Question about Dishwashers
LG dishwasher displaying EO error message - have checked all pipes, no blockages
    Sergeant:
    Champion:
  • 334 Answers
LG Manufacturer Library »
LG Customer Support: (800) 243-0000
E0 code is attributed to a short keypad with the Electronic Range Control (ERC).
replace the erc
Posted on Oct 06, 2008
    Genius:
  • 1,847 Answers
What is the error message or code that you are getting?
  • Legin Varghese
    Legin Varghese Oct 06, 2008
    n order to fix problem we disconnected dishwasher, put it on one of
    side, opened bottom cover - the one that is outside of dishwasher. We
    find out the part that is
    connected to the drain horse. We take of 3 screw and open that part too. We discover
    few small peices of glass that were preventing to rotate one plastic
    part of dishwasher. We removed that pieces of glass. Put all back and
    connected dishwasher. All was working fine. I am suggesting to
    everybidy try these steps before calling for any service.
I have an error code on my Electrolux dishwasher EO?
Hello Judy, thank you for your post!
I understand that your Electrolux dishwasher is displaying an error code of "EO". The error code "EO" means that you could have a possible issue with the flow controller. I would recommend performing a reset on your dishwasher and this could help clear out any potential miscommunications. You can reset the dishwasher by disconnecting power from it for at least ten minutes. If the reset does not help correct the error code I would recommend having a professional technician out to perform a full diagnosis. Hopefully this information is helpful to you. -Matt
Feb 03, 2016 | Electrolux Dishwashers
How do I resolve f17 error message on bosch classixx 7
F17 is a time out fault on drain pump. Check all water hoses and drain pump for either blockage or restriction. Failing that, check your waste pipe is clear.
May 29, 2014 | Bosch 24 in. SGS43C12 Classixx...
Error code eo
Hello Gary, I am happy to assist you! I see that your Frigidaire dishwasher is displaying error code EO; however, is it possible that the code is missing a number or character(s)? Typically error code "E0" is follow by another number. In the meantime, you can reset your dishwasher. This can be done by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn on your appliance. If resetting the power does not correct the issue, could you please advise me of the new error code or if it continues to display "EO"? With this information I can better address the issue at hand. Thank you! - Z
May 20, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
I have a message on the dishwasher saying EO do you know what this is?
Hi there Mark, are you sure of that code? there is no referance to it but there is a referance to OE, Oe relates to water drainage. it either took too long to drain if thats the case check your filter for blockages or it didnt drain if thats the case I would be looking at the waste pump for bockages.bent armiture or failure. I hope this helps regards Gary.
May 27, 2011 | LG 24 in. LD-12BS6 Stainless Steel...
I have a LG intello dishwasher 2050SH Turned it on yesterday and did a rinse. This was the first use for 4 months in our second home. It was very cold. The rinse stopped some way through and an error...
Hi
To unlock the lock in your LG Dishwasher, with the door open press the SPRAY & RINSE buttons simultaneously for 15 seconds. Hope this helps...please post back for further assistance.
Daniel
Dec 24, 2010 | Dishwashers
We had a short in the wiring where the dishwasher plugs into the wall. After fixing the wiring, the dishwasher now has a message "OE" when I turn it on.
Hi
Thanks for using FixYa. Error OE in your LG dishwasher is a drain error, which is displayed when the unit won’t drain out in spite of 5 minutes drain operation. To resolve this issue you’ll need to check the drain hose for any blockages, also check the wiring connection to the pump. If still the issue is not resolved then you’ll have to replace the drain pump/motor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 14, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Same problem really
with all these error codes but nothing paning out i would recommend replacing the control board inside of the door panel.
Jul 20, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Stopped Working Mid-Cycle
blockage in outlet pipe
Chris
Lg durban
031-7165444
Jan 29, 2009 | LG 24 in. LD-12BW5 Free-standing...
Hi there I have a silver LG dishwasher..I am intermittentleey getting the Code PE. I have take the pump off the exit water pipe and chaeck for blockages etc... there are none. Any ideas?
Please confirm the model number of this LG diswasher.
On recent LG units, the avaiable error codes are: IE OE E1 FE tE LE
The PE code is abnormal. Can you confirm.
I would expect to see the error OE if water is not fully pumped out. Remove the filter from the sump area beneath the bottom rack. Look closely for debris causing a blockage/lock. Please get back to me with your findings and ask more questions as needed.
Jan 25, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Dishwashers Logo
317 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
