Question about Denon Audio Players & Recorders
FM RADIO NOT WORKING ON DENON UD-M50. IT WILL NOT PICK UP SIGNAL. AM WORKS.
ttech
  • 139 Answers
SOURCE: Radio won't work on my Denon Receiver
Hook up a Small piece of wire Coming off the #00 ohm input for ant also put it in Mono mode first and you should be able to Hear Hiss Then tune Let me Know ttech
Posted on Jul 20, 2007
  • 93 Answers
SOURCE: DENON UD M50 CD PLAYER no longer works
Maybe you accidentally break some contact(s), on display or somewhere else. If that is the problem, soldering iron should solve that. Look for any loosen wires or detached contacts.
Posted on Oct 11, 2007
  • 6 Answers
SOURCE: Denon UD-M50 cd changer. Need help extracting drawer for home repair!
Hi KathyKate
If you are still having the same problem with your denon UD-M50 I might be able to help. I have fixed a number of them in the past and have the necessary maintenance manual and knowledge of a company that can supply spare parts. Disassembly looks very complex, especially when the problem is with the carousel but once you have an understanding of the mechanism it's not that difficult. Care should be taken when manually removing and reloading the disc trays as damage can result to the 'Teeth' alongside each. Spare trays are available. All my repairs involved the removal of the carousel mechanism in order to align the trays. I can copy the relevant sections of the manual dealing with the re-alignment which is critical but again if followed exactly you should have no trouble. If you respond with an Email address, I will be only too pleased to forward you the schematics etc.
Regards Ibbotsnm
Posted on Dec 15, 2007
jusus
  • 57 Answers
SOURCE: After lightning strike, my denon
Check the wire at the back of the FM Ant. If possible replaced it or relocate the FM wire.
Good luck
Posted on Jul 28, 2008
  • 4234 Answers
SOURCE: i have an denon ud
Yes this is fixable by rebuilding the loading mechanism. As long as the mechanism is just jammed and no parts are broken, this should only cost the labor charge at a local service shop. I have done a number of these in the past and while not the simplest of mechanisms, it is fairly straightforward.
Dan
Posted on Aug 26, 2008
Instruction manual for a Denon UD-M50
This link should get you to a page where you can view/download the manual for this unit. Good Luck!
Oct 22, 2012 | Denon Ud-m5 Mini Hifi System
How do i reset my denon UD-M50?
Download the user manual to this set by net. It will have all details.
May 28, 2012 | Denon Audio Players & Recorders
CD not ejecting - Denon UD-M50
Check its loading belt. It might be broken or the gear wheel assembly have damaged gear wheels. The fault is with its loading mechanism. Sometime, replacement have to be done.
May 10, 2012 | Audio Players & Recorders
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
Sep 14, 2011 | Denon DRA-37
Denon ud-m30 Tuner problem I can tune am stations, but not fm. Receiver doesn't even receive signals from my nokia n97 transmitter 5 cm away on the known frequency. Is it possible that fm unit is out of...
I have just solved this problem with my system - it is caused by bad connections between the boards. There are multipin connectors that connect the main boards together via a small vertical board. Check that these are fully connected and you will probably solve the problem.
May 30, 2010 | Denon D-M30 CD Shelf System
Tuner not working.
These do on occasion have a bad fm tuner assembly. part number 9630145608. to verify try a fm ant to see if works
Dec 09, 2009 | Denon AVR-1908
After lightning strike, my denon ud-m5 displays "protected" when trying to play fm and doesn't work.
Good luck
Jul 28, 2008 | Denon Audio Players & Recorders
Oct 10, 2007 | Audio Players & Recorders
26 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
