Question about RCA P52926 52" Rear Projection Television
RCA P56926 ADJUSTING PROJECTION TUBES
I have a projection tv with two images in corner and in other areas the original remote is history. no other remote will let me bring up the projection tube adjustment...Can this be fixed with a new remote for this tv?
  • 3 Answers
On my rca projection, it let me access all of those functions under the menu button, right on the front of the tv
Posted on Oct 29, 2008
Crescent shaped image on screen - RCA 56" P56926
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. Also, the convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components, if not then you should get this done by a professional. The typical cost to get this fixed by a pro is around $250-$300. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Apr 07, 2010 | RCA P52926 52" Rear Projection Television
Video input channel stays on screen in upper left hand corner of my sony 57in hdtv rear projection
WITH AN ORIGINAL SONY REMOTE HIT THE DISPLAY BUTTON TO REMOVE THE INPUT ON SCREEN DISPLAY---IF YOU leave it on long enough it will burn that image into one or more of the 3 picture Tubes.
ALMOST ANY SONY TV REMOTE WILL WORK FOR THIS FUNCTION.
sd tech
Oct 09, 2009 | Sony KP-57WS520 57" Rear Projection...
Rca p56926 screen is concave and cant adjust convergence in menu
Convergence can only be repaired by going into the unit itself....You MUST know how to do this or risk a lot more problems.....seek qualified assistance!
Aug 29, 2009 | RCA P52926 52" Rear Projection Television
I need a lamp number for my RCA P56926 model TV. Can anyone help me??
bluestar international componets 1 800-522-2701 1-631-385-8171 or web site bulb 115.00
Jul 01, 2009 | RCA P52926 52" Rear Projection Television
Is the tubes going out on my rear projection tv?
If the red, green, and blue colors are separated like a rainbow, then the convergence amps are going out. This set has a common problem of two electrolytic caps going bad. The caps are in the upper left-hand corner of the main board and will have a bulged top if bad.
I would not think the picture tubes are bad, especially all at once.
- Dan
Apr 28, 2009 | RCA D52W19 52" Rear Projection Television
RCA p56926 replacement screen
you cant, the screens for that model are no longer available and even a used scree assembly will be over 200. if you could find a new one they would be about 4 to 500.00
May 25, 2008 | RCA P52926 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
Xbox 360 hd and p56926
change back to 480 resolution and them go upscaling
Feb 20, 2008 | RCA P52926 52" Rear Projection Television
Image problems
Dual image problem is generally a convergence issue.
A repair of replacement of convergence amp IC(s) and
possible fuse device in power supply will be needed.Ask a
local repair shop w/good reputation what the cost would be.
Oct 07, 2007 | RCA P52926 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
273 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
