Question about Frigidaire Freezer Refrigeration White Upright Large Manual Defrost Freezer Model FFU2124DW
Freezer/refrigerator I have a GE side by side (approximately 6 years old). I have been having troubles with the freezer side building up frost on the back then the freezer gets warmer as well as the refrigerator side (mainly warmer on the top shelves and door). Eventually it will start working again and then go back thru the cycle of of warming up. We have had 3 parts replaced and still no luck. I think our repairman is baffled. Any advice? Joan
    Guru:
  • 449 Answers
Refrigerators with an evaporator (called a humid plate on this type of refrigerator) in the refrigerator section are called a semi-automatic defrost. This means that the freezer section occasionally needs defrosting but the refrigerator section defrosts by a means called "heat leakage defrost". How it should work....
the cold control, (the electrical device under the dial), leaves the compressor off for long enough for the plate to melt off each cycle.
If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help
Posted on Dec 20, 2008
  • 1 more comment
  • Jerry Parmanand Dec 20, 2008
    If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help good
    If yours is not melting off perhaps you have a faulty control or you have it set too high. hope this help good luck
IHave a ge side by side refrigerator not cold enough and freezer has frost on back wall and some items are not frozen
your GE self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch. If you have a GE profile, they have a motherboard at the back of the ref. if all i the part i mentioned are working, just replaced the motherboard. at searspartdirect.com
Apr 06, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
GE GSS22JFMCWW
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Mike
these are the usual suspects.
heater in the back wall of the freezer:
thermal switch also in the back wall of the freezer
Aug 11, 2008 | Nor-Lake Freezer Norlake Refrigeration 6'...
Kenmore Freezer 106.727581: The freezer ices up and the temp goes up to 34 degrees. If I manually defrost it, it goes to 5 below zero in about 6 hours. How can I determine which of the below need to be...
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (also called the bi-metal switch) The defrost heater. To determine if the defrost heater is burned out, watch this part testing video
Aug 21, 2011 | Kenmore Freezers
I have a GE side by side freezer/refrigerator. The
When you say "The items in the freezer are cold with some ice on them. I have tried emptying the ice tray, but that does not help." Is there literally ice from the ice bucket dripping on the food and refreezing, or is there a layer of frost on the food? the noise you are hearing is most likely due to the evaporator fan motor running at alternating low and high speeds. This is a variable speed motor, but there could be quite a few reasons why the motor is not rotating at regulated speeds. the fan motor itself, a faulty thermistor, you could also have an issue with your main control board, or least of all a wiring issue.
You would be wise to have it inspected by a reliable refrigerator repair service, to at least determine what the problem is for certain.
Mar 31, 2010 | GE 13.7 cu. ft. General Electric Upright...
Kenmore freezer upright frost build up on door
first just take it out and clean that one carefully .And then set correctly and observe it,s working condition.then also it's not working means show it to ur near by worker those who repairs it
Jun 20, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
May 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Working ff freezer unplugged 1 year now does not freeze
Hi!!! You seem to have a seal system problem..A leak of refrigerant or a restriction in the seal system..Good luck...
Jan 20, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Freezers Logo
494 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
