Question about RCA F32450 32" TV
36" RCA- loud whine/squeal when it is plugged in, otherwise no power.
36" - F36650. When plugged in, a loud whine/squeal is heard. I believe it is coming from a transformer (horizontal transformer?). Also, while unplugging the set (or if it is left plugged in long enough) I can hear a clicking, I believe coming from this same transformer. It is not the flyback transformer, but a smaller transformer mounted on the board. Also, it is not encased (like the flyback is), I can see the E's and I's. Do these symptoms coincide with a faulty transformer (I believe it is a horizontal transformer)? If so, are they expensive, and where should I go for one?
  • Anonymous Oct 19, 2008
    I have the same problem.
  • shnazzyone Oct 27, 2008
    Me too this is my issue
The HOT Hortz output transistor has gone home, 99% of the time from a faulty IVHT (Flyback Transformer), very common on the ctc187cl* chassis. The factory Flyback is no longer available, I have had problems finding an aftermarket one to replace it with.
The HOT is a BUH517, but you can also use a 2SD5129. It is the transistor mounted on the siler heat sink with a metal clip rather than a screw, just in front of the flyback.....
If you replace just the HOT, most of the time you will get a rapid arc (27,000volts - BE CAREFUL!!!) from the lower (yoke) post on the flyback. If the flyback is shorted, It may also just burn out the HOT and go right back to "squealing"....
Good luck finding the flyback!!!
Posted on Feb 24, 2009
My t.v. whines when innitially plugged in. no picture (rca f36650) guide plus gemstar xbox ready entertainment series
The tv have a dead part call the FBT-Flyback transformer,a big black block of plastice with a red wire with a black cap hook it to the CRT-(Tv picture tube).The FBT-give the tv highvoltages to the CRT(Tv picture tube).This tv is old model of an analog tv probally can't find part for it anymore.
Dec 08, 2010 | RCA F36650 36" TV
NO PICTURE AND WHEN PLUGGED IN, JUST MAKES A HIGH PITCH SQUEAL
Your horizontal ouput is shorted. You might can get by with just replacing it but the flybcak may also be bad.
Jan 05, 2010 | RCA F36650 36" TV
RCA F36650 36" TV
is the squealing noise from the back of ur set , if so it is ur flyback transformer
May 29, 2008 | RCA F36650 36" TV
RCA 36" model f36650
If you have your manual, the manual may have the error codes in them, otherwise you can search online for the error codes or post the model number here so that we can help you find the correct manual or list of codes, but yes the lights are an error code.
Let me know if you need any further help
Mar 28, 2008 | Televison & Video
RCA F36TF720YX2 TV
The squeal maybe produced by the flyback, It looks like is a common defect on this chassis, but check any other defective part in the horizontal section and the power supply as well.
The fly back part # is 257805 but i would call RCA just to verify it or you can check inside the Tv's lid for that part number.
Check globalsemi.com website.
Good Luck.
Jan 17, 2008 | RCA F36TF720 36" TV
F36650 No power, high squeal even without turning on.
CaptC, those sets are infamous for that problem, you need to replace the following parts:
Flyback Transformer part # 257805
Horizontal output transistor part # 2SC5148
there is a coil off the base of the driver transistor I think it`s L4401 that should be removed from the set and scrape the wax off the legs then re-install and re-solder it and you should be good as new, good luck
Nov 27, 2007 | RCA F36650 36" TV
No picture High pitch squeal RCA F36650
Confirm service # from back of set = F36650 YX01..........
Transformer red HV lead attaches to CRT & Horiz output
xistor is on heatsink next to transformer = 2SC5148 .........
Rca part # 257805 or ASTI 2078 and 237470 xistor............
Do not use a generic transistor = name brand only............T.
Please rate this solution..............
Nov 12, 2007 | RCA F36650 36" TV
RCA F36650 36" 2002 xbox ready tv
Yes it is the Horizontal Output and a few capacitors and resistor that needs changing. If you are good at desoldering and soldering you could do this. I think on this set its the Q4401, caps C4402, Cr 4402, Check Q4802, C4102, If you just want to try new parts and hope it works then you have to check voltages at different points to fix set. Now it also could be Bad Flyback in this set too. I have seen where you change flyback and horizontal output and c4402 would do it. R4118, R4114
Sep 09, 2007 | RCA F36649 36" TV
RCA F32450 32" TV Logo
464 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
