Question about Frigidaire Washing Machines
Makes a grinding noise when the draining cycle starts.
  • 1 more comment
  • conniebabine Oct 06, 2008
    Its an affinity front loader. Gives the error code e10 and when it does make it through the wash cycle and starts to drain, it gets so loud you can hear it outside. From other things I have read it sound like the pump. I hate this washer. paid a billion bucks for it and nothing but problems. nest time i will buy the most basic, cheapest washer.
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Okay...it does sound like you have something caught in the drain pump. I STILL need a model number in order to confirm how this washer is constructed. Is this a front loader or top loader?
    PS I agree with you...most of the simple model washers I've worked on last much longer...
  • Jeff Rockwell
    Is this a fron loader, or a top loader? What is your model number? This information would be a great help in being able to determine a cause of your problem.
  • 5,911 Answers
I guess I should have read your last post a littel more clearly...sorry. Front loader it is. Yes, this is a very common problem for front loading machine machines. More than likely something is caught in your drain pump. The following link explains how to check it:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
I know the link is for a Whilpool model, but the process and theory are still the same. If you leave the washer in its current state and continue to run it, you may cause irrepairable damage to the pump. It doesn't take much to damage the small motor and impeller. I hope you find this information helpful. Please let me know if you require additional assistance.
Posted on Oct 07, 2008
What is causing my Kenmore top washer to make a grinding noise before the rinse cycle?
Have you replaced the clutch or spin tube? There is a brake actuator that comes with the clutch kit and if this is broken it can make a very loud grinding or clacking sound.
Jun 25, 2014 | Kenmore Washing Machines
Washer not draining
sounds like you need to replace the pump
Aug 30, 2017 | Whirlpool Washing Machines
Washer makes grinding noise when it agitates
check back of unit as the concrete on the back may of been dislodged check not over loaded also the belt maybe loose or streached
Jan 02, 2014 | Crosley CAWC529JQ Top Load Washer
Have a proforma toploader and is making a grinding noise in both wash and spin cycle. it is still draining and doing everything just making the noise.
We have a proforma toploader washing machine and when using the machine in makes a very loud grinding noise during the spin and wash cycle. On occassion it also does not spin the clothing out properly, however the machine is still usable.
Dec 29, 2010 | Maytag Performa PAV3200
Grinding noise
grinding noise normally comes from drain pump or a circulation pump, a tech has to see which one it is .or if you want when it goes in drain mode see if you hear it then,if not then it the other. let me know if i have been of some help.
Feb 24, 2010 | Dishwashers
Washer has started making a heck of racket during the drain/spin cycle. It's not consistant. Two loads may go thru ok no noise. A third load and it will make a very loud grinding chain like noise.
Grinding noises are most often the result of a failing water pump. The noise can increase during the spin\drain cycle due to the added load on the pump. Although less likely it could also be the drive belt rubbing on something or a pulley bearing failing. If you are able to locate and remove the drive belt, you should be able to turn the water pump pulley by hand. If the pump does not turn smoothly it is bad.
Aug 06, 2009 | Maytag Washing Machines
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Grinding niose from agitator.
If the fill and drain functions correctly, AND the spin cycle works correctly, AND the cycle itself starts and completes correctly, the problem being that the back and forth motion of the agitator starts the loud grinding noise, it will likley be broken gears in the transmission. The single most expensive part in the washing machine.
Feb 04, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
136 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
