Question about Fisher and Paykel 24 in. DS-603 Built-in Dishwasher
Dosen't pump all the water out
Dose'nt pump all the water out on last rinse
  • 144 Answers
Take everyting out of the inside of the drawer, you need to take out the motor rotor and check for any damage to the plastic rotors and check under the rotor for any damage to the plastic socket or plastic ridge in the socket (stator). If all is ok disconnect the drain hose and place in a bucket and check that the drawer drains ok when it first starts. if alls ok then you need a new Main Motor controller module. cheers
Posted on Mar 24, 2009
New fuel pump worked now dosen't 95 accliam
Check the condition of the fuel pump relay first and the condition of the wiring in both connectors inside and outside of tank second. Check condition of the ground wire return where it attaches to body- it may be broken or corroded. Inside of the tank as well. Also check to see if you have 12 volts at the pump- if not, check fuse and other wiring for damage.
Also check to make sure the oil pressure switch is intact and functioning correctly.
Oct 06, 2012 | 1995 Plymouth Acclaim
Dishwasher fills with water. then hums but dosen't clean
Sounds like water-level sensor is ok as it stops filling then 'hums'. I'd (carefully) check the connections to the connections between the level-sensor and the wash motor start relay. Could be motor is bad or something is causing it to become 'jammed'. Before you begin opening the appliance, I'd attempt to vacuum out the water or try putting the control in the last position to cause it to try to pump out the water.
Mar 01, 2012 | Kenmore 16372 / 16374 / 16379 Built-in...
No water flow through system, checked tip, water was on, nozzle on, checked filter. motor starts and runs fine.
The first thing you need to check is if you have the water supply hocked to the mechine with no pressure line connected just the water dose it spray out the pressure line connecter with out the engine running . If this dosen't happen the water pump is no good . You can never start any kind of mechine like this with out constant water flow . It sounds like something is broken between the engine shaft and the pump the pump is likely seized and this broke the connection between the engine and the pump. If this is the case the mechine is likely not worth the money you would have to put into it to save it
Sep 17, 2011 | Honda Garden
Iv'e purchased a 5 cup homemaker rice cooker but your leaflet dosen't explain how much rice or water ratio
I am sure that there is some official rice water ratio, but my method works for me.
1. Rinse the rice until no more "white" comes off of it and the water runs clear.
2. Let sit for one hour in water.
3. Drain water.
4. Add water to 1" over the top of rice and start in cooker.
5. Add 1 cup of water per day until rice is used up.
Jun 25, 2011 | Microwave Ovens
The washer will not drain water during the rinse and spin cycle
The pump is not switched on during the cycle and this circuit must be traced from the timer output. However if the drain works well in the last cycle then the pump is alright. Hence the pump circuit switch during the rinse and spin has to be traced and confirmed. Good day
Aug 12, 2010 | GE Washing Machines
It dose not go to spin
Hi just read your posting.Now just a couple of questions.Does your machine drain the water If it does not drain the water remove most of the water by hand so you can tip the machine back so you can look underneath .Now you will see a pump to the front right of the machine.It will have a red or black fan attached to it.Turn the fan a few times to loosen the pump if it is tight .If it loosens when you turn the fan put it back on its feet and select a spin cycle and push the start button.Hopefully it starts to drain.If it drains it should spin. Please reply with additional information or if it starts to drain.Good luck.
Jun 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
Engine oil metter dosen moves when touareg is
Not a good thing. Could be a bad oil pump, does the engine sound normal? I'd have a mechanic check it out.
Feb 07, 2010 | 2004 Volkswagen Touareg
Dishwasher not cleaning/rinsing properly
try connect a water filter (carbon and particle), and connect the machine on output filter, mormaly resolve this problem. Some old houses has water supplie problems, as dirty water, and contamined problems, check for water purity.
Jan 14, 2010 | Dishwashers
Maytag washer will not rinse on the white cycle. is it the timer?
you must know that because it sets there and dose nothing???if so it has to do with water[its calling for it and its not coming so it keeps waiting,cant move on till sattifies the water level switch].set timer at start of load and check water setting temps .dose cold come out when set cold only also same hot.ihope thats a bit of help.God bless ,tom
Jan 04, 2009 | Whirlpool GSC9455 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Logo
140 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Gere knutson
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
