Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Ice maker DOES NOT WORK.
Was working fine but a piece of ice got stuck like it always does. When I removed the stuck ice the ice maker would not work.
  • greatfullme Oct 06, 2008
    Whirlpool 25cf SxS GS5SHAXNQOO
  • 112 Answers
Make sure the bale arm is up. If it is, check the rake fingers of the icemaker, they should be at about 2 oclock looking from the boxed end. If they are not in the correct position, your icemaker needs to be replaced.
Posted on Oct 14, 2008
  • bruce harrod Oct 14, 2008
    The bail arm must be down. Sorry about that
My lg side by side refrigator ice maker it will make ice but doesn't always come out of the tray
About once a week, I have to take the ice bin out and empty the ice in a large bowl, remove the stuck-together pieces then return the ice to the bin and replace the bin. Good luck.
Feb 12, 2017 | LG Refrigerators
This sometimes happens with my KitchenAid ice maker.
Usually there is a piece of ice stuck on the side where the sensor is that causes the ice to drop. I usually carefully chip away at any ice that is stuck. Once the stuck ice is removed, the ice maker works fine.
Sep 18, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
My ice maker was making noises and I looked at it and a piece of ice was obstructing the ice ejector. I removed it and it worked fine for a week. Now it fills with water, freezes, but they are not...
there are plastic arms on the ice maker,sometimes they bend and get jammed or when the ice got stuck it did damage to the motor and it finally died,if it's filling,a heater on the ice maker comes on,loosens up the cubes,the motor turns and dumps out the cubes,it sounds like you have a bad ice maker
Mar 29, 2011 | Jenn-Air JCD2295HES Side by Side...
The ice maker wont drop the ice
Try this pour Hot water in ice maker it may be stuck then see,if blades turn there could be something stuck in ice maker.write back (I had a piece of plastic bag get stuck on the rotateing blades that push the ice up to the drop tub underneath) I hope this works for you
Aug 29, 2010 | Whirlpool Refrigerators
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice maker does not make any ice green light flashing in freezer
There was a small piece of ice stuck in the back prongs. Removed stuck ice (very small but enough not to make it work). Now it works GREAT!
May 15, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice Maker does not work
My husband repaired our ice maker after our repairman failed to show to replace the entire unit. He removed the front panel and then the next panel fastened by 2 screws. A white plastic piece can be seen as the ice exits the unit, which is poorly designed and literally gets stuck to the left. He slid the piece to the right and vuala! It works. He is looking for a rubber piece or something that will keep the piece pushed to the right, as it seems due to the poor design that this type of malfunction will happen again... good luck!
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
405 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
