Question about Motorola Mobility RAZR V3m Cellular Phone
Battery is not charging (even new battery). - Motorola Mobility RAZR V3m Cellular Phone
    Sergeant:
    Champion:
  • 370 Answers
Most probably the charging pin is not working .... have it replaced only after you check your charger.... also if its under warranty ... go to the local authorised service centre
Posted on Oct 09, 2008
My old 611 dosent hold the battery charge for long even though I have put in a new battery
An in car charger will not charge as well as the mains, when charging for the first time you should use the mains, and charge for at least 8 hours. If it didn't charge correctly, it will be the same low charge all the time, as the battery has a memory that makes it charge the same each time. Try charging from the mains, you might be lucky.
May 22, 2012 | Cell Phones
I have nokia 6120c charging shows but not store on battery even i changed new battery please help!
You will need to check your adapter and also the voltage that comes to the battery at the charging terminals while the adapter is plugged on.
Since your new batteries are also not charging it is possible there is fault in the charger for not providing the sufficient voltage/current to the battery.
Finally it is possible that there are errors in the main board - charging circuit that prevents the desired levels of voltage required for charging.
Feb 04, 2011 | Nokia 6120
Lg b2050 is taking too much time to charge,it's about 5 hours.IS IT THE PROBLEM WITH BATTERY OR CHARGER?
buy a new battery brother
if its 4/5 years old
sometimes less charging the battery damages its potential and u need new battery.
do charge battery daily even when not in use.
Sep 12, 2009 | LG B2050 Cellular Phone
Battery
Your battery is gone, you will need to replace a new battery because the old battery is at it age. When you get a new battery, charge it 24 hour to fully charge it before you use, it is very crucial to maintaince the life of battery
Jul 20, 2009 | Apple iPhone Smartphone
My battery won't seem to hold it's charge for even 6 hours
well 2 years is a long time, considering that battery has 500-600 charges lifetime I think you'll need new battery...
Jun 26, 2009 | i-mate JasJam Smartphone
BATTERY UNABLE TO CHARGE, ALTHOUGH PHONE WORKS
Well, the white to pink dot is a sign of water in the phone. It is a moisture indicator and the first thing the repair fols look for so they can deny any claims.
They second thing is you can get an external battery charger for the razor. They run about 5 dollars and allow you to charge the battery seperate from the phone.
Razr V3 external battery charger
May 27, 2009 | LG VX9400 Cellular Phone
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
It doesn't gharge even with a new charger
sometimes the pins inside mob
were broken
or battery were old these are the two cases
for not charging
try to charge with another battery
Mar 21, 2008 | Motorola Mobility E398 Cellular Phone
LG KG800 charging problem.
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Jan 21, 2008 | LG KG800 Cellular Phone
Motorola Mobility RAZR V3m Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
