Question about Western Digital Scorpio WD800UE (WD600VE50PK) 60 GB Hard Drive
WD800UE I Have a WD800UE, the board died stopping me, accessing the HD. Where can I find a board (new or old) for my HD?
    New Friend:
  • 51 Answers
What board died? What kind of board?
Posted on Oct 08, 2008
Hi, My previous computer died and I have tried to
you need then to "boot" in the second HD to TRY to look at those files.At start up press F12 and chhose the HD.
Oct 12, 2010 | Western Digital Caviar SE WD2500JS...
HD not recognized and makes 3 times beep...beep noise when conect
Sounds like the drive has gone south.
This is a bit of work, but if you have access to a Linux disc, load the Live CD and see if you can mount the drive from there.
This is not quick a quick solution but may be far cheaper than sending off to a recovery expert.
If you are not familiar with Linux, go to www.ubuntu.com and download the latest distro, V9.04. Download, burn a copy and boot from it. Be prepared to spend time doing this, but it may just save your valuable data.
I have many times been able to salvage data just by doing this, if Ubuntu sees the drive, you could copy the data to your C drive and reboot.
Best of luck!
tom
Apr 04, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
Feb 02, 2009 | Western Digital Scorpio WD800UE 80 GB Hard...
Maxtor 3200 backup drive not recognized in my computer to access
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=510
Re: whishels
Options Options
eltigre
New Visitor
eltigre
Message 23 of 61
Viewed 3,676 times
My Maxtor 3200 died also. I took the following steps to get it running again.
(1) Remove plastic box from around unit. Carefully stick a screwdrive in the case division and pry it apart. It is not easy, but do will finally come apart.
(2) inside you will find a perforated metal box. There are two screw on each side of the box. Remove and separate the two halves.
(3) there you will discover that inside is just an ordinary Maxtor hard drive like you would buy in the electronics store. Attached to the HD is a PC board. There are 3 screws holding the PC board down. Remove the screws and carefully remove the HD and PC board.
(4) unplug the powere plug and the IDE interface from the HD. Now you have a HD that you can install in your own case (as long as you have a desktop unit and not a laptop).
(5) I installed the HD in an empty slot, connected the IDE cable that was already there (between the CD and IDE interface), plugged in the power plug, fired 'er up, and voila, works like a champ.
I suspect that the problem is in the interface (PC board), since the only thing I did was remove that from the equation. Hope this helps
Kudos! Thanks!
09-09-2008 09:36 AM
Dec 31, 2008 | Maxtor BASICS Personal Storage 3200...
Gateway gt5220 beeping noises, fan on.
What may be happening is that files are corrupt as a result of a HD failure. This is not that uncommon. It has happened to my computers causing strange beeps and often repeated clicking noise coming from the hard drive. HD failure can happen anytime; when booting up, while the computer is running. The only way I've found to fix this is to buy a new hard drive and reinstall the operating system and programs you typically use.
You may be able to recover files from the ailing drive however. After you get the new hard drive working with your newly installed operating system and all is working, you can setup the ailing drive as a slave while setting your new drive as a master. You need to power off the computer and consult the data sheets for jumper settings.
This will allow you to boot up and access your old HD as a spare. If your lucky the data files, pics, music and documents you created will be in a region of the hard drive that isn't corrupted. Be prepared however to expect some unrecoverable files. If there is physical damage to the drive mechanism like a stuck read/write head then you may be totally out of luck. I have in some instances been able to unstick the HD by giving it a sharp rap on it's edge and even opening it to push the head free. Success for such a radical procedure is rare, but when it works, you have enough time to copy files over before enough dust collects on the exposed HD.
Assuming your able to access the old HD as a secondary drive, copy all of your files over to a backup directory on the new HD. I would recommend an expternal backup HD that can be used to automatically save your files before the next failure happens.
Nov 30, 2008 | Gateway GT5220 PC Desktop
I replaced mother board now I can't access files on old HD
Try going into the BIOS settings and setting the slave drive as the 1st boot drive.
May 04, 2008 | Intel Motherboard
Packard bell imedia 3034
After reading a ton of posts you may be correct, your board is dying or is dead.
An easy way to get your data off your old Hd to your new Hd would be to connect it directly into the new PC internally.
Just like you would a new drive only you would set the old drive as a slave. Here is your 3034 link.
http://support.packardbell.com/uk/item/index.php?pn=P842025601&g=1400
The motherboard in this 3034 is Gigabyte, GA-8SIML-NF7, shown at this link: http://support.packardbell.com/uk/item/index.php?i=spec_columbia5p&ppn=P842025601
There is almost no chance of you finding this board its just too old. There are boards at this link that will handel all of your imedia 3034 parts, motherboards.
http://computers.pricegrabber.com/motherboards/p/40/form_keyword=motherboards+478+socket/rd=1/mode=g_us_b_s/skd=1
Hope this helps you Jim!
Please vote...
Jan 18, 2008 | Intel Motherboard
How to Install a new HD on Dell Inspiron 6000?
You can always parition the drive, and install both Ubuntu and XP (dual boot).
Yes, you will be able to access the files (providing the drive isn't totally crashed), although Ubuntu may not "know" what the files are.
Jan 10, 2008 | Dell Inspiron 6000 Notebook
Western Digital Scorpio WD800UE (WD600VE50PK) 60 GB Hard Drive Logo
126 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
