Question about Maytag Neptune FAV6800AW Top Load Washer
Sounds like a jetliner taking off!
I have the above model Neptune and when it spins out, it sounds like a jetliner taking off. I have had this for 4 years and this is the first problem.
Any suggestions?
  • 1 more comment
  • Anonymous Oct 16, 2008
    I have exactly the same "jetliner taking off" sound when on the spine cycle. Not to mention having to deal with mold and/or rust.
  • Anonymous Oct 25, 2008
    this machine has been fixed once 8 months ago , it is 4 years old , bangs and squeaks as it washes, doesnt want to spin
  • Anonymous Oct 28, 2008
    I have the same problem with the spin cycle of my FAV 6800AWW. The spin cycle sounds like a freight train! I was quoted a repair cost of $500 to $600! My machine is also 4 yrs old. I emailed Maytag but the only offer they had was 15% off a new product! It's unreasonable for a machine to last only 4 yrs! Has anyone gotten any help from Maytag with this?
Check you tub bearing
Posted on Oct 15, 2008
Maytag Neptune stacking washer, model #MLG2000AWW, sounds like a jet engine warming up during spin cycle. Otherwise it is quiet and works well. Is a main bearing going out? Is it something I can fix...
you can but it wouldnt be economical to fix it if it sounds like a jet it is yr rear bearing and although the part might be only 60 dollars the amount of time it would take someone to do the job correctly is about 2-3hrs if you can do the job yourself then you would save on a large labor bill ive seen some techs price doing this job at starting prices of 400 you can find the part at marcone appliance parts if you choose to do the job yrself hope this helps
Jul 18, 2010 | Maytag Washing Machines
My maytag neptune tl fav6800aw top loader sounds bad and wont spin or drain half the time any ideas were to start. It is about 4 years old
Sorry I missed your post I feel I can help you if you want DIY the fix. From your description it sounds like you have a Clutch malfunction see this post Clutch Fix for support.
Let me know if I can help you thru the issue………Rich
Jun 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune top loading washing machine when washing sounds like there are belts squealing and the washer tub seems to hit the sides of the machine when spinning what is going on?
This sounds like a possible Clutch issue. Is the machine model an FAV6800A or FAV9800A?
When the washer is banging around do you take unbalance errors such as dC or uC?
Do you want to DIY the fix or call in a repair service. If you could confirm your machine model number......Rich
May 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Our 5 year old Neptune won't progress through the cycle past 24 minutes, and won't drain, though it sounds like it is spinning. We had a new clutch put in about 3 years ago. The repair guy said to replace...
It is not the controller. It sounds like it spinning since the motor is turning. If the motor turn then it is not the control board problem. The culprit is that the mechanism is not working. The motor has 2 directions of rotation. One is for agitation through a mechanism, as helix. The part cost about 10$. Other direction is for spinning. This includes the transmission pulley, the brake and the clutch. The clutch and the brake are hardly needing replaced unless a wrong diagnostics had been made. The thickness of the transmission pulley is worn out due to a friction force every time the spinning mechanism is engaging. When it is worn out, it is short to push the clutch so no engagement happens, hence no spinning. And this parts also cost $15. The only cost is the labor to take the machine apart to replace this. If you enjoy doing it then I recommend you should. There is no instruction to describe how the system work, but if you observe the mechanism carefully, you will understand how it work. The best simulation to gain understanding is to unplug the machine take out the panel, turn the belt in either direction so you can see how it engage to the 2 different mechanisms then you will see how it works. Good luck.
Apr 21, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Hi just got a set neptune model mah3000aww the
your main control board and the actual lock,
open the three screws on the top of the control board..
you will see the machine control
without disconnnecting the wires , inspect the board as closely as uou can your looking for physical burn on the board,,,, this usually takes place on the lower left area of the board
there you will see a burnt resistor, r-11
you will need to replace that control
the board is 138.00
you will also need to replace the wax motor lock above the door
but is sounds like you just bought them
do you have a wrrenty of sdome kind
if you wish to make the repai let me know i will walk you through it it prety easy but can be tricky
Oct 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Loud Spin Cycle
im sorry,load spin cycle may be a bad spin bearing.remove lower back panel.look behind large black pully.if see rust ,water.metal fragments.thats it.cost a bunch to repair.ive done them 4 400 to 500$.God bless you ,tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washer will wash but not spin
Sounds like the control board is bad. take the back panel off the control panel and look at the R11 resistor and see if it burnt. If it is replace the control board and the door wax motor (in the locking mechanism)
Nov 21, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune super stack model: ML2000 when it spin drys the clothes it sounds like an jet airplane ready for take off.
it sounds like the main bearing in the back of the drum (under the big pulley). make sure you replace it and the water seal soon before the starts to damage the plastic tub.
Jun 27, 2008 | Washing Machines
Removal of front assembly (Maytag MAH6500AWW)
remove the front ,everything thats in front of the tub.Remove the fins attached inside of tub ,remove any bolt you see .Remove the tub
Jun 05, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
75 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
