Question about Toshiba SD-6915 Multi-disc DVD Player
Do not Play movie copies
I love movie, but the kids always damage the disc, I start make copy from the original movie, just to don't let to touch the original disc. They play nice in the computer, (we have 3), but in the Toshiba Player Model: SD-6915SU (Play DVD-R, DVD+R,DVD-RW, DVD+RW,etc) at the half of the movie, go frezee and no more movie. I put off the player, (the only option), them whem I press play, I can see only from the beginning (again) to the moment it stop in the first place. If I try from the scene selection, dont work (go frozen again) even if I select the scene after.
I like to now if some body make a update for the firmware, about this problem or any solution.
e-mail : canovivi@hotmail.com
5 Suggested Answers
SOURCE: TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Posted on Dec 13, 2007
  • 537 Answers
SOURCE: Can only play DVDs for one region code.
Most DVDs can only play DVDs from a single region. However, they sometimes allow you to change the region at least one time. Another option is to make your DVD player region free. This is a hack that can be performed. Once you do this, you can play DVDs from any region.
Please see the following link for more information:
http://www.videohelp.com/dvdhacks/toshiba-sdk760/6898
Posted on Jan 17, 2008
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
marked
  • 6487 Answers
SOURCE: Toshiba SD-5000 DVD Player - disc tray stuck
Try first turning off the player and turn it back on and eject it using the eject button on the unit and also try to eject it using the remote.. IF still wont eject this can be a mechanical function on the ejecting part of the unit that you may need to open the unit and check for that..
Hope that helps.........
Posted on Aug 07, 2008
SOURCE: Toshiba SD-K860 DVD Player wont load DVD's
Having the same problem. DVD player loads enough to identify it is a DVD or a CD, but won't actually start playing anything.
Posted on Aug 12, 2008
Purchased a dvd then learnt that dvd region codes exist. is there a way to watch region 1 dvd in region 4. dvd is 'mac and me' and is my favourite movie from childhood. really want my kids to...
With a DVD ripping program like Mac the Ripper or Magic DVD Ripper you can remove the region coding on a disc and copy it to a new DVD. These run on Mac and PC respectively, and you will need a DVD burner in your computer as well.
Keep in mind that you can legally make a copy of a DVD IF you follow certain rules:
1. You MUST keep the original disc and packaging to legally own the movie. If you get rid of the original you must destroy all backup copies as well.
2. You MUST NOT have more than one copy at a time, but you may make a second if your first one fails.
3. You MUST NOT give or sell a copy of the image (digitally or on a disc) to anyone else, or post it to any file sharing service. This is piracy and you can be prosecuted.
May 22, 2011 | Televison & Video
Tip
How Can I Copy DVD Files Easily on Mac?
Have you ever troubled with how to backup, clone or copy your favorite DVD to computer as a DVD folder, or an ISO image file, or even to another DVD disc directly? Furthermore, are you still griping about whether copying DVD entirely or just copying DVD with main movie?
more information:mac dvd copy
iSkysoft DVD Copy for Mac is extremely easy-to-use DVD copying software to copy any DVD movie with excellent DVD copying quality in Full Disk Mode or Main Movie Mode. It can copy DVD movie to computer as DVD folder, ISO file, copy DVD to DVD disc; burn ISO file or DVD folder to DVD disc.
Guide - How to copy DVD files easily
Step1. Select DVD Source
Download iSkysoft DVD Copy for Mac and install it. In the “Select Source” field, click and select “Select source DVD folder”. Then browse your computer hard disc and select your DVD movie (either in a folder or from your DVD ROM).
Step2. Select DVD Copy Method
iSkysoft DVD Copy for Mac allows you to copy DVD to a folder on your hard disc or directly burn DVD to a new DVD disc.
In the “Select DVD Copy Method” field, click to select a method to output the selected DVD movie:
If you want to output your DVD movie to a folder on your hard disc, you can select the “Output DVD Folder” option, and specify a directory to save the copied DVD movie.
If you want to directly burn your DVD movie to a new DVD disc, you can just select the DVD ROM where you have inserted a blank DVD disc.
Step3. Program Settings
Set Buffer Directory: Specify a directory on your hard disc as the buffer directory to store the temporary files generated during the conversion. We recommend that you select a folder on a hard disc that has relatively big free space.
Select Language: Select an interface language for the program. The currently available languages are English and Simplified Chinese.
Step4. Start to Copy DVD
Click the Start button to start to copy DVD movie and/or burning it to a new DVD disc.
Note: If you are copying a DVD disc from your DVD ROM to a new DVD disc, iSkysoft DVD Copy for Mac will ask you to insert a blank DVD disc when the program gets ready to burn. Then you can just take the original DVD disc out and insert a blank DVD disc.
on Jun 21, 2010 | Computers & Internet
Tip
ISkysoft DVD Copy for Mac Guide
Want to copy D9 and D5 DVD movies on Mac OS X? iSkysoft DVD Copy for Mac is specially designed for Mac OS X users to lets you copy your DVD movies and remove their protections with just a few click. iSkysoft DVD Copy for Mac allows you to output DVD folder and directly burn your DVD movies to new DVD discs with no protections.
