:
  • 14 Answers
The short power cable is meant to plug into the back of a dell lcd monitor that supports it. i have the dell ultrasharp 1905fp which has the power jack in the monitor itself. or you can buy the power adapter on ebay it is rated at 12volt 1000ma. just search for as500 sound bar.
Posted on Apr 24, 2009
Sounds like you are talking about the power connector have you got two wires one with a light green din this pugs into your sound card then you have to power the speakers with the other cable.
Posted on Jan 28, 2009
Just purchased a Panasonic sound bar and Samsung tv. The sound bar is hissing at low vol from one end. Should I return to the shop or is there a setting issue?
I would check your cable connections. If you are using an analog Red & White connection flip the red and white connections and see if the hissing sound changes to the other end of the sound bar. If it does then try new cables.
If you are using a 3.5 mm Stereo headphone plug then try a new cable and see if the hissing vanishes.
If the hissing doesn't change then take the soundbar back it is likely a defect in the internal wiring., either bad grounding or a short in the wiring.
Jan 14, 2017 | Samsung Televison & Video
1988 klf300 bayou no spark, installed a new cdi voltage regulator,stator,and coil ran for four days and now no spark. what do you think is wrong.
Hi, Jeff sounds like you have a faulty wire connection somewhere otherwise the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting, leaking, spark plug cable connections loose check for spark leakage in the dark.
6. Faulty ignition coil or electronic control module.
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Another no spark bayou any help left out there
Kawasaki Bayou 300 spark problems
https://www.tradebit.com/usr/valuablemanuals/pub/9003/1986-2006KawasakiKlf300Bayoufree.pdf
OEM Parts for Kawasaki
1988 Kawasaki Bayou 185 Owner Manual
Jan 14, 2017 | Motorcycles
Problems with 1996 dodge grand caravan keeps dying replaced computer sensor alternator spark plugs wires serpentine belt fuel pump coils
FUEL FILTER,,IF IT IS OLD-REPLACE!
FUEL PUMP NOT REALLY SUSPECT.....BUT POSSIBLE AS IN A THERMAL SHORTING (AFTER A SHORT TIME)
YOU HAVE TO DETERMINE WHETHER THIS DELAYED STALL ISSUE, IS COMING FROM A FUEL OR ELECTRICAL MALFUNCTION. IE: ELECTRIC CUT OUT...SUDDEN LOSS OF POWER...FUEL ISSUES: ROUGH RU..THEN SHUTS DOWNNING, BUCKING & SURGING
IF YOUR NOT FIXED...JEFF AT: JLGPROP@!YAHOO.COM THE WORX GROUP L.L.C.
Jul 02, 2014 | 1996 Dodge Grand Caravan
2000 Kawasaki VN 1500 Vulcan keeps blowing ignition fuse
Hi, Jeff before diagnosing your blown fuse issue check the bottom of your seat if its metal and comes in close proximity to the positive battery post you need to take the necessary steps to ensure there is no contact (electrical tape, thick rubber insulation, hammer a dent in the seat bottom etc.) You are going to need a wiring diagram from your service manual, a test light, an ohmmeter and plenty of extra fuses also you need to fix your stator plug first before proceeding.
If you turn on your ignition switch and immediately blow a fuse you have a hard/dead short and is usually easy to find. With a test light connected to the hot side of the blown fuse holder start stabbing the wire/s that leads away from the fuse holder and towards the ignition switch, you test light will illuminate validating the short. When the test light fails to illuminate you have passed the short and need to back up until the test light illuminates, then look in the immediate area for the short.
If you driving down the road for 30 minutes or 15 miles and blow a fuse you have soft/flying short and may take some time and patience to find.
If the main fuse/circuit breaker constantly blows/trips while riding you probably have a faulty battery terminal connection. Check battery terminals for damage or corrosion, check battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary. Any other fuses that constantly keep blowing while riding are usually caused by a loose or corroded ground wire in the circuit, which means you have to check, inspect, test each and everyone with and ohm meter set on a low ohm scale 100 ohms or less . Simply touch one lead to the ground source and the other lead to the battery negative terminal, a reading of zero indicates a clean solid ground. Any number reading or infinity indicates a poor ground and needs to be repaired. Poor or weak grounds require excessive additional amperage to complete the circuit which in turn blows the small amperage fuse.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Ignition fuse keeps blowing
VN1500 keeps on blowing fuse
Kawasaki VN1500 Service Manual
2000 Kawasaki Vulcan 1500 Classic Fi Owner Manual
Jun 03, 2017 | 2000 kawasaki VN 1500 Vulcan Classic
When you turn the car off sometime you have to raise hood move the battery wire around then it starts because at first you dont hear anything when you turn the key
sounds like a short in the wire, or possibly a broken battery terminal. take the cables off, clean the posts and cable ends real good, and inspect the terminals for leakage
Jul 25, 2011 | 1998 Ford Taurus
I need the wires to connect the surround sound. Any ideas where I might get them? And what are they called. They each have 2 wires and 2 holes to plug. thanks
almost all surround sound connectors are RCA cables. ask for any RCA cables. sometimes they come in pair or u can buy individual cables.
Apr 13, 2010 | Durabrand STS92 System
Engine revs when turning right.
Wrong size throttle cable or misadjustment. At the handlebars, I've seen some set that acceleration causes a pull of the cable, I've also seen bikes set to push the cable. Confirm this is set correctly, and that your mechanic used the correct legnth of cable.
Jul 30, 2009 | Yamaha XJ 650 Motorcycles
I have a maytag washer (model LAT9416AAE). The timer motor doesn't run. If I plug it's wires directly into an outlet, it runs fine. In the timer assembly, it apparently gets no power. Is there another...
You need a new timer assembly. Please be very care full when hard wiring your machine. it could short the machine out and also cause personal and property injury.
Jan 07, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
2002 Honda CRV Battery keeps dieing over night
first you need to make 100% sure it isnt the battery .when you park it for the night take your battery cables off and leave them off until the next day.when you go to start it put them back on and if it starts up then its probably not a battery issue.(some batteries get weak and will not hold a charge overnight). if it starts then its probably a short in your wireing.also when you put the cables back on listen for a crackling poping sounds as you putting the cables back on the battery.a good indicator thats there a short in your system.i hope this helps thanks jeff
Nov 26, 2008 | 2006 Honda CR-V
Installation of Subaru EA8 alternator
why would you need a diagram all there is a plug and a wire or two that has a washer look. that goes on the stud at the back of the alternator that uses either a 6 8 or 10 mm nut to tighten the wires up.thats it i hope this helps thanks jeff
Oct 20, 2008 | 1984 Subaru Brat
Dell AS500 Sound Bar Computer Speakers Logo
2,154 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
