Question about HP Pavilion dv6000z Notebook
I restored my hp notebook and now cant connect to the internet
It recognizes wireless networks but the connection stays in local only...I cant connect to the internet...WHats wrong?
  • libramantt Oct 07, 2008
    my problem is that i have a hp pavilion dv2000 it hav vista as the os, however i downgrade to xp and the i cannot get the audio to work. i did the driver thing, i force install the driver and still no result. what should i try
Uninstall and reinstall your wireless drivers, then check the properties of the connection. Also look at any firewall settings that you may have install on your machine
Posted on Oct 07, 2008
  • 1,124 Answers
You have to set your wireless connection again.
Select your wireless network, insert you key or password (if any) and connect
HP Pavilion Dv6910us Entertainment Notebook Pc will not connect to internet
To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router. information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-
Mar 24, 2012 | HP Pavilion Dv6910us Notebook
I restarted my desktop and wiped it clean, when i went through everything to start restoring everything i had on it i tried to connect to the internet through my wireless adapter. I cant get online to...
I'm afraid your only option is to get the drivers one way or the other before you can connect to the internet or the network.
What I recommend is simply downloading the drivers from another computer that has access to the internet and transfering the driver package with a USB key or an other portable storage device.
Apr 08, 2010 | 2wire 1000-200004-000 Network Adapter
MN-520 wireless adapter will not connect.
well!! I have an answer for you.your comp is loosing the IP address.first connect your computer via cable then goto start - programmes - accessories - dos prompt. type`ll get ip address,subnet mask,default gateway.copy it. goto network and sharing center in vista and network connection under control panel in XP,IN Vista,click on view status,goto properties and double click on internet protocol(tcp/ip) or IPv4In XP,right click wireless network connection and goto properties and double click on internet protocol(tcp/ip).type in the IP address,subnet mask,default DNS server address type the default gateway in primary DNS and in secondary your connection won`t drop after this.
Jun 26, 2009 | Microsoft Broadband Networking MN-520...
Wireless network card
Hi there.
The wireless switch on the front bottom of the laptop, it's suppose to be blue when the button is on the right.
Right click on computer and select manage, go to device manager, and go to Network Adapters, try to see a network adapter called Broadcom, if it doesn't appear, it means that your computer doesn't recognize the wireless card and you may have to reinstall the drivers.
Please let me know how you get on.
Good luck
May 28, 2009 | HP Pavilion dv6000z Notebook
I cant get into my internet settings ! acer aspire one
it says that is not a recognized as an internal or external command, operable program or batch file
May 27, 2009 | Acer Aspire One PC Notebook
Wireless network is not connect to local network
I am bit confused with your query.  Its not possible to connnect wireless with local network.  Or what you can do is use wireless router so that ur laptop detects the service and you can access internet.
Mar 16, 2009 | HP Pavilion dv6000z Notebook
Help mi out plzzzz(wireless problem)
what you can see on your network connections? If you can see some icon of internet connection or local network connection you can right click and then point to properties after that you can see the local area connections properties. double click the Internet protocol (TCP/IP) click it and then click obtain automatically ip address. Some wireless network, you can see the network provider which you can see on your network locations. Sometimes you can put specific ip adress of your provider. If not? you can make your own network connection, right click the internet connection and then click properties follow the instruction and go to network connection and sign up your username and password so that you can access through internet connections.
Jun 25, 2008 | HP Pavilion dv6000z Notebook
Wireless laptop
To use wireless conection you need a Wireless Access Point i.e. wirless router. Then you can connect your laptop to this router and use internet. But if you have modem in your lap (generally all laps are coming with modem now) you should direct attach the phone line to your lap. In this case you need a dial-up no which you can ask your ISP.
If any problem just Ask me
Apr 07, 2008 | HP Compaq Presario V2000 Notebook
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
Dynex wireless adapter
When you posted "cant...dynex wireless notebook card...operate..." do you mean:
1. It is not recognized by Win98SE;
2. Will not install:
3. missing/error on drivers;
4. will not connect:
5. will connect but drop;
6. will connect but no internet access?
Pls post back details. Further to what AP/Router are you connecting to?
Kind regards.
Nov 04, 2007 | Intel Pro 1000XT Server Adapter...
HP Pavilion dv6000z Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
