Question about Roper RS22AQXKQ Side by Side Refrigerator
Ice not moving from maker to basket
The ice maker made ice two days ago, after using it all, I pushed the level down for it to make more. Now, the ice cubes are stuck there and won't move!
  • 905 Answers
The water may have froze it up or the motor quit
Posted on Oct 06, 2008
Samsung refrigerator ice maker
Many icemakers use a bar or a sensor to shut off water when ice levels are at a maximum. Check to see if it's bent, missing, or pushed down below the ice level, tricking it into thinking there's no ice there.
Aug 03, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRS6LR5E ice maker won't stop making ice
Ice maker wire signal arm is being held down by some item in the freezer. Move item and release wire signal arm. Any ice cubes that are frozen together over the wire signal arm. the ice rises in the ice bucket and pushes the wire signal arm up and this is what stops ice production as ice is used then arm comes down and starts ice production all over again. if there is nothing holding arm down then you will need to replace ice maker.
Oct 07, 2013 | GE Monogram ZDI15C Automatic Icemaker
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
My ice maker does not shut off, it keeps making ice
Make sure the arm on the side of the ice maker is able to move. As ice level rises the arm moves up. raize the arm all the way up and it should click. This will turn off the ice. Push it down and it will turn on again
Jan 08, 2011 | GE GSS20IEP Side by Side Refrigerator
When is ice maker activated ;with bar up or down ??
The bar will sense ice cube level in the holding bin. If it is all the way down it will tell the ice maker to make more ice. When the maker "dumps" the ice the bar should be all the way up and will lower to check the level.
Jan 02, 2011 | Kenmore Refrigerators
I dumped my ice maker storage bin two days ago, and now it wont make ice.
there is a rod in this maker that is lifted up to turn it off when the container is full, push that rod down and it'll start making ice again....siever
Jan 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Icemaker not working properly
The arm has a cam, you can't see it but if you'll move it up and down about 20 times, it may clean off what ever is causing it to hang up, try that. You can always order a new one from Amazon or Ebay. It's not that hard...scale of 1-10, it's a 1.
Apr 23, 2017 | Frigidaire FRS23R4A Side by Side...
Water dispenser and ice-maker do not work
open ice maker cover buy pass T_H will move if still water not come in ice maker change fill valve
Sep 03, 2017 | Refrigerators
Roper RS22AQXKQ Side by Side Refrigerator Logo
73 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
