Question about Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD)
Belkin 4-Port Router
We just bought this router. The model # is F5D5231-4. I tried looking through your site for help, but the Belkin router with this same model number is NOT the one I have.
Anyways, the guy at Radioshack said that a Linksys wireless USB adapter would be compatible with the Belkin router. Strangely, or perhaps not so strangely, the computer with the USB is not detecting any wireless connection. I'm thinking that it has to do with the different frequencies. The Linksys USB frequencieas are IEEE 802.11g, IEEE 802.11b
The Belkin router frequencies are IEEE 802.3 10Base-T Ethernet, IEEE 802.3u 100Base-T Fast Ethernet, IEEE 802.3x Flow Control, & ANSI/IEEE 802.3 NWay auto-negotiation.
I do have Ethernet, just so you know. What would you suggest I do?
  • 905 Answers
This is because that router is a wired router not a wireless router
Posted on Oct 07, 2008
Can't remember the security key
Default IP is 192.168.2.1 -
4-Port Router Part # F5D5231-4
#feedback { background-color:#ddd; padding:5px 8px; border:1px solid #ccc; margin-top:18px; } function fbkSubmit(obj) { try { urchinTracker("/supportfeedback/" + dx.getQstr("aid") + "/" + obj); var str = userControls_articleContent.feedbackSubmit(obj, location + ""); } catch (ex) { //do nothing } $("#feedback").hide("slow").html("Thanks for the feedback.").show("slow"); } Reset the router to factory default
Resolution With the router powered on, use a small thin object to press and hold the reset button for exactly seven seconds. The router lights will flash and this will restore the router to factory default. Connect your computer to one of the routers lan ports with an etherent cable. Open your web browser and navigate to 192.168.2.1. This should show the router status page with the default settings. SummaryThis article describes how to reset the router to factory default you then type in the above ip address to access the router and use the DEFAULT username password to enter router.Set up all according to manual and change the password for security. Manual link Below: http://www.belkin.com/support/article/?lid=en&pid=f5d5231-4&aid=1564&scid=220
Nov 03, 2010 | Belkin (F5D5231-4) Router
How do i change my ip?
You can find the manual for your router here:
http://www.retrevo.com/support/Belkin-F5D5231-4-Routers-manual/id/557ci672/t/2/
You may want to look from page 18 onward, as this explains how to configure the router from the web interface.
Just remember that if you change the IP address of the router you will also need to adjust the DHCP range that the router gives to your PC (page 34).
Hope that this helps!!
Oct 17, 2010 | Belkin (F5D5231-4) Router
Why wont the belkin wireless router connect to my wireless mini notebook
Hi i got your issue
Yes, it will not connect in your wireless notebook as this particular model of belkin router is a "wired router" it does not transmit any wirelless signal ......
If you want wireless connection you can look for the new model of routers from BELKIN
Thank you.....
With regards.....
Priya
Oct 03, 2010 | Belkin (F5D5231-4) Router
My belkin basic router is not working
well you can fix such kind of problems via contacting to belkin tech support. for more help you may visit: Belkin Tech Support Helpline
Sep 10, 2010 | Belkin (F5D5231-4) Router
When i plug my belkin router in it won't recognize it
1. Please check your computer's IP address should be autamatic.
2. Please do not connect your cable from your computer to Belkin's Internet port
3. Please connect your cable between your computer to belkin router's 1,2,3 or 4 number's port
4. Please check you cable should be not cross cable.
Mar 13, 2010 | Belkin (F5D5231-4) Router
Lack cd for router 802.11b model F5D6231-4
you shouldn't need a CD for the router to work. The CD isn't a driver CD it is a CD to make connecting the router eaiser but it isn't necessary to use the CD to make the router work. This URL should help you set up this router:
http://www.belkin.com/support/product/?lid=en&pid=f5d5231-4&scid=220
Good Luck
Jan 05, 2009 | Belkin (F5D5231-4) Router
Lost disk for Router F5D5231-4
If you need this for the router setup, here is a link
http://www.belkin.com/support/download.asp?download=F5D5231-4
As far as I can see, the top link 'Need help setting up your router?' points to a downloadable setup guide with incorporated setup software. There's also a user manual on this page.
Hope this helps you.
Jan 03, 2009 | Belkin (F5D5231-4) Router
Router stoped working
yes new roughter netgear is easy plug in play vs linksys new model u can try hard reset button on back if your router has one still dont afte rthat cheak dns server code if u need one they woulve told u his to at start maby cheak for latest firmware for it if any is out ok otherwise ya get upgrade be faster then belkin
Oct 06, 2008 | Belkin (F5D5231-4) Router
Wireless router
I may be confused but this router model number does not seem to be wireless enabled are you sure it is correct F5D5231-4?
secondly for general wireless security see
http://www.fixya.com/support/t281214-wireless_security
Dec 01, 2007 | Belkin (F5D5231-4) Router
Belkin Router
Ip adresses are SIMPLE to find, it doesn't matter what router you have, unless you are looking for local ip which doesn't seem you stated it
You could find your ip in theese following sites
www.ip-adress.com
www.ipchicken.com
www.whatsmyip.org
www.whatsmyip.net
Hope this helped!
Belkin (F5D5231V4-SN-PD) Router (F5D5231V4SNPD) Logo
152 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
