Question about Dell DJ Ditty MP3 Player
My dell dj ditty has frozen
The screen is permanetly froze with the picture of it cinnecting to my computer.. when it is plugged into my computer, my computer does not recognize it..
  • 8,596 Answers
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Posted on Dec 14, 2008
How do i take off music out of my dell dj ditty mp3
Plug up your dell DJ Ditty MP3 Player
Go to my computer and click on your storage device
You should be able to manually delete what music you want off
Jan 16, 2011 | Dell DJ Ditty MP3 Player
Need installation cd for dell dj ditty
buscalo en internet solo ingresando el modelo
Aug 28, 2009 | Dell DJ Ditty MP3 Player
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
-Tha Mp3 Doctor
Dec 14, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
Nov 13, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty
This is a flash memory type player, all you should have to do is plug it in to your computer, select the drive that it is plugged into and it should show all the items on that memory, then select all, and right click to delete. From here you should be able to select different songs from your files and copy them over to that particular drive... See if that helps
Sep 20, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
Jun 27, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty
We may be in luck - I actually found an owner's manual for this one. Did you run the installation CD first? If you don't, Windows will load it's own, possibly wrong, drivers.
The Musicmatch service that this player was tied to was discontinued in October 2007, so your going to have problems even if we get it working again. Use Windows Media Player 10 instead (downgrade if you have the current version 11 installed).
Let me know how everything turns out.
-Tha Mp3 Doctor
Jun 13, 2008 | Dell DJ Ditty MP3 Player
Dj ditty
Reset, make sure lock is not engaged, then
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Nov 15, 2007 | Dell DJ Ditty MP3 Player
Computer won't open DJ Ditty
Windows Media Player 11 not compatible with this player.
The device doesn't know if it is a MTP or MSC device - in one of these modes, it will not allow access to the music folder. unfortunately, there is no way to switch between these two modes in the menu settings. Go to Control Panel - Device Manager - find MTP Deivce and update driver.
Sep 28, 2007 | Dell DJ Ditty MP3 Player
DJ ditty wont work
Connector bent = replace the player
May 02, 2007 | Dell DJ Ditty MP3 Player
Dell DJ Ditty MP3 Player Logo
547 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Greg Cann
Greg Cann
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
