Question about Canon PIXMA MP470 All-in-One Printer
Paper-feeding mechanism broken
There is no paper jam, there are no obstructions, and it still won't print.  The paper is fed in a little bit but then it stops and the error message reads "No paper in tray."  I literally am about to destroy this thing.  Please help!
  • 9 more comments
  • kayfisher31 Oct 22, 2008
    I also have the same problem !! HELP US = (
  • guspy Nov 22, 2008
    paper won't feed..i check everything there was no obstruction...
  • paulw705 Nov 25, 2008
    Everything is clear and even done Clean Up operation on Paper Feed. Stiil partially feeds then appear to get blocked from going in any further. Ten machine says insert paper when there is obviously plaenty in Paper Tray.
  • Anonymous Dec 02, 2008
    I have the same problem, though mine actually tears the paper as it prints and then I get an error message saying that the paper tray is malfunctioning. I have no idea what to do.
  • aschwitz3 Dec 03, 2008
    mine feeds in near the roller and then jams the printer,
    i pull it out, i've cleaned the printer roller i have no idea what to do.
  • JAlpeza Dec 05, 2008
    I have the same problem. Anyone have any solutions?
  • Anonymous Dec 20, 2008
    Paper jam error appears - tells me to clear jam and click OK - there is no jam - even with no paper or 1 sheet, it whirrs a bit and then gives the same paper jam error.  What gives?  Just bought new cartridges online one second before I tried to print the order form and the printer went ERROR Nuts!  What now?
  • stitchen Dec 23, 2008
    I've had mine for about six months and haven't even changed the ink, yet and it says I'm out of paper. It draws from one side, then stops and says no paper. Very frustrating. Expensive printer to last only six months!
  • Anonymous Apr 09, 2009
    keeps telling me theres no paper, but theres plenty. the damn printer refuses to feed the paper!!! help
  • Anonymous Apr 12, 2009
    Need I say more? Who can help us???
  • Anonymous Apr 29, 2009
    This is ridiculous, I've hardly used this printer and the piece of junk WON'T FEED THE PAPER
I am getting a message that The paper is jammed but it is not, at first the paper would go in crooked, and it would jam, then put it through again and it would do the same thing again. Eventually I would get some Clear the paper and press OK. I do that and it doesn't help. Somebody suggested I unplug the printer from power, Unplug the USB printer, Restart the computer, Plug in and turned on the printer, Plug in the USB printer cable. I thought that might reset it but it didn't help. This printer worked great one day and the next this started, PLEASE HELP
Posted on Apr 13, 2009
I am having the same problem :( HELP!
Posted on Oct 21, 2008
Lexmark s605 paper jamming
Sounds like an obstruction on the right hand side of the feed mechanism. All-in-ones are a pig to find these - I've had one HP almost completely stripped before I found a chad of plastic stuck in a corner. Nine times out of ten it's a torn corner of the first bit of paper to get chewed jammed in the feed slot.
Apr 06, 2012 | Lexmark Interact S605 All-in-One Color...
Printer is telling me paper is jammed but there is no paper jammed
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Check this link for tips;
http://www.ehow.com/how_113761_clear-printer-paper.html
Nov 15, 2011 | Canon PIXMA MX310 All-In-One Printer
Hi there I have a canon Pixma MX360. The printer got a paper jam and I have removed all the paper that was jammed in the printer, however when I press OK to confirm the paper has been removed the settings...
You must check carefully to make sure all paper is removed, even little pieces that may have been torn. Use a flashlight and check very carefully in the paper path, also look down the paper chute, and where the paper exits.
Aug 03, 2011 | Canon Pixma MX360 Printer
Dcp 115 is showing "Paper
Please also check this link for tips:
Jul 22, 2011 | Brother DCP 115C All-In-One InkJet Printer
Paper Jammed, Paper freed, Paper does not now feed correctly and does not print.
what kind of printer this is? most commen is the type of paper, also try to roughen the wheels with a slice of grounding paper, very gently
Jun 16, 2011 | Office Equipment & Supplies
PRINTER IS SAYING THERE IS PAPER JAMMED AND IS NOT FEEDING PAPER THROUGH BUT I CANT FIND THE WHERE THE PAPER IS JAMMED OR HOW TO ACCESS THE ROLLERS WHERE IT MAY BE JAMMED PLEASE HELP
Jan 24, 2011 | Canon Pixma MP450 All-In-One InkJet...
I am getting a "paper jam" signal but can find no
Oct 30, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Paper i feeding wrong, it starts then backs up a
Generally whenever paper goes "crooked" it's because something is partially obstructing the paper path.
It could be a small piece of plastic, or paper from a previous jam that tore off and stuck.
I would suggest looking at the paper path (use a flashlight) to see if there are any obstructions and then carefully remove any found.
I've also seen where the side plastic has become broken, or has a sharp edge sticking out that will cause the paper to misalign.
Hope this helps!
Sep 01, 2009 | Epson Office Equipment & Supplies
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Paper jam
Well, if you could put that disengaged gear back all by yourself, then put a little "grease" or "oil" on the right side of the paper tray are mechanical levers or gears especially the one pushing the paper forward... when you're done.. printing goes fine again...
Oct 25, 2007 | Epson Stylus Photo R320 InkJet Printer
Canon PIXMA MP470 All-in-One Printer Logo
342 people viewed this question
old marine
old marine
