Question about Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated
Runs and stop
Runs for 2-4 seconds and cut out
  • juan1hector Dec 12, 2008
    my air compressor run and stops, it is poping out the safety swith every time that stops.
    I also read the prior tread to this isue but my compressro is electric as estated in the header, so the information to solve this isue is unaplicable.
    thanks.
    juan
  • morenoarmand Feb 05, 2009
    my compressor keeps popping out the reset switch and it takes about 30 tries for it to finnaly re start only to do the same thing over and over im at it for 15-20 miniutes before i can actually get a full load of air
  • 135 Answers
Check fuel filter.
Remove fuel cap and try again.
Fuel starvation.
Are you at a high elevation (readjust carb. needle)?
Posted on Oct 07, 2008
Friends car, he has not got a computer. It usually runs as sweet as a nut. Engine starts then cuts out. Sometimes runs for 20 minutes, then cuts out.
car starts then cuts out after 2 seconds, please help!!? ' Yahoo ...
https://answers.yahoo.com/question/index?qid...
Mar 22, 2010 - Car starts then cuts out after 2 seconds, please help! ... I went to start it this morning, it started up fine but only for literally 2 seconds then it just cuts out. .... In every after how many kms we should engine oil in the motor bike?
Engine fires up, but cuts out. - Gassing Station - PistonHeads
www.pistonheads.com/gassing/topic.asp?t=1128508
PistonHeadsMar 23, 2012 - When the engine is cold it needs a bit more fuel to stop it cutting out(sort of like ... If you can't do it yourself then you shouldn't need to take the car to your ... Also, starting with your foot on the throttle seems to cause all sorts of ...
What is the problem if the car starts and then dies almost ...
askville.amazon.com > Transportation > Automotive
Nov 22, 2010 - Askville Question: What is the problem if the car starts and then dies almost immediately? ... I waited for my kids, and when I tried to start it back up, theengine turned over but then died immediately. ... 1. out of gas, or bad gas
fuel system - Engine starts but almost immediately cuts out 3 ...
mechanics.stackexchange.com/.../engine-starts-but-almost-immediately-c...
Jun 26, 2014 - When I start the car the engine catches but then dies almost immediately. I have to restart the car 3 or 4 times like this until the engine starts ...
Car starts, then cuts out straight away!! - boards.ie
Jan 08, 2016 | Cars & Trucks
Starts and cuts off
serial number/keygen for registry reviver
Jan 28, 2014 | Cars & Trucks
Panasonic genius1300w cuts off after 3 seconds
see this causes and fix it. God bless you
Door Switch If the microwave runs for a few seconds and then shuts off, a door switch might have failed intermittently. Check each of the door switches for any signs of overheating, arcing, or burning. Also check each of them for continuity. Replace any of the switches that is visibly damaged or that only has continuity intermittently.
Main Control Board If the microwave runs for a few seconds and stops there may be a short circuit in the main control board. Check other components first, these boards are often misdiagnosed.
Touchpad and Control Panel If the microwave runs for a few seconds and stops the touchpad and control panel might be defective. There are several other components that can cause this problem, be sure to check any other components before replacing this board.
Touchpad If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpa
High Voltage Transformer If the microwave runs for a few seconds and stops the high voltage transformer might have an intermittent short. This is not common. Check other components related to the microwave symptom first.
Thermoprotector If the microwave runs for a few seconds and stops the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Thermostat If the microwave runs for a few seconds and stops the thermostat might be defective. Watch our video on testing thermostats.
Oct 09, 2012 | Panasonic TK-929SA Stainless Steel...
Alarm list says motor rotation and cuts off
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
Sep 27, 2012 | Microwave Ovens
Starts, idles and runs but quits after a few seconds of cutting
Check the air cleaner and muffler for plugging. One screw adjusts the idle stop (idle speed) position and the H and L jet screws set fuel mixture for high speed and idle speed mixture respectively. Turn both jet screws CW to stops (lightly) then back each out CCW 1-1/2 turns. This is a basic setting and should allow the engine to start and run. Start the engine and allow to warm up. Pull the throttle full on and adjust H CW until the engine starts to speed up, but 4-strokes. Correct adjustment is when the engine 4--strokes running free, but immediately 2-strokes when cutting. Release the throttle and adjust L needle CW until the engine idles fairly well, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the chain stops turning, but the engine will continue to run. Hope this helps!
May 17, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Idle engine cuts out
You need to get to the idle screw on your carb and srew it in until your idle raises up a bit, also put some Techroline (chevron) in your gas tank...1/2 bottle in Full tank.....Good luck to you friend....Tim
May 12, 2009 | 2003 Suzuki UH 125 Burgman
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Sep 21, 2007 | Dacor PCOR30 Convection/Microwave Oven
Hitachi EC12 Portable Electric 2hp Air Compressor, Oil Lubricated Logo
76 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
