Question about Garmin GPS
Garmin 396 XM weather I have a three year old GPS 396 and recently subscribed to xm weahter. Have experienced extreme difficulty getting the weather info. On a few cross-country flights exceeding two hours, it never got beyond the "acquiring data" stage. Occasionally (but not often) the data will load and weather info will display within ten minutes. Any ideas? Jim Mahoney jemahoney@sbcglobal.net
jesse_thom
  • 9 Answers
SOURCE: XM radio sounds like crap!!!
I have my XM antenna on top of the cab immediately above my head and the Garmin inside the cab near the front speaker. So that would be another option in case you don't want to or don't have the cable to put one in the back. Have experienced no problems as of yet. Sound seems fine with my arrangement.
Posted on Mar 02, 2008
SOURCE: GPS & XM
I have both a 660 and xm...no problems
Posted on May 04, 2008
Agent Ken
  • 250 Answers
SOURCE: Sirius vs. XM
Hello pdweidner,
The CN-NVD905U is fully satellite ready and is compatible with both Sirius and XM. To change services you will need to purchase and install a XM compatible tuner and antenna to replace the Sirius tuner and subscribe to XM service.
Best regards,
Ken
Go Ahead. Use Us.
Posted on May 13, 2008
sTatiC00000L
  • 8 Answers
SOURCE: xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
Posted on Sep 08, 2008
SOURCE: xm stopped working display says "antenna"
Broken antenna cable. Likely you have a kink or worn thru point on the wire somewhere.
Posted on Sep 17, 2008
Battery went dead on Garmin 396. The unit worked with airplane power in GPS mode but displays "waiting for data" on Nexrad Radar. I have downloaded version 5.30 I should alao mention that...
You indicated that the battery went dead. Does the new battery work correctly? That is, does it show a full charge when you've had it plugged in overnight and disconnect the power? Try plugging it into AC power overnight and verify that the battery is accepting and holding a full charge. If it isn't, then unplug and turn the unit on and allow the battery to run all the way down. Then charge it fully. This resets the charge indicator. You may have to repeat it once. I did this and was able to again show that both my new and my old battery were working o.k. They should show about 8.1 V fully charged.
About the Nexrad problem. In the past I would need to refresh the XM receiver when this happened. XM walked me through it and I have the steps, but the links are no longer working. Maybe it is no longer required since the XM link now jumps to SiriusXM. I've not needed to refresh for a couple of years and I suspect they eliminated that requirement.
To verify that the XM antenna is connected: Turn unit off. Connect the XM receiver. Simultaneously press "on" and "enter" keys- hold both until data screen appears, which takes about 5 seconds. Second line from bottom indicates if it is seeing the XM receiver. This helps isolate where the problem is- i.e. if you have a faulty receiver, bad connection or a software problem. The only contact I know of now is Garmin 800-800-1020. They can give you the XM contact if the problem is on that side of the unit. There is other data here which may be of interest to you on this page. Turn unit off to close this window.
If you need your XM radio ID, turn 396 on. Press menu, menu, scroll to XM, then right to Info. XM Receiver ID is there. Write it down in case you talk to XM or they give you a way to refresh. There are other menus you can get into but if they show a problem I don't know the solution other than contacting Garmin and I don't have my XM receiver home so can't verify the steps.
Mar 28, 2011 | Garmin Replacement GARMIN GPSMAP 396 GPS...
Cant get xm weather on garmin 740s
To receive XM weather or audio, the GPSMAP 740s requires a GXM 40 Smart Antenna with XM subscription.
The GXM 40 Smart Antenna (010-00730-00) is used to receive weather and audio service from XM satellite radio. For details on XM services please visit our XM webpage.
Once a GXM 40 Smart Antenna has been connected to the GPSMAP 640, the device can display the subscription information for the antenna.
From the Home Page in Boating mode:
  1. Select Configure
  2. Select System
  3. Select System Information
  4. Choose Weather Subscription
From the Home Page in Driving mode:
  1. Select Tools
  2. Select XM Services
  3. Select XM Radio
  4. Set the channel selector to channel 0
  5. Select Radio ID
The subscription information will now be displayed on the screen.
Mar 26, 2011 | Garmin Gxm 51 Weather And Audio Xm...
I have a Kenwood ddx6019 with XM satellite radio. recently, I entered a manual channel change and lost all reception. A banner reads LOADING LOADING across the bottom of the screen. Any ideas on how to...
I have a Kenwood ddx6019 with XM satellite radio and sirius. i want to know how do i turn on the xm so i can get live traffic update and my garmin gps unit and weather. and were to i find the mx radio id for xm. i found it for sirius
Nov 01, 2010 | Kenwood DDX-6019 Car DVD Player
Sirius vs. XM
Hello pdweidner,
Best regards,
Ken
Go Ahead. Use Us.
May 13, 2008 | Panasonic Strada CN-NVD905U GPS Receiver
Installing XM on my Motorcycle
Pick yourself up a Garmin Zumo 550, it has a navigator, MP3 player, photo viewer, and XM (Radio, Traffic, & Weather) and best of all the music gets interupted when it's time to give you directions.
May 03, 2008 | XM Radio (XMP6000)
GPS & XM
May 01, 2008 | Garmin Nuvi 660 GPS Receiver
No traffic and weather showing-using GXM 30 smart antenna with subscription
the only idea i have is contacting xm asking if they can resend the traffic signal to your unit.
Jan 29, 2008 | Kenwood DNX7100 Car Video Player
if the xm and gps antennas are close together this will happen. u will have to move one to the front and the other to the back of the vehicle.
Nov 03, 2007 | Kenwood DNX7100 Car Video Player
GPS Logo
255 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
