Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Cable connectivity I am able to connect to the net via cable modem. When I try to connect via d link WBR 1310 router no connectivity. When I plug from router into my pc, I get a steady light. When connected directly from cable, I get flashing light. Is this significant? When I run auto fix I get message no connectivity -- contact lan administrator. Any help? pat
    Scholar:
  • 94 Answers
Hi pat seems your router is not configure yet for internet connection, for cable connection you must log into the setup page of the router and clone the mac address of your computer.
to do that you can call 1-877-453-5465
to have someone walk you trough the steps.
flashing lights simply means activity on your network, and you get activity when you have internet connection.
hope that helps pat.
Posted on Oct 07, 2008
WHAT IS THE MODEM
The WBR-1310 is just a router - you will also need a modem - the modem is the component that connects to your telephone line or to the cable providers cable - to get broadband into your home
http://en.wikipedia.org/wiki/Modem
you would connect the modem to this router in order to share your broadband service amoungst devices or to get wireless
Jul 13, 2014 | D-Link 802.11g Wireless Router WBR-1310...
Wbr 1310 does not seem to connect to laptop. erthnet cable is connected from modem to wan port on router and another erthnet cable from port 1 on router to laptop erthnet connection. no...
connect your computer to the router and open internet explorer and in the address bar type, 192.168.0.1 and push enter. it might be 192.168.1.1, don't remember. login and setup your internet connection. if you have cable internet set it to DHCP. if you have DSL you will have to get the settings off the providers web site. you can also try resetting the router. with the power on, press the tiny reset button on the back of the router for about ten seconds. you will see the lights go out and come back on. once the router reboots try it again. Good luck.
Aug 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
How to install d link 802.11G wireless access
Connect modem lan cable to Router Wan / Internet port. From Router Lan port you can either connect your system or switch . wireless : Scan for wireless network from your wireless system. If it shows, connect to your wifi network
Thanks
Mar 25, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Issues with a D Link WBR 1310 Router
Make sure that your computer is able to go online directly
through the modem.
If your computer is able to go online through the modem,
that means the modem is working fine.
You will need to connect the computer to the router and the
modem to the router.
open the set up page of the router and change the settings
of the router according to the ISP.
Click Here for more information about the routers and
network
Apr 25, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
My computer is not reading anything on my dvd. Need to down load WBR-1310. help
are you trying to set up the router.
You don't need CD or DVD .
If you connect the computer to the modem, does it work ?
if that works then the modem is working.
Now connect the modem and computer to the router.
open the set up page of the router.
change the settings of the router according to the ISP.
Click Here for more information about router set up
Jan 08, 2010 | D-Link 802.11g Wireless Router WBR-1310...
D-Link Wireless Router WBR-1310 wont connect?
- Check LAN cable
- Use a different cable
- Use "crossed" LAN cable
Oct 18, 2009 | D-Link 802.11g Wireless Router WBR-1310...
After connecting router wbr-1310, DSL connection states "limited to no connectivity." What could be causing that problem and how can it be corrected to operate the router?
limited to no connectivity with a wireless system means that it is not picking up the signals from the internet device you have, check if everything is plugged in properly and that your internet connection (modem) has enough strength to be able to be wireless.
Sep 04, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Connection
Go to this site to download a manual to verify you have it setup right.
http://www.d-link.com/products/?tab=3&pid=WBR-1310&rev=WBR-1310
or try this first.
Power off your modem,D-Link and PC.
You need to have the cable that looks like a wide phone plug with 8 contacts instead of 4 (cat 5 cable) go from your comcast modem to the plug on back of the D-Link that is marked WAN.
Then plug a cat 5 cable into any of the 1 through 4 Lan ports on back of the D-Link to your PC's Ethernet port.
Then with all these powered off turn on the Comcast modem, wait a full 2 minutes for it to settle in. then turn on the D-Link give it 2 minutes then turn on your PC.
If that doesn't work for you refer to the manual or you have something broke that may require servicing in person by someone computer savvy.
Hope this helps.
Jul 31, 2009 | D-Link 802.11g Wireless Router WBR-1310...
I have comcast cable net and D-link WBR 1310
Hi, forget about the USB connection since you wanted to use a router for your wireless connection. Contact Comcast asnd make sure they assist you in making your computer connect to the Internet using the ethernet connection because you are going to use the ethernet connection for the modem-router connection. Once your computer is online with the ethernet connection, you can connect your Dlink router to the modem and configure it for Internet connection. There will be more steps before you can use the wireless connection. Just make sure you can get online with ethernet connection first.
Jul 23, 2009 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
256 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
