Televison & Video Logo
Anonymous Posted on Oct 06, 2008
No Picture, No Sound
I have had my RCA HD50LPW164 since about 2005. I haven't had any problems, then one day the TV will not turn on. The blue power indicator light is a solid blue but when I press the power button there is no response, no picture, no sound.
Any ideas what this can be? I know you have to change the bulb every once in a while but shouldn't I still get a response from the TV and sound? I was also told it could be color wheel failure. How do I locate the source of the problem?
  • Mike  Viegas
    Mike Viegas Dec 06, 2008
    I have a RCA HD50LPW164 I haven't had any problems, then one day the TV will not turn on. The blue power indicator light is a solid blue but when I press the power button there is no response, no picture, no sound. I also just put a new Lamp in it and it was working fine for a couple months.
  • Mike  Viegas
    Mike Viegas May 11, 2010
    Could you please explain what flyback means
Anonymous
Level 2:
  • Expert 185 Answers
  • Posted on Oct 08, 2008
Anonymous
Expert
Level 2:
Answers
185
Questions
0
Helped
30167
Points
263
  • Anonymous Mar 05, 2009
    must have been thinking of a different model yours hasn't got a flybabk
2answers
Rca tv 32" hd tv serial number 2212-32lb45r-a101474 will not come on the blue botton comes on but we have no picture
Do you have sound still. Ifvso while the TV is on, shine a torch into the screen .
if you see a picture you possibly have a backlight issue
failing that tcon board but get it tested
What parts might be bad if tv powers on, standby light turns blue, but still no picture or sound?
If back-light is OK, the fault will be with its T'Con board. If you wish to get some details; check the site linked here. Pull up older posts.
I have an RCA 32" LCD HDTV/DVD Combo model 32LB30RQD it has power, but no picture or sound and no turn off the blue power light.
Probable defective power supply board in the set. ebay RCA model # for replacement power board. Replace board
Viewsonic LCD TV N4280p haven't picture and no sound ,but turn on
Hello
There is some missing output voltages from the power supply regulator board to your tv. Normally, these board are replaced as card basis. some of them are repairable too. You have to check this board first, to find whether it is repairable or not. If not replace it as card basis.
2_8_2012_4_19_29_pm.jpgTwo vies of the power baord to your TV is attached here. This board can be purchased either from the authorised service center for Viewsonic at your town, or from any electronic sparepart selling shops at your town.2_8_2012_4_20_00_pm.jpg
1helpful
I have a RCA 27" flat SDTV purchase in
Ur power inverter board is dead.
U need new one.
2answers
RCA HD50LPW164
It is very well possible for new lamp to be bad ?
3helpful
3answers
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
