Question about Panasonic KX-TG2357 Cordless Phone
Panasonic KX-TG2357 needs a new key / number pad. numbers are to hard to press to make contact
  • lukyduck Oct 25, 2008
    I have the same problem!! What a pain....the numbers are so hard to press and often do not connect to dial out ... or because I am pressing so hard it sometimes dials the number twice and I get the wrong number.. It is mostly the most-used number pads that are problemsome (1-4) and the rest are generally ok.... do i need to replace the key pad??
  • rjolding Dec 30, 2008
    I have exactly the same problem with one of my two phones and suspect that something might have been spilled on it. i have tried to dismantle it but cannot get it apart. I have removed the two screws inside the bottom portion of the battery compartment but I see nothing to remove to get the upper part to separate. Any ideas?
To open phone remove the 2 crews at the bottom, then pry open using a screw driver to unlock the internal fasteners. then remove 3 internal screws. Clean-up the PCB key and the back of the keypad with Acetone. This works perfectly. Saved me $150 on a new set.
Posted on Jan 10, 2010
Sometimes moisture builds up inside the phone and affects the functioning of the keypad. If you are somewhat skilled in working on such devices you could open up the phone and clean up the back of the rubberized keypad (especially the conductive buds) and the contact areas on the PCB.
Posted on Nov 03, 2008
Forwarding calls on Panasonic tx-tg2357
You can transfer a call between units, but you cannot forward to a different phone number. Page 48 of the manual details this: http://service.us.panasonic.com/OPERMANPDF/KXTG2357.PDF
Mar 18, 2015 | Panasonic KX-TG2357 Cordless Phone
PHONE CS6629, HOW DO I ENTER LETTERS ON TO KEY PAD INSTEAD OF NUMBERSRS
Assuming you want to enter a name into the directory, simply keep pressing the appropriate key until you get the desired letter. For example, if you want one of "ABC" then keep pressing the "2" key to cycle through these letters.
Dec 30, 2013 | Panasonic KX-TG2357 Cordless Phone
Cs6629 how do i enter numbers on to key pad instead of numbers
My panasonic kx-tsc10mxw keypad locked
take this:
1- Press Function
2- Press Down button until menu “Change password” displayed -> ENTER
3- " Current password " : Press this Number "726276642" -> Enter
4- “New password”
5- 0000 ENTER
6- EXIT
7- Press DIAL LOCK KEY
Jul 12, 2009 | Panasonic Lands Phones
Where to get new key pad
you need to pull it a part and cleen the push butons under the carban with matho cheers peter
Apr 05, 2009 | Panasonic KX-TG2382 Cordless Phone
Need hnew handset for Panasonic KX-TG2357
www.amazon.com/Panasonic-KX-TG2357-Technology-Speakerphone-Answering/dp/B000JF23IS - 240k
Available from these sellers
Jan 10, 2009 | Panasonic KX-TG2357 Cordless Phone
Panasonic kx-tg2357
Called Panasonic Support. The unit will NOT record voice messages whilst in talking mode.
Jan 06, 2009 | Panasonic KX-TG2357 Cordless Phone
Key Pad buttons require more force to accept the input - loosing memory!
I have the same phone with the same problem and didn't want to part with it either. The cause of the problem are skin oils that seep down the rubber keys, and through slots at the base of the molded pad, thereby interfering with electrical contact. There is a vendor on ebay that sells a tape like pad with larger contacts that solves the problem perfectly. Go to ebay and use the following search term (I know this isn't the same model number, but its apparently compatible) :
Panasonic KX-TGA230 KX-TGA270 KX-TGA230B BUTTON FIX
The price is 5.95 including shipping. The repair pad will come with an instruction sheet, or you can go to the website on the instruction sheet and download about a 40Meg video file that shows you exactly how to make the repair. My phone operates with a nice light touch now that its fixed. Good luck.
Aug 24, 2008 | Panasonic KX-TG2383 Corded Phone
Panasonic KX-TG2357 Cordless Phone Logo
603 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
