Question about Garmin StreetPilot C330 GPS Receiver
Garmin C330 Turned unit on from the box and screen froze! Pressed reset button, screen went blank, now it will not turn back on. the screen is congeal the swith on off is not operated c330
  • 69 Answers
IS the battery charged fully? Try turning it on while its plugged in.
Posted on Oct 07, 2008
Garmin froze and after turned off now will not turn back on
Pull the trim ring off the front of the GPS and you will find a reset button. Press thia button and hold it down and start the GPS It will reset and you should be fine.
Thanks for using Fixya.com
Harleyknut.
Apr 08, 2009 | Garmin StreetPilot C330 GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Blank Screen on Garmin C330
It took a nap...
Dec 11, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Street pilot is dead
It took a nap...
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
Garmin c330
Look near the SN # and press the reset button.
Jun 19, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen
Resetting Your c330
If your unit locks up, press the Power button to turn off the unit, then press again to turn the unit back on. If this does not help, reset your C330.
1. Place your thumb nail in the groove located under the Garmin logo on the face plate.
2. Gently pull off the face plate.
3. Press the Reset button.
4. Turn the unit back on; it will operate normally
Apr 04, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin C330
put your thumbnail under the silver faceplate above where it says garmin and on the right you will see a reset button. It will reset your garmin and you will not lose your information. Hope this helps.
Patti
Dec 12, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin C330 white screen
Have you tried a Master Reset? If not, it may help, but it WILL ERASE ALL OF YOUR FAVORITES, and may remove anything you have updated. To do a Master Reset, turn the unit off. Press the On button and the bottom right of the screen at the same time. Release the On button, but keep pressing the screen until the unit asks if you are sure you want to reset. Press yes. This may help.
Oct 28, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
83 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
