Question about Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater
Blue flame heater pilot wont stay lit
Pilot wont stay lit flame wont come on
The thermocouple is bad.replace it and your good to go.about 8 or 10 bucks at your local hardware
Posted on Feb 03, 2009
  • 153 Answers
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Posted on Oct 07, 2008
2 Suggested Answers
TheMobilian
  • 8205 Answers
SOURCE: wont stay lit
If dust gets into the pilot safety device called an ODS (oxygen depletion sensor) then the safety thinks the air is low and kicks the pilot off. To remedy it I flush the pilot with a little rust buster. This cleans the dust out without disturbing the air flap. I have repair photos and a neat demo video that shows how it works HERE
Posted on Feb 21, 2010
New kozy world natural gas heater. Pilot light wont stay lit snd heater flame wont stay lit.
Are you holding down the pilot light button long enough for the heat sensor probe to get hot and turn on the gas valve? It takes up to 3 minutes
Nov 20, 2016 | World Heating & Cooling
I have a Mr Heater infra red propane wall heater. My problem is it turns itself off (pilot light) after running for an hour or two. I have no problem getting it turned back on but for some reason it d
Your pilot flame should be blue with a small yellow tip, and it should cover the thermocouple (a small rod in front of the pilot light). If the flame is too small and doesn't cover the thermocouple, it may be adjusted too low, or you have low gas pressure or you have a leak in your gas line coming in to the heater. If the flame looks like a lazy yellow flame, you are probably not getting enough air to the flame. Check that your air openings around the pilot are not clogged up. If the flame looks like a waving blue flame then you probably have excessive draft at the pilot. If the pilot flame looks good and covers the thermocouple, then the thermocouple might be bad. Best of luck. I hope I have helped.
Nov 23, 2013 | Heating & Cooling
Gas burner wont stay lit
Is it the Pilot, or the main burner that won't stay lit?
The pilot has a little 'flame rod' in the path of the pilot flame, that conducts a tiny current thru the flame, to a detection circuit-- assuring that there is a pilot flame-- If that rod get's dirty, it can cause false trips. Is that any help?- Mack B
Oct 25, 2013 | Honeywell Pilot Burner for Natural Gas,...
My 30,000 btu Blue Flame gas wall heater wont stay lit, pilot light stays lit but the blue flame went out and had smell of gas I shut off the gas supply but, dont know what is the problem thanks, marty
you could have a overdraft problem causing your flame to go out. check your draft setting at the burner and make sure it's not open too wide. If it is, simply close it it slowly and make sure that the flame remains totally blue.
Nov 27, 2010 | Heating & Cooling
Pilot wont stay lit and weak flame
Tap pilot head to knock off any built up corrosion and rust and flame will get better and keep pilot lit
Nov 25, 2010 | Empire DV-35 Heater
How do I fix a pilot light that will not stay lit?
Check the gas valve. Sometimes the springs in the valve can wear out.
Another thing is the pilot itself. Inside the pilot is a little rod that stays heated to ingnite the igniter. It can become dirty or corroded and won't allow the pilot to stay lit.
Apr 19, 2010 | Vanguard International Blue Flame - Large...
Pilot will not stay lit and heater will not light
thermocouple probablly bad, is the flame covering the thermocouple.
the flame has to hit top portion of thermocouple to work correctlly.
Feb 14, 2010 | Endless Summer (GA200209) Stainless Steel...
Pilot flickers replkaced ther-cup now pilot wont lite/stay lit.
Blow out the dust from the pilot and reposition the pilot where the flame hits the tip. more
Jan 26, 2009 | Williams 2509612 Ceramic Mid-Size Heater
Wont stay lit
go to this site www dot desatech dot com. Here you'll find parts to repair your heater. a propane heater uses a millivolt generator to sense the flame. along it's cappilary are two push on spde connectors. these connect to the high limit temperature sensor which is mounted on the flame backplate of your heater. to see if it is the high limit shutting down your heater, jumper across the two spade connectors. if the heater stays on, this is your problem. if the flame still goes out, then the millivolt generator is shot.
Nov 09, 2007 | Coleman 5075751 Utility Heater
Dyna-Glo D-E36 Infra-Red Wall Mounted Panel Heater Logo
517 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
drifterray
Level 1 Expert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
