Question about HP Photosmart 2610 All-In-One InkJet Printer
Hp 2610ix all-in-one printer
The printer has just recently started this problem. You go to print(or copy) and it pulls the printer paper in like usual and then the paper slows and i get the "out of paper" error. I click ok, because it has paper, and immediately it has the "paper jam" error because the paper is already in the mechanism. then I press ok and it pushes out the paper and then it prints the page as if nothing was wrong. It seems it's reading the paper incorrectly. I've gone through all the hp troubleshooting and none if has changed a thing. (cleaning the rollers, changing paper, resetting, etc.)
  • 432 Answers
I would try reinstalling the printer software.
Posted on Jun 26, 2007
Light is flashing on Resume on my HP Deskjet F2110 All-in-One printer scanner copier. What does that means?
Regular paper, envelopes, or specialty media may get stuck or jammed in the printer. Follow the instructions below to find and remove jammed paper (or other media) from the printer. If the HP All-in-One has a paper jam, first check the rear door. If the jammed paper is not in the rear rollers, check the front door.
Step one: Check for and remove any paper stuck in the paper In tray
  1. Remove all loose paper from the paper In tray.
  2. Press the RESUME button.
    • If the paper jam is cleared, skip to Step Four
    • If the paper is still jammed, continue on to the next step below.
  • If more than one sheet is stuck in the printer, remove the paper, one sheet at a time by taking hold of a sheet in the middle of the stack and, with both hands and firm, even pressure, pull the sheet towards you. Usually, removing one or two sheets from the middle of the stack will release the pressure and the rest of the stack can be removed.
  • After removing the paper, check to make sure no scraps of paper are stuck in the printer.
    • If the paper jam is cleared, skip to Step Four.
    • If the paper is still jammed, continue on to the next section.
  • Step two: Clearing a paper jam from the back of the printer
    If the paper jam is not accessible from the In tray, follow the instructions below to clear the paper from the back of the printer.
    1. Unplug the HP All-in-One.
    2. Press in the tab on the left side of the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. Figure 1: Removing the rear door
      CAUTION:If the paper tears when removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all of the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Replace the rear door. Gently push the door forward until it snaps into place.
    3. Press Cancel to continue the current job.
    Step three: Lift the front cover and slowly remove any jammed paper
    1. Unplug the power cable.
    2. If necessary, pull the input tray down to open it. Then, lower the print cartridge door. Figure 2: Lowering the print cartridge door
      CAUTION:If the paper tears when while removing it from the rollers, check the rollers and wheels for torn pieces of paper that might be remaining inside the device. If all the pieces of paper are not removed from the HP All-in-One, more paper jams are likely to occur.
    2. Close the print cartridge door.
      Figure 3: Closing the print cartridge door
    1. Plug the power cable into the HP All-in-One.
    2. Turn the power on.
    3. Press Start Copy Black or Start Copy Color to continue the current job.
    Step four: Verify the print cartridge carriage can move freely
    2. Check to see if the print cartridge carriage can move freely from one side of the printer to the other. If the carriage is to the right and out of plain view, skip to Step Five. Do not try to force it to move if it is hung up on something. [img src="http://h10025.www1.hp.com/ewfrf-JAVA/Image/common/note.png" alt="">
      NOTE:Be careful not to force the print cartridge carriage. If the carriage is stuck, forcing it to move will damage the printer.
      • If the carriage does not move, continue with the next step below.
  • Remove the print cartridges.
  • Step five: Reload and test the printer
    Once the jammed paper is removed, verify that the printer is still functioning properly.
    1. Reload the printer with plain paper.
    2. Perform a self-test by pressing and holding the Resume button until the printer starts printing. A test page should print.
    NOTE:Do not put more than 35 sheets of plain paper in the document feeder tray.
  • Gently move the print cartridge to the far right of the printer.
  • Remove the paper from the paper In tray, but do not remove the drawer.
  • Remove the rear access door.
  • With your fingers, rotate the rollers "up" three full rotations.
  • Push the rear access door back into the printer until it snaps firmly into place.
  • Replace the print cartridges.
  • Plug the power cable into the HP All-in-One.
  • Turn the power on.
  • Step six: Service the printer
    Perform all the steps mentioned above. If the problem continues, service the printer.
    Cause Paper jams can be caused by several factors. Follow these guidelines to prevent further paper jams.
    • Insert paper into the paper tray only until it meets resistance. Do not push it farther in.
    • Make sure that the paper is flat in the paper tray and that the guide is adjusted to the width of the paper.
    • Do not add paper while the product is printing.
    • Remove printed pages frequently.
    • Do not use paper that is too thin, too slick, or that stretches.
    • Do not use torn or creased paper. Used paper might cause jams.
    • Make sure that the rear access door is securely fastened.
    Jun 17, 2011 | HP Deskjet F2210 InkJet Printer
    I only get a black sheet of paper if I copy with my hp 1610
    you will need to download the driver for leopard after you remove tiger
    Aug 13, 2009 | HP PSC 1610 All-In-One InkJet Printer
    Color not printing after Ihad pulled out a jamed paper
    It sounds like I would check in the printer properties for this printer and under the "color" tab see if "print in grayscale" is checked. If you have tried multiple color print carts and still no color, it would have to be a setting issue. What if you print a test page from the printer screen it self? Go to the menu on the printer, and either select to print a self test page, or also try to copy a color document...this would help to eliminate the printer or the computer as the problem...
    Mar 10, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    HP4L Printer-While printing,paper cycles1/2the way, printer stops
    Check the paper size setting in the software and print driver. Sounds like a non-standard paper size setting.
    Feb 15, 2009 | HP LaserJet 4L Printer
    My 6318 printer will not print
    Did you take/pull the tape off of the cartridge?
    Dec 29, 2008 | HP Officejet 6310 All-In-One InkJet...
    HP photo smart 2610IX SCANNER WONT WORK AND GETTING ERROR MESASAGES THERE IS A PAPPER JAM AND THERE IS NOT
    its the problem of gear assembly which pulls the paper that needs to be replaced or the unit needs to be serviced.
    Dec 10, 2008 | Office Equipment & Supplies
    Ink Color Issues
    Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
    Sep 11, 2008 | HP Photosmart 3210 Printer
    HP Photosmart 2610 All-In-One InkJet Printer Logo
    184 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