Step1. Please download iSkysoft DVD Copy for Mac; you can know more about it by visiting here.Then install the software and run the software.
Step2. Select DVD Source
Step3. Select DVD Copy Method
Step4. Program Settings
Step5. Start Copying DVD
Click the Start button to start copying your DVD movie and/or burning it to a new DVD disc.
on Mar 31, 2010 | Computers & Internet
I want to get region free a MATSHITA DVD-RAM UJ-850S.
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
or if this is what you mean by region freehttp://www.freeware-downloads.com/any_dvd_backup.htm
Any DVD Backup is DVD Decrypter and DVD copying software to copy entire DVD movie to hard disk, and removes all the CSS, RC, RCE, APS, UOPs and Sony ARccOS protections while copying. Combining powerful functionality with a straightforward interface, Any DVD Backup provides an easy way to transfer DVD information onto your hard drive.Any DVD Backup is FREEWARE that will circumvent the copy-protection schemes used on commercial DVDs and enable you to make copies of store-bought DVDs. With Any DVD Backup, you own the most efficient way to create backup copies of your DVD movie collection. These working copies allow you to play your DVDs on your computer hard disk without the need of any DVD players.This DVD to computer backup solution avoids the inevitable risk of getting your originals of your DVD movie discs scratched or damaged. You get disc protection with no loss of playback quality.Any DVD Backup is free software. You should never pay for Any DVD Backup.
hope this helps
Apr 26, 2011 | Computers & Internet
Play original movies only, no play copies and no burned copies
My parents had a Sony drive that was the same. The guy at the store says that some sony models have a chip that detects the type of disc and will only play originals.
Jul 21, 2010 | Sony DRU-820A DVD RW Dual Layer Burner
On one particular DVD (UP from Disney/Pixar) a certain section keeps repeating. When I stop the DVD to try accessing the root menu it freezes up and the entire sound bar locks. The only way to resolve this...
Those discs have a very strong copy protection mechanism to avoid making digital copies on PC systems but some DVD players won't play them because of that, if you have the original movie, download a copy from the internet, burn it to a dvd-r disc and play it. It's perfectly legal because you already bought the movie. The downloaded copies have no copy protection and will play better than the original.
The PHILIPS DVD-Home theater players are specially picky about non-standar disk like the one you're trying to watch.
Jan 12, 2010 | Philips SoundBar DVD Home Theater with...
Is it necessary to play a original disc wont a copy do the same my console doesnt work with copied one whats the solution
if you are talking about game and you playstation is not moded then yes but if it is movies then no originals and copies do the same. hope this helps :)
Feb 22, 2009 | Sony PlayStation 2 Slimline Console
Ps3 was playing movies i had burned to disk now it wont
The best way to play burned movies is to copy them onto a memory stick or external hard drive then copy them onto the ps3 i use this method and find the movies play in much higher quality than dvd-r or+r or whatever discs you use
Jan 25, 2009 | Sony Playstation 3 (PS3) Console
Best Media to use for DVD playback
The laser eyes on mobil units are relatively cheap and low quality. If you keep playing copied discs(any format), it will make them "tired"(out ot alignment) from trying to focus on low quality encoded discs and render it useless. Original discs are produced with equipments and programs that cost ten of thousands of dollars that why they tend to retain the encoded info longer even when exposed to direct sun light for times and easier for unit to read. But if you are like the rest of us going to junk that player after a couple of years in service then use Verbatim Platinum dvds, they are quite high in prices but retain info much better than others. But remember they are still copied discs not the original articles and might one day cause your players to fail completly. Goodluck.
May 01, 2008 | Jensen VM9510 Car DVD Player
Copying vhs on to dvd
There are two methods for copying - one is called "one-touch dubbing" and the other is called the "GUI Method".
For one touch dubbing obviously you have the tape and disc both inserted and have the tape at the position you would like to start copying. Press and hold the Copying button in the direction of the media you're copying to (in this case, the arrow pointing to the DVD) for 3 seconds and it will either start copying or will prompt you on-screen of the television...
If you are using a disc that can be finalized (anything other than DVD+RW or DVD-RAM), you will get a message on the TV that says press Record to record and finalize or press Play to record without finalizing.
The GUI method is to press Functions - Copy, then select the copy direction and start copying.
Before finalizing a disc, when you go to play back the video it always starts with the last recording, not the first. This is probably why you think there is no movie there other than the 10 seconds of Arby's commercial (mmm, Arby's). However, this is the purpose of the Direct Navigator function. If you access it, you should see thumbnails of all of your recordings. Once you finalize the disc and playback, it should start from the beginning.
Mar 09, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Toshiba SD-6915 Multi-disc DVD Player Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
