Schematics for the Onkyo
Just to let you know that FixYa has sent the diagram of the A-8190 and that am checking possibilities. Let you know ASAP.
Kind regards.
Benimur
  • 1 more comment
  • Louie  Role
    Louie Role Oct 06, 2008
    Hi again,
    A question pls, at what point did you measure the -18VDC, speaker terminals?
    If
    yes, then most likely a problem with the output transistor pair as
    initially posted. Additionally, if it is only on one channel, then you
    can use the other channel as reference when doing voltage measurements
    or in passive/resistance checks.
    Good luck and pls postback updates.
  • Louie  Role
    Louie Role Oct 08, 2008
    Dan,
    Much appreciate the assist. I have to agree with you since this Onkyo is basically a DC amp. FixYa sent an email informing that the user asked that the schematic be forwarded to me. I did not post in the problem that I have a copy of the service manual/schematic but just mentioned that there are several models of the A-8190 (based on the primary of the main transformer). In any case, what I can not reconcile is where the user measured the -18V hence my question "at the speaker terminal?" Which is doubtful since this model uses (split PSU) +/- 60VDC. Assuming either the driver or the output is shorted, then the voltage across the speaker terminals would be greater than 18 closer to 60. The closest (but unlikely) possibility would be the +/- 22 Volts regulated supply of the NJM4558SE (Q519 or Q 520).
    Incidentally, here is the original post.
  • Louie  Role
    Louie Role Oct 09, 2008
    Thanks Dan for confirming my initial suggestion of checking Q701, and the 2SA1491 & 2SC3855 pairs as posted in the original Premium Problem.
  • 4,234 Answers
Benimur,
I don't have the info on the initial question/posting, but Onkyo systems I have worked on often have open driver transistors as well as shorted outputs. With one of the driver transistors open, the voltages tend to float to one side. The 18V you mention sounds like that is what is happening. have the initial asker replace the driver transistors (as a pair) just like the outputs.
Keep me posted.
Dan
Posted on Oct 08, 2008
  • ABRsvcs Oct 08, 2008
    Actually, if one of the drivers is open or one of the low voltage feeder resistors is open, this kind of offset is possible. Can you forward the schematic to me at dfleuryATverrents.com?
    I'll look into it a bit more and update this again.
    Thanks,
    Dan
  • ABRsvcs Oct 09, 2008
    After looking at the schematic, I see that this unit has a TA7317 chip. This is the "protection" chip and these are known for going bad. It is quite possible that the source of the 18V is this chip. have the asker change this IC. That may resolve the problem. Otherwise, lift the bases of each of the 4 output transistors and post the voltage readings on the 3 pads of each transistor here.
    Dan
Onkyo TX-NR616 Receiver will not turn on. Just hear a relay clicking. Can I download the schematics for this unit?
Hello, we do not provide schematics to end users only authorized service centers. I suggest taking it to a service center. Thank you, Onkyo USA
Apr 18, 2017 | Onkyo Audio Players & Recorders
Tail lights don't work
Hi Anonymous, check your bulb first, they were famous for failing. Then check your wiring harness and connections for corrosion, broken or loose pins. Use a test lite to trace possible shorts. For a free wiring diagram please visit the website below:
Harley Davidson Wiring Diagrams and Schematics
Good luck
Feb 12, 2014 | 2000 Harley Davidson FXDL Dyna Low Rider
Hi Johnny, would it be possible for you to email me the fuel pump wiring diagram you have posted? Thanks.
Did you get the question i sent you about the engine size?, i will do this, here are nthe diagrams. The engine component wiring is diffrent due to the fact that two type engines come in this car, i have sent you the wiring diagram for the 2.5 engine, the wiring for the fuelpump is wired the same as the 3.0 engine but if you need to check other components and you have the 3.0 engine then let me know and i will send the wiring for the 3.0. locate the fuelpump on the page and then you can follow the wiring to the computer and other locations, hope this is helpful please let me know that you have received this . good day.10_21_2011_11_32_16_pm.gif10_21_2011_11_32_34_pm.gif10_21_2011_11_32_54_pm.gif
Oct 21, 2011 | 2002 Jaguar X-Type
I have a 2007 Softail custom and have lost blinker and the horn checked fuses and all wirering possible cannot find a problem any idea's
Hi Gary, check your turn signal module connections for corroded, broken or loose pins and for a free wiring diagram please visit the website below and good luck.
Oct 13, 2011 | 2007 Harley Davidson FXSTC Softail Custom
.comneed a diagram for the
Due to copy-write laws it is often not possible to post schematics to a public forum such as FixYa.
Subaru have a tech web site you can access for a small fee or go to ALL DATA.com and purchase a subscription for your car. You will find all you need in diagrams, torque spec's, schematics, recalls, tech bulletins etc.
If you know a local independent shop well, they may print you a copy of what you need from their data base system.
Jan 13, 2011 | 2006 Subaru Outback
Lost right channel of CD
This service manual is available here http://www.manualscenter.com/onkyo-c-74.html?page=14&sort=2a. The cost is 10 bucks or 15 bucks, depending on if there is an X at the end of this model number or not.You will need to check the final output stage for an open circuit, possibly a shorted output device or a drive IC or transistor. First open this unit and make sure there are no open channel output fuses. Some models have these. Not sure about this model. Good Luck
Mar 21, 2007 | Onkyo TX-DS575 Receiver
459 people viewed this question
 Grubhead
Grubhead
