My pc won't boot up and there is message to insert system disk. I insert the disk boot up to the same message.
    Genius:
  • 1,124 Answers
Take out all the disks from your computer drives and start up again.
If the computer prompt for a disk or OS, probably you have a HDD problem.
To get your CD drive available to boot...you must set that option on your PC bios (boot options menu)
Posted on Oct 07, 2008
If a computer boots up and display a fault message such as ..." Insert System Disk"; what is the fault?
Cannot find the hard drive or cannot find a bootable operating system ie. corrupt files/dead drive/cable damaged or not connected.
Apr 06, 2014 | HP Computers & Internet
Getting message "Disk Boot Failure Insert system disk and press enter" using window xp platform and have MCA fee antivirus software
this happens either the boot sequence have changed or your hard drive is not recognised by the BIOS
Jan 26, 2013 | Computers & Internet
My computer won't turn on properly. It keeps saying disk error press control alt delete. When I do it just says it again and again. It won't load and turn on.
First you should check if there is any disk on your cd room, if there is any disk you should remove the disk from the cd room, if there is no disk the possibility is your hard drive getting error
Press f2 or delete to enter your bios set up system
Look for boot menu
Set the first boot as a HDD and the second boot as cd room and disable the third boot
Save and Exit the setting
if your computer still won't load you need to reinstall your windows
insert windows cd and go to set up again by pressing f2 or delete button
Set the first boot as cd room then the second boot as HDD
Save and exit the setting again
When the message press any key to boot from cd appears you should press the space bar or another key
Then just follow the instruction of formatting
Jun 03, 2011 | Acer Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
When i turn my computer on i get a message that says, disk boot failure, insert system disk and press enter
Your boot file on your hard drive may have been corrupted. You need to start the computer with your operating system disc in the drive, and hopefully it will be able to repair your operating system. good Luck!
Jul 17, 2010 | Compaq Presario SR1030NX (DW256A#ABA) PC...
Error message asks me to insert the boot disk. I
Your laptop bios may not be booting into the operating system drive or your drive partion may have an error.Try entering into the bios and checking to see that the boot order is still set to boot from Drive 0(Hard drive).During boot up,the bios looks for command to find the first boot device specified according to system settings.You can enter into the setup by tapping the Delete key when u first power up your computer..please let me know how u make out:)
Apr 12, 2010 | ASUS Eee 4G Notebook
Toshiba satellite 5105-s607 insert system disk error. Every time put o.s disk in keeps saying same message.
Log into the bios and change the boot order to boot from the CD - it will then boot up your CD system Disk first
As the PC boots - you should see a message to get into bios/setup usually F10, F2 or del key varies buy manufacturer
then look for the bios section for boot order and make sure the CD/DVD drive is set to before the harddrive
Mar 19, 2010 | Toshiba Satellite 5105-S607 PC Notebook
Non system message
Your boot sequence is probably not set to boot from the Hard drive first. Remove any floppy disks/CD's from their drives and try to boot it.
If you are still getting the message then you have files that are corrupt on your hard drive.
Jan 26, 2009 | Gateway Media Center 610XL PC Desktop
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
