I have a 27" samsung Model TX-R2779H and first the picture image changed so that the sides curved inward like a hour glass along with a electric overheated smell, now no picture at all
  • 4 more comments
  • jasbeck2004 Oct 07, 2008
    If I press the accept will I get the fix?
    I am not clear on the following step...."Take your digital multimeter and check all of the big resistors on the board". How do you check these?
    Also I noticed that my profile states Projection Television, but that is not correct, my TV is a tube TV
    I have added a few more comments and have not gotten a reply do I need to keep waiting?
    where is the power supply?
    Sergeant:
    Champion:
  • 334 Answers
Bad power suplly if u smell burn its form power s on thes eoldr big style tvs k start at the power
Posted on Oct 07, 2008
    Scholar:
  • 116 Answers
Its the problem of convergence in your tv.
  • 4 more comments
  • mastermind10 Oct 07, 2008
    it can be fixed.
    http://home.earthlink.net/~oleg.filippov...
    please check this above link for better help.
    you can do it your self.
    for pictures on where is the convergence settings.
    http://www.somelifeblog.com/2007/06/sony...
    yes.
    you can press accept.
    or feel free further queries.
    and that is a technical knowledge about checking a resistor with a multimeter.and i cannot teach that through comments here.its a long procedure.if any of your collegues having that knowledge should help.
    it is clearly mentioned in the pictures with yellow marks as what to check and replace.please have a proper look on the circuir board shown in that picture.
    the power supply is the main circuit board of the unit.
How do you fix a samsung tx-r2779h it takes more than an hour to turn on
Hello
Just try to replace its picture tube base connecting socket, can be located on the picture tube base card.
Mar 07, 2012 | Televison & Video
Picture is curved like an hour glass
that a pincushion problem likely caused by a failed capacitor
Mar 26, 2009 | RCA Televison & Video
Circuit City ''esa'' TV picture curves in on sides
Curving in on ( hour glassing ) the sides is usually the indication of a bad regulator IC. Since it occured after a move, you may also have a bad solder connection or smal crak in the board. To check for cracks ( assuming you have unplugged the power and are relatively comfortable doing so) shine a flashligt from the top of the board ( with the components on it ) and examine the bottom of the board. If a trace is broken you can often see it this way
Mar 12, 2009 | Televison & Video
My samsung cr32z30 32" hdtv turns off automatically after running for about 30min to an hour. also the picture is curved on both sides when watching tv in 4:3 ratio. the curve is most prodominate at...
Linearity coil (there are several) shorted causing HV to increase and causing HVSD, no replacement parts available. Replace sweep module to fix.
Nov 10, 2008 | Samsung Televison & Video
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Screen image display distortion
Hello.
What you are reporting is a problem in the pincushion circuit in the horizontal section of your CRT monitor. Usually this is from an electrolytic capacitor that is no longer willing to play nice with all the other components.
It is repairable, but get an estimate first. If the repair bill appears to be around $100, you would be better off to put a few more dollars with that and buy an LCD TFT monitor.
If you are quoted $25 or $30, it is probably worth having repaired. Just keep in mind that these older CRT monitors have age on their components, and once repaired, it will still be an old monitor.
Only you can decide which choice is right for you. At least now you have a few facts to help make the decision.
I hope this helps.
Nov 06, 2007 | Apple Multiple Scan 1705 Monitor
Curved picture
ur problems is on the pincushion check for a capacitor that its bad on the pincusion section  good luck.
Nov 01, 2007 | Televison & Video
High pitched squeal from TV
Get a small wood/plastic stick and touch the different coils/transformers to see which one is the cause. Replace part or if the part doesn't run hot, use a small amount of hot melt to quiet. Don't completely encapsulate in glue, don't want to create any hazards.
Oct 29, 2007 | Samsung TX-R2779H 27" TV
Shrinking picture
picture is starting to curve in from the sides like the shape of an hour glass. Is the tube shot? NO. is it something less costly? YES YOUR PROBLEM is in pincushion correction circuit.call skilled tech to fix it. it will not take much time. good luck.
Sep 22, 2007 | Televison & Video
Samsung 27" Dynaflat that warps image
the problem is into your power supply try to check you b+. it is a low b+
Apr 28, 2007 | Samsung DynaFlat TX-P2775H 27" TV
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
