Question about HP Pavilion F1703 17" LCD Monitor
Hp vs17e monitor
My screen will only show 3 second and then it turns
off
  • electrodude Jan 23, 2009
    can someone explain how to fix this in non-broken sentences and proper english?
    are you supposed to remove the two chokes on the power side (the coils with the 6 turns of wire) and resolder them?
  • mnd_fl May 11, 2010
    Can someone point out to me where the Power/Backlight PCB exactly is??
    I had my VS17E totally disassembled and I couldn't find any PCB that had any "coils" on it.
    Are you referring to the PCB where the power cord and video cable plugs into??
    Thanx
All of them r rite but u can always buy a new monitor. ur choice.
Posted on Nov 04, 2008
  • 42 Answers
Probably the previous post meant the same solution:
The 2 coils on the power/backlight PCB are not properly soldered anymore. resolder the two coils and the problem will be solved.
Greetings Drikus
Posted on Oct 12, 2008
Take face plate(gray color) off and remove 10? screws that hold the lcd in place. Then remove power ribbon(mark placement with marker),then carefully remove lcd.Now remove 2 serial port bolts and slide off cover to reveal pcb boards. Look for the board that has the 2 copper windings and remove. Look for soldering joints that look dull and reheat with soldering gun and flux if needed, should work like new!!!!!!!
    Champion:
  • 293 Answers
Hi...there,
That's mean you got a busted backlight inverter, Dude! Replaced a new one or repaired it. Good lucks!
Posted on Oct 07, 2008
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
My screen stays black but my pc is on
it sounds like your mointer is ****, i highly doubt the game caused it. try another mointer, or sell that one on ebay and buy a new one
Jun 14, 2009 | HP Computers & Internet
HP vs17e My screen went black for a few moments and when it
Switch off and on your PC and hold down the F5 key and this should bring up your PC in Safe Mode. If this fails, then find a PC repair shop to replace the power supply.
Mar 22, 2009 | Computers & Internet
HP vs17e automatic auto-adjusts randomally.
well why not try the monitor on any other computer
if it fails there,
bingo bad monitor.
easy no?
that shifting is bad. real bad,
if the problem in only on your PC.
then the Video (card or GPU chip) is bad.
you never said what you are plugged into
1981 to 2017, 10,00000 systems. made.
Mar 17, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Hp vs17e monitor says it's in sleep mode then goes blank
check the board postings for the HP f1903 monitor.I recall seeing a problem of the same there and a solution or fix. As it is only a newer version of the same model, it may be the same fix. Appears HP has a big problem with QA and this particular model. Lots of people have same or similar problems, and all appear to have a similar fix or solution. Tricky part... figuring out how to "Open" the monitor to check it inside!
Good Luck.
PS - if you figure out the opening part, let us all know!
Feb 02, 2009 | HP Pavilion F1703 17" LCD Monitor
Auto Adjustment keeps turning on every few seconds
manufacturer fault. Just buy a new one, honeslty not worth the time of day as you have to get very tekkit torepair this one
Dec 25, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor in sleep mode
my computer is on but screen is black and has power. How can I fix it?
Aug 27, 2008 | HP Vs17 17" LCD Flat Panel Monitor
My mothers computor monitor screen wont come on, Its a Hp vs17e monitor thwe screen stays black
monitor could be blown or the video card might now be anygood or try to turn up the brightness on the monitor .....
Jul 14, 2008 | Computers & Internet
LCD monitor dirty
please give me a power supply smd ic nomber please MODEL NO. HP VS17E
Jun 26, 2008 | HP Vs17 17" LCD Flat Panel Monitor
HP Pavilion F1703 17" LCD Monitor Logo
670 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
