Question about Toshiba 36A60 36" TV
TV dead; unresponsive, no raster, nothing.
The set is unresponsive to remote or to on-set controls; no raster, located all four fuses, all check good; a/c power is measured after the main fuse... appears to be no filament heat in the CRT...looks like the controls are not activating the power switch...
    Scholar:
  • 92 Answers
You may have lost the standby power supply. There should be a 5v supply that runs with the set in standby, see if you can find that. Also check for B+ (around 160VDC) at the large filter capacitors in the power supply.
Posted on Oct 07, 2008
Sound but no picture on samsung 51e440a plasma. Experienced tech but new to plasma technology.
You've done a very good and exhaustive check of the TV electronics. It appears that the boards are all doing their jobs and you are getting sound and can control the TV. Do a thorough check of the glass panel with a flashlight. Look for fine cracks, particularly in the corners.
Feb 08, 2017 | Samsung Televison & Video
How do i fix a non responsive tv set?
Do the ballast first. That should get the picture back. The main board controls everything else.
Oct 08, 2016 | Televison & Video
Kec tv problem and solutions
In other words, the set is in dead condition. You should start troubleshooting from the main power retulator section circuits.
May 28, 2013 | Televison & Video
Kec b w tv kit
In other words the set is dead now. Check its main power supply regulatior section circuit.
Can't change channels, volume, or power off or on
You need a new frount control raster for this TV, what has happend is this little circuit board under the buttons has given out. You might have lost the function to control with the remote as well. The best thing to do here is take it to a tv repair shop. and have it looked at.
Diagnosis: bad control raster
Prognosis: replace raster with spare or new
Do not shoot the messenger please do leave postive feedback and ratings today.
Jun 14, 2010 | Toshiba 32A33 32" TV
Power will not come on, but fuse is good
i dont know about a code but i would check my 5 volt standby power supply voltage ,and depending on tv check all standby voltages with set pluged in only .if stand by voltages is good check for horiz drive at base of driver trans when you press the power button
Apr 16, 2009 | Televison & Video
TV will not power on
the remote button has change resistance... its a carbon film resistor on board.. cleaning
Dec 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
RCA P52960 R/P lost all controls..remote & panel!1 HELP
Hello ChupacabraV2,
This is a scene from some horror movie. I bet , if you unplug it, the TV will still be on!!....Just messing with you. Its been several days since you posted this problem. Please post update if there is any change. I don't think you have the TV on all this time. Let us know
Best regards
circuitcity
May 31, 2008 | RCA P52960 52" Rear Projection Television
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
No raster, No sound
Your problem discription is not very detailed but certainly it sounds like the first place to look would be at the fuses if the set is completely dead. Good luck.
May 26, 2006 | Philips 21PT4475 TV
Toshiba 36A60 36" TV Logo
142 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
